article: Running OSX Mavericks under KVM with QEMM
My xml is as follows
<domain type='kvm' xmlns:qemu='http://libvirt.org/schemas/domain/qemu/1.0'>
  <name>OSX-Yosemite-10.10</name>
  <uuid>0ba39646-7ba1-4d41-9602-e2969a3fc26d</uuid>
  <metadata>
    <type>None</type>
  </metadata>
  <memory unit='KiB'>4194304</memory>
  <currentMemory unit='KiB'>4194304</currentMemory>
  <vcpu placement='static'>2</vcpu>
  <resource>
  </resource>
  <os>
    <type arch='x86_64' machine='pc-q35-2.1'>hvm</type>
    <kernel>/mnt/disk1/vm_images/extra/chameleon_svn2549_boot</kernel>
    <boot dev='cdrom'/>
    <bootmenu enable='yes'/>
  </os>
  <features>
    <acpi/>
  </features>
  <cpu mode='custom' match='exact'>
    <model fallback='allow'>core2duo</model>
  </cpu>
  <clock offset='utc'/>
  <on_crash>destroy</on_crash>
  <devices>
    <emulator>/usr/bin/qemu-system-x86_64</emulator>
      <driver name='qemu' type='qcow2'/>
      <source file='/mnt/disk1/vm_images/Yosemite.qcow2'/>
      <target dev='hda' bus='ide'/>
    </disk>
    <controller type='usb' index='0'>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x01' function='0x0'/>
    </controller>
    <controller type='ide' index='0'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
    </controller>
    <controller type='pci' index='0' model='pcie-root'/>
    <controller type='pci' index='1' model='dmi-to-pci-bridge'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1e' function='0x0'/>
    </controller>
    <controller type='pci' index='2' model='pci-bridge'>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x01' function='0x0'/>
    </controller>
    <interface type='bridge'>
      <mac address='52:54:00:00:20:20'/>
      <source bridge='br0'/>
      <model type='e1000-82545em'/>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x03' function='0x0'/>
    </interface>
    <graphics type='vnc' port='-1' autoport='yes' websocket='-1' listen='0.0.0.0'>
    </graphics>
    <video>
      <model type='vga' vram='9216' heads='1'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0'/>
    </video>
    <memballoon model='virtio'>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x02' function='0x0'/>
    </memballoon>
  </devices>
  <seclabel type='none' model='none'/>
  <qemu:commandline>
    <qemu:arg value='-device'/>
    <qemu:arg value='ioh3420,bus=pcie.0,addr=1c.0,multifunction=on,port=1,chassis=1,id=root.1'/>
    <qemu:arg value='vfio-pci,host=01:00.0,bus=root.1,addr=00.0,multifunction=on,x-vga=on'/>
    <qemu:arg value='vfio-pci,host=01:00.1,bus=pcie.0'/>
    <qemu:arg value='usb-kbd'/>
    <qemu:arg value='usb-mouse'/>
    <qemu:arg value='isa-applesmc,osk=64_Character_OSK_Key'/>
    <qemu:arg value='-smbios'/>
    <qemu:arg value='type=2'/>
    <qemu:arg value='ide-drive,bus=ide.1,drive=MacDVD'/>
    <qemu:arg value='-drive'/>
    <qemu:arg value='id=MacDVD,if=none,snapshot=on,file=/mnt/disk1/vm_images/installer/Yosemite.iso'/>
  </qemu:commandline>
</domain>
  • Replies 128
  • Views 42.2k
It's the product key for OSX that you can only get from Mac hardware. Follow his instructions to locate.
ok will try to digest. From what i understand, run his script on a linux os installed on mac hardware ? Is that right ?
Correct, you run the script on a MAC, when I first downloaded the script it would not run as I was on a Snow Leopard.
When I upgraded to Yosemite it worked fine. I was stumped on this one for a few days.
When the key revealed I could kick myself...... :-)
thx for clarfication will attempt later
If anyone has any tips on how to get this running on an AMD CPU I'm all ears.
I gave up and went with the hackintosh build using yosemite-zone.
  • 2 months later...
Superb guide! I can get everything going, but my VM hangs on the Apple Logo screen when booting for the first time. Any ideas? I'm running OSX Yosemite. I can post my XML:
<domain type='kvm' id='11' xmlns:qemu='http://libvirt.org/schemas/domain/qemu/1.0'>
  <name>OSX-Yosemite</name>
  <metadata>
    <type>None</type>
  </metadata>
  <resource>
  </resource>
  <os>
    <type arch='x86_64' machine='pc-q35-2.2'>hvm</type>
    <kernel>/mnt/extra/vm_tools/chameleon_svn2510_boot</kernel>
    <boot dev='hd'/>
  </os>
  <features>
    <acpi/>
  </features>
  </cpu>
  <devices>
      <source file='/mnt/extra/vms/Yosemite/Yosemite.qcow2'/>
      <backingStore/>
      <alias name='ide0-0-0'/>
    </disk>
      <alias name='usb0'/>
    </controller>
      <alias name='ide0'/>
    </controller>
      <alias name='sata0'/>
    </controller>
    <controller type='pci' index='0' model='pcie-root'>
      <alias name='pcie.0'/>
    </controller>
      <alias name='pci.1'/>
    </controller>
      <alias name='pci.2'/>
    </controller>
      <target dev='vnet1'/>
      <alias name='net0'/>
    </interface>
    <graphics type='vnc' port='5901' autoport='yes' websocket='5701' listen='0.0.0.0'>
    </graphics>
    <video>
      <model type='vga' vram='16384' heads='1'/>
      <alias name='video0'/>
    </video>
      <alias name='balloon0'/>
    </memballoon>
  </devices>
  <qemu:commandline>
    <qemu:arg value='isa-applesmc,osk=shhhhh '/>
    <qemu:arg value='id=MacDVD,if=none,snapshot=on,file=/mnt/extra/vm_tools/Yosemite.iso'/>
  </qemu:commandline>
</domain>
Nope not sure, however at the chameloan boot screen type "-v" for verbose and post the last few lines when it gets stuck.
I have my OS X machine up and running since months now (mainly as iTunes server) and I have to say: awesome!!!
I', shutting down the server each night. The Powerdown script is doing this very well by just pressing the power button (..that is something my wife is also capable to do  ;D )
However, the "normal" shutdown procedure (the usage of the "S" script if I'm not mistaken) of the Powerdown isn't working for the OS X VM. How are you guy's deal with OS X KVM shutdown before shutting down the whole server?
I'm fairly certain that when unRAID shutdowns or reboots that it force shuts down the OS X VM. The old VM plugin used to at least bring a prompt to my Mac screen asking to shutdown but the new VM plugin built into beta15 doesn't even tell me anything is about to shutdown. I am not sure how to get the VM plugin to play nice with OS X like it does with my windows and linux VMs. For now, if I am planning on restarting the server to just go over to my OS X desktop and manually shut it down first.
  <metadata>
    <type>None</type>
  </metadata>
  <resource>
  </resource>
  <os>
    <boot dev='hd'/>
  </os>
  <features>
    <acpi/>
  </features>
  </cpu>
  <devices>
      <backingStore/>
    </disk>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </interface>
    </graphics>
    <video>
    </video>
    </memballoon>
  </devices>
  <qemu:commandline>
  </qemu:commandline>
</domain>
From your signature I can see you are using AMD hardware. I'm not sure if you can operate an  OSX guest VM when the host CPU is AMD as the install checks for an intel CPU and will freeze up when it doesn't find one (your experience). I see you are specifying Core2Duo in the XML but I don't think that works in terms of tricking the OSX install into thinking it is on an Intel machine.
If anyone else knows how to set the XML to do this I would love to know (I had the same thing happen).
Alright, so I didn't missed anything....that what you described is pretty much the same that I'm doing each day when I'm shutting down unRAID. Thanks for your confirmation archedraft.
Would you both try adding this to see if you can get your AMD's to work: (<vendor>Intel</vendor>)
    <topology sockets='1' cores='2' threads='1'/>
  </cpu>
  </cpu>
That is pretty much where I was at. I didn't have the topology in there so I added that. Here is the error output from virsh.
virsh # start OSX-Yosemite-10.10
error: Failed to start domain OSX-Yosemite-10.10
error: unsupported configuration: guest and host CPU are not compatible: host CPU vendor does not match required CPU vendor Intel
For some reason the VM still sees AMD hardware or maybe its just a qemu/kvm error. Can this be bypassed? Without <vendor>Intel</vendor> it will start but it freezes up when it checks the processor. Any other things to try?
My xml.
  <metadata>
    <type>None</type>
  </metadata>
  <resource>
  </resource>
  <os>
    <kernel>/mnt/disk/vmdisk/Images/extras/chameleon_svn2510_boot</kernel>
    <boot dev='cdrom'/>
  </os>
  <features>
    <acpi/>
  </features>
  </cpu>
  <devices>
      <source file='/mnt/disk/vmdisk/Image Media/Yosemite.qcow2'/>
    </disk>
    </controller>
    </controller>
    </controller>
    </controller>
    </interface>
    </graphics>
    <video>
    </video>
    </memballoon>
  </devices>
  <qemu:commandline>
    <qemu:arg value='isa-applesmc,osk=********'/>
    <qemu:arg value='id=MacDVD,if=none,snapshot=on,file=/mnt/disk/vmdisk/Images/Yosemite.iso'/>
  </qemu:commandline>
</domain>
Try <vendor>GenuineIntel</vendor>
Ok I have changed it to <vendor>GenuineIntel</vendor>
same result unfortunately.
error: unsupported configuration: guest and host CPU are not compatible: host CPU vendor does not match required CPU vendor GenuineIntel
OK how about this:
<vendor name='Intel' string='GenuineIntel'/>
Some progress there. The VM starts and I can VNC into it. The boot screen comes up and if I press enter it goes to a grey screen with logo and freezes. If i type in -v at the boot screen something flashes by very quickly and then it goes to a black screen and freezes up.
opening up the domain XML of the running domain (frozen) shows this for cpu
</features>
  </cpu>
Don't know if that helps
So it wont take the <vendor name='Intel' string='GenuineIntel'/>
It automatically edits that out and that is why the domain starts but leaves us back in the same position.
Same result as Jude.
It eliminates the <vendor>GenuineIntel</vendor> when it starts.
I can't post the -v output because it's just a black screen.
Are you comfortable ssh'ing into unRAID and using the terminal? I have another test but it involves creating a test files with the terminal.
