Libvirt Hot Plugin USB - USB Hot Plugin for VMs
The plugin panel says that an update is available for this plugin. Does this mean that support for this plugin is being reinstated?
  • Replies 134
  • Views 49.4k
  • I'm not going to be forking this plugin.  Because it is no longer available within Apps, the messaging the FCP is now changed, with it now being advised to switch to USB Manager.  Similar functionalit
  • For those that are interested, I have found an article here that describes how to set up usb hot plug. https://www.labsrc.com/unraid-automatic-usb-hotplugging-libvirt/#comments   I have
  • I'll have a look.
I've made an update because Unraid is making UI changes. I use this plugin myself because of its simplicity. You are free to use it.
Thank you dlandon for your work. I also use this plugin because of its simplicity and reliability. I was concern about it's compatibility with Unraid since FCP reported it as unknown.
That FCP message is because the plugin is not in CA and FCP warns that it may not be compatible because of that.
Ok, but... why it's not in CA, if I may ask?
It is now.
I wasn't sure if anyone was still interested since the USB Manager can do USB attachments.
Simplicity AND reliability... Thank you, dlandon!
USB Manger once crashed silently on me; in doing so, it removed the BT dongle which I'm passing to my Home Assistant VM, which caused my fridge temperature control to fail, and when I finally got home to correct the issue the thing was already spilling water... such things can happen if a "boring" USB passthrough tool fails 😂
PS: I only switched from your plugin bc of the warning in CA (because, how knows what this means); and immediately switched back after this event...
Edited by t3
I am basically never active in this forum xD
I also saw that this is marked deprecated so I assumed that maybe this was now some sort of function inside the VMs.
Well it was not. I just reinstalled it with the Github link. I too use it for a HAOS VM.
I very much depend on this functionality and at the same time I am sad it is not part of the VM functions by default.
