Unraid crashes with "Stop running nchan processes" - WebGUI not reachable
Solved by Fabske
Another crash in 2 weeks, what am I supposed to do?
On 11/4/2025 at 2:01 AM, bmartino1 said:
If you guys see this again, can you post the output of
ls -ail /usr/local/emhttp/plugins/dynamix/scripts
during the crash I have following output:
@Squid please advise!
Edited by Joloxx9
That looks like an incomplete list. The "total 12" line suggest there should be more shown.
I can asure you that was all what was listed, it was barely usable.
Had another ceash this morning at this time nothing was in CLI, couldn't even log in through it so had to do another hard restart. This is getting to the point where system is being unusable for me as server
@itimpi
This is end of the log right before the crash:
4 hours ago, Joloxx9 said:
@itimpi
that log end just means dockers were shutting down.
this puts veth and other docker created interfaces in a disabled and removed from host state.
so to me this looks like part of a host shutdown and the removable of a usb device. Most likely the keyboard at the terminal.
Please post a diag and make a bug report...
I've posted a bug report. Was told to do syslog and what, once it crashes syslog doesn't record anything it just stops.
You are saying that something disconencted, well I have only 2 things plugged in, UPS and Unraid, UPS is plugged to another controller, 1.10.1 is the one where my unraid is plugged, so not sure what is happening here.
Jumping in on this. Unraid 7.2.2, have tried all of the potential fixes presented previously. Enabled syslog copy to USB, found same symptoms as presented previously (inability to stay logged in via console, web UI non-responsive while some containers are responsive, disabling VPN, server not responding to ACPI calls).
Visible from login prompt (console)
crond[2360] exit status 1 from user root /usr/local/emhttp/plugins/dynamix/scripts/monitor &> /dev/null
crond[2360] exit status 1 from user root /usr/bin/run-parts /etc/cron.hourly 1> /dev/nulll
Unable to present diagnostics, as server needs to be rebooted to become usable again. The best I have are these following syslog entries:
Dec 1 20:36:42 tower rc.rsyslogd: Syslog server daemon... Started.
Dec 1 20:36:43 tower rsyslogd: [origin software="rsyslogd" swVersion="8.2102.0" x-pid="88242" x-info="https://www.rsyslog.com"] start
Dec 1 20:37:02 tower ool www[78640]: /usr/local/emhttp/plugins/dynamix/scripts/rsyslog_config
Dec 1 20:37:02 tower rc.rsyslogd: Restarting Syslog server daemon...
Dec 1 20:37:02 tower rc.rsyslogd: Stopping Syslog server daemon...
Dec 1 20:37:03 tower rc.rsyslogd: killall --ns 88875 rsyslogd
Dec 1 20:37:06 tower rc.rsyslogd: Syslog server daemon... Started.
Dec 1 20:37:07 tower rsyslogd: [origin software="rsyslogd" swVersion="8.2102.0" x-pid="88963" x-info="https://www.rsyslog.com"] start
Dec 1 21:55:47 tower webgui: Successful login user root from 192.168.1.226
Dec 1 21:55:59 tower webgui: CaddyV2: Could not download icon https://d1q6f0aelx0por.cloudfront.net/product-logos/library-caddy-logo.png
Dec 1 21:57:18 tower ool www[186718]: Successful logout user root from 192.168.1.226
Dec 1 22:02:25 tower webgui: Successful login user root from 192.168.1.226
Dec 1 22:02:32 tower webgui: CaddyV2: Could not download icon https://d1q6f0aelx0por.cloudfront.net/product-logos/library-caddy-logo.png
Dec 1 22:02:55 tower ool www[194847]: Successful logout user root from 192.168.1.226
Dec 2 01:24:27 tower monitor_nchan: Stop running nchan processes
All instances of the web UI were logged out and closed.
its is best to make your own general post... posting diag and other... IDK what you guys are doing to get the monitor script to go off the walls like this...
This is pretty much a fresh installation of Unraid 7.2.2 - no upgrades and very few plugins/containers/etc. Diag from server ~30 minutes after forced reboot.
blockbuster2.0-diagnostics-20251202-2054.zip
Edited by kaleb112494
thank you for a diaga. not seeing much. looks like there some issues going on with unriad hype v system...
graphql-api.txt gettign constant failure with libvirt...
which is a little weird...
[02:12:04 INFO api]: Server listening on /var/run/unraid-api.sock {"apiVersion":"4.27.2+375dcd05","logger":"api"}
[02:12:04 INFO api]: Nest Server is now listening {"apiVersion":"4.27.2+375dcd05","logger":"api"}
[02:12:14 INFO VmsService]: Attempting to initialize VMs service...attempt 1/12 {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:14 WARN VmsService]: Initial hypervisor connection failed: Libvirt is not running. Setting up watcher. {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:24 INFO VmsService]: Attempting to initialize VMs service...attempt 2/12 {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:24 WARN VmsService]: Initial hypervisor connection failed: Libvirt is not running. Setting up watcher. {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:34 INFO VmsService]: Attempting to initialize VMs service...attempt 3/12 {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:34 WARN VmsService]: Initial hypervisor connection failed: Libvirt is not running. Setting up watcher. {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:44 INFO VmsService]: Attempting to initialize VMs service...attempt 4/12 {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:44 WARN VmsService]: Initial hypervisor connection failed: Libvirt is not running. Setting up watcher. {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:54 INFO VmsService]: Attempting to initialize VMs service...attempt 5/12 {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:54 WARN VmsService]: Initial hypervisor connection failed: Libvirt is not running. Setting up watcher. {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:04 INFO VmsService]: Attempting to initialize VMs service...attempt 6/12 {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:04 WARN VmsService]: Initial hypervisor connection failed: Libvirt is not running. Setting up watcher. {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:14 INFO VmsService]: Attempting to initialize VMs service...attempt 7/12 {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:24 INFO VmsService]: Attempting to initialize VMs service...attempt 8/12 {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:34 INFO VmsService]: Attempting to initialize VMs service...attempt 9/12 {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:44 INFO VmsService]: Attempting to initialize VMs service...attempt 10/12 {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:54 INFO VmsService]: Attempting to initialize VMs service...attempt 11/12 {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:04 INFO VmsService]: Attempting to initialize VMs service...attempt 12/12 {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"VmsService"}
[02:12:02 INFO app]: Exiting with signal 130 {"apiVersion":"4.27.2+375dcd05"}
[02:12:02 INFO UnraidFileModificationService]: Rolling back all modifications... {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"UnraidFileModificationService"}
[02:12:02 INFO RCloneApiService]: RClone process not running or already stopped. {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"RCloneApiService"}
[02:12:02 INFO RCloneApiService]: RCloneApiService module destroyed {"apiVersion":"4.27.2+375dcd05","logger":"api","context":"RCloneApiService"}
[02:12:05 INFO app]: ENV {"API_VERSION":"4.27.2+375dcd05","BYPASS_CORS_CHECKS":false,"BYPASS_PERMISSION_CHECKS":false,"CHOKIDAR_USEPOLLING":false,"DEBUG":false,"ECOSYSTEM_PATH":"/usr/local/unraid-
I'm not seing any vms or the VM sytem enabled...
I do see yor using ?bond? on a realtek driver for your eht0 nic...
standar plugin no cmd, or 3rd party appl;icaiton... singale cache disk pool per diag...
still combing thoguh the logs and diag... but not seeing anything abnoraml atm.
?Is this Unriad instace on baremetal aor virtualized?
Correct on all fronts so far. This is bare metal, was previously a Windows system until I convinced the owner to try Unraid out. Unfortunately, I feel that this has left a sour taste in his mouth.
Found this in /var/log/nginx/error.log just a moment ago
root@BlockBuster2:~# cat /var/log/nginx/error.log
2025/12/02 18:04:43 [info] 9694#9694: Using 116KiB of shared memory for nchan in /etc/nginx/nginx.conf:162
2025/12/02 18:04:43 [info] 9694#9694: Using 262144KiB of shared memory for nchan in /etc/nginx/nginx.conf:162
2025/12/02 18:10:45 [alert] 34899#34899: *309 open socket #20 left in connection 258
2025/12/02 18:10:45 [alert] 34899#34899: *317 open socket #29 left in connection 268
2025/12/02 18:10:45 [alert] 34899#34899: *336 open socket #38 left in connection 269
2025/12/02 18:10:45 [alert] 34899#34899: *361 open socket #34 left in connection 271
2025/12/02 18:10:45 [alert] 34899#34899: *321 open socket #30 left in connection 272
2025/12/02 18:10:45 [alert] 34899#34899: aborting
2025/12/02 18:10:46 [emerg] 37618#37618: "nchan_max_reserved_memory" directive is duplicate in /etc/nginx/nginx.conf:51
2025/12/02 18:21:01 [alert] 38228#38228: *1 open socket #3 left in connection 7
2025/12/02 18:21:01 [alert] 38228#38228: *17 open socket #19 left in connection 9
2025/12/02 18:21:01 [alert] 38228#38228: *15 open socket #21 left in connection 11
2025/12/02 18:21:01 [alert] 38228#38228: *9 open socket #22 left in connection 12
2025/12/02 18:21:01 [alert] 38228#38228: *11 open socket #23 left in connection 13
2025/12/02 18:21:01 [alert] 38228#38228: *13 open socket #24 left in connection 14
2025/12/02 18:21:01 [alert] 38228#38228: *1806 open socket #38 left in connection 20
2025/12/02 18:21:01 [alert] 38228#38228: *1788 open socket #30 left in connection 23
2025/12/02 18:21:01 [alert] 38228#38228: aborting
ker process: ./nchan-1.3.7/src/store/spool.c:479: spool_fetch_msg: Assertion `spool->msg_status == MSG_INVALID' failed.
2025/12/02 18:21:03 [alert] 83383#83383: worker process 83384 exited on signal 6
2025/12/02 18:21:39 [alert] 83518#83518: *90 open socket #38 left in connection 21
2025/12/02 18:21:39 [alert] 83518#83518: *62 open socket #21 left in connection 24
2025/12/02 18:21:39 [alert] 83518#83518: *94 open socket #39 left in connection 26
2025/12/02 18:21:39 [alert] 83518#83518: *83 open socket #40 left in connection 27
2025/12/02 18:21:39 [alert] 83518#83518: *92 open socket #41 left in connection 28
2025/12/02 18:21:39 [alert] 83518#83518: *135 open socket #36 left in connection 29
2025/12/02 18:21:39 [alert] 83518#83518: aborting
2025/12/02 18:22:52 [alert] 86436#86436: *6 open socket #18 left in connection 8
2025/12/02 18:22:52 [alert] 86436#86436: *4 open socket #19 left in connection 9
2025/12/02 18:22:52 [alert] 86436#86436: *8 open socket #20 left in connection 10
2025/12/02 18:22:52 [alert] 86436#86436: *10 open socket #21 left in connection 11
2025/12/02 18:22:52 [alert] 86436#86436: *12 open socket #22 left in connection 12
2025/12/02 18:22:52 [alert] 86436#86436: *14 open socket #23 left in connection 13
2025/12/02 18:22:52 [alert] 86436#86436: *178 open socket #30 left in connection 16
2025/12/02 18:22:52 [alert] 86436#86436: *203 open socket #33 left in connection 28
2025/12/02 18:22:52 [alert] 86436#86436: aborting
2025/12/02 18:23:31 [alert] 87725#87725: *1 open socket #3 left in connection 7
2025/12/02 18:23:31 [alert] 87725#87725: *3 open socket #18 left in connection 8
2025/12/02 18:23:31 [alert] 87725#87725: *5 open socket #19 left in connection 9
2025/12/02 18:23:31 [alert] 87725#87725: *7 open socket #20 left in connection 10
2025/12/02 18:23:31 [alert] 87725#87725: *9 open socket #21 left in connection 11
2025/12/02 18:23:31 [alert] 87725#87725: *11 open socket #22 left in connection 12
2025/12/02 18:23:31 [alert] 87725#87725: *21 open socket #24 left in connection 14
2025/12/02 18:23:31 [alert] 87725#87725: *42 open socket #34 left in connection 24
2025/12/02 18:23:31 [alert] 87725#87725: aborting
2025/12/02 18:23:33 [alert] 88744#88744: worker process 88745 exited on signal 6
2025/12/02 18:23:35 [alert] 88744#88744: worker process 88822 exited on signal 6
2025/12/02 18:24:11 [alert] 88968#88968: *32 open socket #21 left in connection 8
2025/12/02 18:24:11 [alert] 88968#88968: *34 open socket #22 left in connection 9
2025/12/02 18:24:11 [alert] 88968#88968: *50 open socket #27 left in connection 14
2025/12/02 18:24:11 [alert] 88968#88968: *44 open socket #28 left in connection 15
2025/12/02 18:24:11 [alert] 88968#88968: *46 open socket #29 left in connection 16
2025/12/02 18:24:11 [alert] 88968#88968: *48 open socket #30 left in connection 17
2025/12/02 18:24:11 [alert] 88968#88968: *52 open socket #31 left in connection 18
2025/12/02 18:24:11 [alert] 88968#88968: *54 open socket #32 left in connection 19
2025/12/02 18:24:11 [alert] 88968#88968: aborting
2025/12/02 18:24:13 [alert] 90495#90495: worker process 90496 exited on signal 6
2025/12/02 18:24:15 [alert] 90495#90495: worker process 90534 exited on signal 6
2025/12/02 18:25:48 [alert] 90733#90733: *177 open socket #21 left in connection 9
2025/12/02 18:25:48 [alert] 90733#90733: *38 open socket #26 left in connection 13
2025/12/02 18:25:48 [alert] 90733#90733: *40 open socket #27 left in connection 14
2025/12/02 18:25:48 [alert] 90733#90733: *42 open socket #28 left in connection 15
2025/12/02 18:25:48 [alert] 90733#90733: *46 open socket #30 left in connection 17
2025/12/02 18:25:48 [alert] 90733#90733: *49 open socket #31 left in connection 18
2025/12/02 18:25:48 [alert] 90733#90733: aborting
2025/12/02 18:25:49 [alert] 94566#94566: worker process 94567 exited on signal 6
2025/12/02 18:25:51 [alert] 94566#94566: worker process 94612 exited on signal 6
2025/12/02 18:26:22 [alert] 94789#94789: *24 open socket #5 left in connection 7
2025/12/02 18:26:22 [alert] 94789#94789: *29 open socket #22 left in connection 9
2025/12/02 18:26:22 [alert] 94789#94789: *41 open socket #28 left in connection 15
2025/12/02 18:26:22 [alert] 94789#94789: *43 open socket #29 left in connection 16
2025/12/02 18:26:22 [alert] 94789#94789: *45 open socket #30 left in connection 17
2025/12/02 18:26:22 [alert] 94789#94789: *47 open socket #31 left in connection 18
2025/12/02 18:26:22 [alert] 94789#94789: aborting
2025/12/02 18:26:24 [alert] 96348#96348: worker process 96349 exited on signal 6
2025/12/02 18:26:26 [alert] 96348#96348: worker process 96418 exited on signal 6
2025/12/02 18:47:08 [alert] 96633#96633: *2232 open socket #5 left in connection 27
2025/12/02 18:47:08 [alert] 96633#96633: aborting
I do have two Web UI tabs open currently - one on his network, and one on my workstation from home. I am accessing it from a domain that is reverse proxied via a caddy container on this same Unraid system.
per sytem log your experiencing ntp time server error adn soemthing comand wise stoped teh nginx server adn caused a reboot loop...
Dec 2 18:08:51 BlockBuster2 rc.nginx: Stopping Nginx server daemon gracefully...
Dec 2 18:09:40 BlockBuster2 sshd-session[34507]: Connection from 192.168.1.226 port 53807 on 192.168.1.69 port 22 rdomain ""
Dec 2 18:09:41 BlockBuster2 sshd-session[34507]: Postponed keyboard-interactive for root from 192.168.1.226 port 53807 ssh2 [preauth]
Dec 2 18:09:48 BlockBuster2 sshd-session[34507]: Postponed keyboard-interactive/pam for root from 192.168.1.226 port 53807 ssh2 [preauth]
Dec 2 18:09:48 BlockBuster2 sshd-session[34507]: Accepted keyboard-interactive/pam for root from 192.168.1.226 port 53807 ssh2
Dec 2 18:09:48 BlockBuster2 sshd-session[34507]: pam_unix(sshd:session): session opened for user root(uid=0) by (uid=0)
Dec 2 18:09:48 BlockBuster2 sshd-session[34507]: User child is on pid 34600
Dec 2 18:09:48 BlockBuster2 sshd-session[34600]: Starting session: shell on pts/0 for root from 192.168.1.226 port 53807 id 0
Dec 2 18:10:04 BlockBuster2 rc.nginx: Stopping Nginx server daemon gracefully...
Dec 2 18:10:04 BlockBuster2 rc.nginx: Nginx server daemon... Already stopped.
Dec 2 18:10:04 BlockBuster2 rc.nginx: Starting Nginx server daemon...
Dec 2 18:10:08 BlockBuster2 rc.nginx: Nginx server daemon... Started.
Dec 2 18:10:33 BlockBuster2 ntpd[2339]: kernel reports TIME_ERROR: 0x41: Clock Unsynchronized
Dec 2 18:10:44 BlockBuster2 rc.nginx: Stopping Nginx server daemon gracefully...
Dec 2 18:10:45 BlockBuster2 nginx: 2025/12/02 18:10:45 [alert] 34899#34899: *309 open socket #20 left in connection 258
Dec 2 18:10:45 BlockBuster2 nginx: 2025/12/02 18:10:45 [alert] 34899#34899: *317 open socket #29 left in connection 268
Dec 2 18:10:45 BlockBuster2 nginx: 2025/12/02 18:10:45 [alert] 34899#34899: *336 open socket #38 left in connection 269
Dec 2 18:10:45 BlockBuster2 nginx: 2025/12/02 18:10:45 [alert] 34899#34899: *361 open socket #34 left in connection 271
Dec 2 18:10:45 BlockBuster2 nginx: 2025/12/02 18:10:45 [alert] 34899#34899: *321 open socket #30 left in connection 272
Dec 2 18:10:45 BlockBuster2 nginx: 2025/12/02 18:10:45 [alert] 34899#34899: aborting
Dec 2 18:10:46 BlockBuster2 rc.nginx: Nginx server daemon... Stopped.
Dec 2 18:10:46 BlockBuster2 rc.nginx: Starting Nginx server daemon...
Dec 2 18:10:50 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: notify
Dec 2 18:10:50 BlockBuster2 publish: curl to notify failed
Dec 2 18:10:50 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: session
Dec 2 18:10:50 BlockBuster2 publish: curl to session failed
Dec 2 18:10:50 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: temperature
Dec 2 18:10:50 BlockBuster2 publish: curl to temperature failed
Dec 2 18:10:50 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: devices
Dec 2 18:10:50 BlockBuster2 publish: curl to devices failed
Dec 2 18:10:50 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: arraymonitor
Dec 2 18:10:50 BlockBuster2 publish: curl to arraymonitor failed
Dec 2 18:10:50 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: mainPingListener
Dec 2 18:10:50 BlockBuster2 publish: curl to mainPingListener failed
Dec 2 18:10:50 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: parity
Dec 2 18:10:50 BlockBuster2 publish: curl to parity failed
Dec 2 18:10:50 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: paritymonitor
Dec 2 18:10:50 BlockBuster2 publish: curl to paritymonitor failed
Dec 2 18:10:50 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: fsState
Dec 2 18:10:50 BlockBuster2 publish: curl to fsState failed
Dec 2 18:10:50 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: mymonitor
Dec 2 18:10:50 BlockBuster2 publish: curl to mymonitor failed
Dec 2 18:10:50 BlockBuster2 rc.nginx: Nginx server daemon... Failed.
Dec 2 18:10:51 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: devices
Dec 2 18:10:51 BlockBuster2 publish: curl to devices failed
Dec 2 18:10:51 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: arraymonitor
Dec 2 18:10:51 BlockBuster2 publish: curl to arraymonitor failed
Dec 2 18:10:51 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: mainPingListener
Dec 2 18:10:51 BlockBuster2 publish: curl to mainPingListener failed
Dec 2 18:10:52 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: devices
Dec 2 18:10:52 BlockBuster2 publish: curl to devices failed
Dec 2 18:10:52 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: arraymonitor
Dec 2 18:10:52 BlockBuster2 publish: curl to arraymonitor failed
Dec 2 18:10:52 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: mainPingListener
Dec 2 18:10:52 BlockBuster2 publish: curl to mainPingListener failed
Dec 2 18:10:53 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: devices
Dec 2 18:10:53 BlockBuster2 publish: curl to devices failed
Dec 2 18:10:53 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: arraymonitor
Dec 2 18:10:53 BlockBuster2 publish: curl to arraymonitor failed
Dec 2 18:10:53 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: mainPingListener
Dec 2 18:10:53 BlockBuster2 publish: curl to mainPingListener failed
Dec 2 18:10:53 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: parity
Dec 2 18:10:53 BlockBuster2 publish: curl to parity failed
Dec 2 18:10:53 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: paritymonitor
Dec 2 18:10:53 BlockBuster2 publish: curl to paritymonitor failed
Dec 2 18:10:53 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: fsState
Dec 2 18:10:53 BlockBuster2 publish: curl to fsState failed
Dec 2 18:10:53 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: mymonitor
Dec 2 18:10:53 BlockBuster2 publish: curl to mymonitor failed
Dec 2 18:10:54 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: devices
Dec 2 18:10:54 BlockBuster2 publish: curl to devices failed
Dec 2 18:10:54 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: arraymonitor
Dec 2 18:10:54 BlockBuster2 publish: curl to arraymonitor failed
Dec 2 18:10:54 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: mainPingListener
Dec 2 18:10:54 BlockBuster2 publish: curl to mainPingListener failed
Dec 2 18:10:55 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: temperature
Dec 2 18:10:55 BlockBuster2 publish: curl to temperature failed
Dec 2 18:10:55 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: devices
Dec 2 18:10:55 BlockBuster2 publish: curl to devices failed
Dec 2 18:10:55 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: arraymonitor
Dec 2 18:10:55 BlockBuster2 publish: curl to arraymonitor failed
Dec 2 18:10:55 BlockBuster2 webgui: curl error: Failed to connect to localhost port 80 after 0 ms: Could not connect to server endpoint: mainPingListener
Dec 2 18:10:55 BlockBuster2 publish: curl to mainPingListener failed
Dec 2 18:11:13 BlockBuster2 rc.nginx: Stopping Nginx server daemon gracefully...
Dec 2 18:11:13 BlockBuster2 rc.nginx: Nginx server daemon... Already stopped.
Dec 2 18:11:13 BlockBuster2 rc.nginx: Starting Nginx server daemon...
Dec 2 18:11:17 BlockBuster2 rc.nginx: Nginx server daemon... Started.
Dec 2 18:13:43 BlockBuster2 webgui: Successful login user root from 192.168.1.226
Dec 2 18:14:20 BlockBuster2 webgui: CaddyV2: Could not download icon https://d1q6f0aelx0por.cloudfront.net/product-logos/library-caddy-logo.png
IO would suspect a issue inteh bond and potenal need to install teh net driver plugin for realek devices.
NTP failed earlier int he boot before your first web ui and ssh login to the system. The sytem is not mainting a stable netowrk conection per the log and evental fails.
Installed the Realtek RTL8111 plugin from CA as suggested, and set upstream router as NTP sync. Will update around this time tomorrow. Thanks for helping to take a look @bmartino1
