March 9, 201313 yr Saw this on sale, thinking of getting new case and some more HDs. Right now have a 430w non modular. And only 1 Data, Parity and cache. What more could I get out of the 430w? Is it ok to go with this and not need all power of it yet? Depends on the make and model of the PSU. Mines the corsair 430cx
March 9, 201313 yr Saw this on sale, thinking of getting new case and some more HDs. Right now have a 430w non modular. And only 1 Data, Parity and cache. What more could I get out of the 430w? Is it ok to go with this and not need all power of it yet? Depends on the make and model of the PSU. Mines the corsair 430cx You should be able to run at least 12 green drives. I had 13 WD Green drives on mine before I upgraded to a Corsair 500CX.
March 13, 201313 yr I just bought the Corsair CX Series 600 Watt (available in 430, 500, 600, or 750 watts) for my desktop (non-unraid) and it works awesome. The modular design is so good for cable management, makes the whole case look nicer. Big upgrade for me.
April 4, 201313 yr http://www.newegg.com/Product/Product.aspx?Item=N82E16817151121 Seasonic SS-660XP2 ATX 12V/EPS 12V, 660W, 80 PLUS PLATINUM Full Modular certified Active PFC Power Supply + $34 off w/ promo code EMCYTZT3210, ends 4/4 Also a $20 mail-in rebate. $123.99 after $20.00 rebate - $34 promo = $90!
May 20, 201313 yr SeaSonic X750 Gold 750W ATX12V V2.3/EPS 12V V2.91 SLI Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply $89.99 With Promo Code: EMCYTZT3465 After $15 MIR with Free Shipping! Expires 5/21.
July 3, 201313 yr SeaSonic X Series X650 Gold ((SS-650KM Active PFC F3)) 650W ATX12V V2.3/EPS 12V V2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply $79.99 after $20 MIR (not sure if it will be free shipping). Newegg Shell Shocker deal starting at 1 PM ET (10 AM PT). Ends today.
August 2, 201313 yr It looks like instead of the usual cooler master componets they are using the OEM as seasonic, the same platform as Corsair AX760 and AX860 Cooler Master V-Series - 700W Power Supply with Fully Modular Cables and 80 PLUS Gold Certification
August 9, 201313 yr Newegg shell shocker deal $69.99 plus an additional $20 rebate plus free shipping. Today 8-9-13 only. SeaSonic M12II 750 SS-750AM 750W ATX12V / EPS12V SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Semi-modular Power Supply New 4th Gen CPU Certified Haswell Ready I am not sure if this is a single 12vdc rail or not. http://www.newegg.com/Special/ShellShocker.aspx?cm_sp=ShellShocker-_-17-151-107-_-08092013_2
October 26, 201312 yr CORSAIR CX series CX430 430W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply $18.99 after $20.00 rebate card w/FS. Ends 10/27.
January 6, 201412 yr CORSAIR HX series HX650 650W ATX12V v2.2 / EPS12V 2.91 SLI Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply 89.99 after $20.00 Rebate. Through 1/8/14 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139012
January 22, 201412 yr Newegg Mystery Deal 24 hours only http://www.newegg.com/Product/Product.aspx?Item=17-139-051&nm_mc=EMC-GD012214&cm_mmc=EMC-GD012214-_-index-_-Item-_-17-139-051 CORSAIR CXM series CX750M 750W ATX12V v2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply New 4th Gen CPU Certified Haswell Ready + $10 off w/ promo code EMCYTZT5494, ends 1/22 $59.99 With Promo Code: EMCYTZT5494 After $20 MIR with Free Shipping!
January 22, 201412 yr Just remember ... the CX series is Corsair's "bargain basement low-end" power supply. If it works for your system, it's okay ... but I've seen several systems that aren't stable with a CX that work fine with their TX and HX series. I simply don't use the CX series units -- if I'm buying Corsair I only get HX or TX series units.
April 11, 201412 yr This seemed like a good deal to me based on prices of other PSUs and previous posts. CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply New 4th Gen CPU Certified Haswell Ready http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010 $129 -$20 instant -$20 MIR = $89 w/ MIR, $110 w/o Expires 4/14
April 11, 201412 yr That is indeed a VERY good price for a modular HX series !! Just ordered one as a spare PSU ... I'm sure I'll find a use for it "one of these days"
May 6, 201412 yr SeaSonic G-750 SSR-750RM 750W ATX12V / EPS12V 80 PLUS GOLD Certified Modular Active PFC Power Supply $79.99 w/FS WITH PROMO CODE EMCPEPC43 after $20 rebate.
May 29, 201412 yr CORSAIR CX series CX430 430W ATX12V v2.3 80 PLUS BRONZE http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026&cm_re=cx430-_-17-139-026-_-Product expires on 6-4-2014
May 29, 201412 yr CORSAIR CX series CX430 430W ATX12V v2.3 80 PLUS BRONZE http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026&cm_re=cx430-_-17-139-026-_-Product expires on 6-4-2014 I use the CX500 without issues, but many here recommend avoiding the CX line for server use. They're really cheap for a reason.
June 1, 201412 yr They're really cheap for a reason. True. They DO work; but I've seen many systems that had issues with them, but work perfectly with any of the higher-end Corsair units or other good PSUs. Cheapest is not what you want when you want a rock-solid reliable system.
March 30, 20179 yr Just saw this on Slick Deals. http://www.bestbuy.com/site/evga-80-plus-600w-atx-12v-eps-12v-power-supply-black/8511029.p?loc=0&ref=8575135&acampID=7acb5484156011e783703e62206ab9820INT Edited March 30, 20179 yr by shanelovell It did not post screen shot
September 27, 20188 yr If you are looking for super budget or spare parts: EVGA B-stock. comes with 1 year warranty, and every wednesday, the prices are even cheaper!https://www.evga.com/products/productlist.aspx?type=8
February 24, 20215 yr Flex ATX - Silverstone SST-FX350-G 80-Plus Gold, 350W $85.77 at time of posting. Seems reasonable to me, bought it & happy with it so far. It is smaller (less deep) than most 1U / Flex ATX PSUs out there. https://www.amazon.com/gp/product/B07QGMX5DW
December 9, 20223 yr This link has in-depth suggestions for PSU including quality ratings of specific variants/years and any comments of failures reported by people. I originally saw this on LTT forums and seems they have move it to their own website. Highly recommend you check this out when buying a PSU. https://cultists.network/140/psu-tier-list/
