robertoal Posted May 12, 2016 Share Posted May 12, 2016 Hello again! Made a different topic especially for my Rsync problems. Server 1: Unraid Server 2: OMV Use case: Backup al essential data nightly from the Unraid server to the OMV server. What works: rsync -avz -e ssh [email protected]:/mnt/cache/home / So what is the best way to go about configuring the rest? Unraid is running the rsync daemon, I guess.. So adding a task within OMV should do the trick? Well unfortunately not. I think it has something to do with the SSH certificates, which I generated on both machines. But i have no idea where to put them or how to use it in general. So can anyone point me in the right direction? Thanks in advance! Quote Link to comment
robertoal Posted May 17, 2016 Author Share Posted May 17, 2016 Google is your friend. I used different source to come up with this, please add is you think something has to be different... Before you go ahead with this, it asumes rsync deamons are runnning on both machines, which in the case of unraid and OMV they are. Second, it assumes you set up SSH on unraid. I can;t really remember how I did this though Search for SSH.. If someone knows the steps for enabling SSH please enlighten me. 1. Test Rsync with password: rsync -avz -e ssh /home/localmachine/ [email protected]:/backup/remotemachine/ (NOTE: forwardslash in source means copy al CONTENTS of directory, without the directory itself.) When password is enabled, should ask for it here. 2. ssh-keygen -> when asked for pass just press enter twice 3. The keys are generated now, next step is: ssh-copy-id [email protected] When it asks if you want to continue connecting type yes followed by enter After a second it asks you for the remote server password, give it.. Should say: 'Number of key(s) added: 1" 4. Type: ssh [email protected] followed by enter.. This time it should not ask for a password.. 5. test rsync again: rsync -avz -e ssh /home/localmachine/ [email protected]:/backup/remotemachine/ Should not ask you for a password.. we are getting somewhere :-) 6. Now, you want to run the task every day for example. Cron manages this. Crontab -e uses vi, which i can;t work with (idiot?). So give this command: export VISUAL=nano; crontab -e Should use nano now. Add this line: 10 1 * * * rsync -avz -e ssh /home/localmachine/ [email protected]:/backup/remotemachine/ And it should run 10 past 1 in the night. To make the cron entry's persisten create a .cron file in your plugin folder!: /boot/config/plugins Still to find out: how te make ssh persistant. Will update on this I tested the rsync commands which work fine for me, I did not test if cron will work this night. Will update. Quote Link to comment
robertoal Posted May 19, 2016 Author Share Posted May 19, 2016 Back to the drawing board. After restart... cron jobs deleted, so looks like the command: export VISUAL=nano; crontab -e And adding entry's are NOT persistent, anybody some thoughts about this? After restart I have to copy (via the ssh-copy-id command) the ssh key to autohorty file on OMV as well, any thoughts on this? Thanks again for any help.. Quote Link to comment
JonathanM Posted May 19, 2016 Share Posted May 19, 2016 Back to the drawing board. After restart... cron jobs deleted, so looks like the command: export VISUAL=nano; crontab -e And adding entry's are NOT persistent, anybody some thoughts about this? After restart I have to copy (via the ssh-copy-id command) the ssh key to autohorty file on OMV as well, any thoughts on this? Thanks again for any help.. Unraid is extracted from the archive on the USB drive into RAM every time it is booted. Any file locations not in /boot (flash drive) or /mnt/disk??(plus some other /mnt paths) are in RAM, and changes are lost on reboot. The /mnt location is only fully populated when the array starts, so best practice is to use the /boot locations to store modifications that you wish to make persistent, and script all changes needed so they can be called at boot time. Prior best practice was to use the go file on the usb drive to call those scripts, I'm not sure what the current recommendation is, but limetech is trying to discourage go file modifications, as they can interfere with automatic upgrades. I'd use the go file method for now, but keep in mind you may have to redo things in the future. Quote Link to comment
Squid Posted May 19, 2016 Share Posted May 19, 2016 You can create a new folder within the plugins folder on the flash and toss a file in there called xXxX.cron. dynamix will add the cron entry in there every boot Sent from my LG-D852 using Tapatalk Quote Link to comment
robertoal Posted June 30, 2016 Author Share Posted June 30, 2016 Back again! Putting a cron file into the plugin folder works like a charm.. only thing left is to make the ssh-id persistant.. any thoughts on this? Quote Link to comment
lazydaze Posted February 11, 2020 Share Posted February 11, 2020 Old topic, but has anyone figured out how to make it persistent? Quote Link to comment
