Baregills Posted February 11 Share Posted February 11 I have just set up my new Unraid server with a 10 Gbe NIC as the only network connection. Everything is generally working as it should, but I have experienced occasions where the Mac connects via wifi rather than the 10 Gbe connection. Obviously that does not perform very well. I can see no way to block a wifi connection. Is there such a setting? Quote Link to comment
itimpi Posted February 11 Share Posted February 11 10 minutes ago, Baregills said: I have just set up my new Unraid server with a 10 Gbe NIC as the only network connection. Everything is generally working as it should, but I have experienced occasions where the Mac connects via wifi rather than the 10 Gbe connection. Obviously that does not perform very well. I can see no way to block a wifi connection. Is there such a setting? This is not an Unraid issue as Unraid does not support WiFi so the Mac must be connecting to your router via WiFi and that is what you need to look into. Quote Link to comment
Squid Posted February 11 Share Posted February 11 You can always disable WiFi on the Mac Quote Link to comment
wgstarks Posted February 12 Share Posted February 12 (edited) Macs will connect to networks in the order set in the network settings on the Mac. If wifi has priority over ethernet you can drag them into a different order. If Ethernet already has priority then this would suggest that your Mac is experiencing issues connecting to your network via Ethernet and is reverting to wifi instead. Possibly a bad cable or port. Edited February 12 by wgstarks Quote Link to comment
Baregills Posted February 21 Author Share Posted February 21 Thanks to all who responded. The issue has been resolved ....... but I don't quite know how! Quote Link to comment
