***GUIDE*** Plex Hardware Acceleration using Intel Quick Sync
I'm having trouble getting hw transcoding to work again after upgrading the version of Plex I am using. For background, I was using a very old version of the Plex app in Unraid as I saw no reason to update, not until recently when it became incompatible with the mobile app.
Before updating, I was able to use hw transcoding all the time including remote plays. Since the update, it hasn't worked once. I even tried titles I know worked before, so I'm a bit baffled.
My server has an Intel 5775C processor with Iris Pro 6200 iGPU. I've made sure the Docker setup is as per the guides and also have checked the right options within the Plex app itself.
Looking at the logs, the only warning I get is "Critical: libusb_init failed".
Any help would be appreciated, as having a working iGPU transcoding was a big win for my setup and use case.
  • Replies 500
  • Views 548.5k
  • You might find this useful (Yes means the iGPU can both encode and decode.):   BTW: this chart is from the Quick Sync Video Wikipedia page.
  • Please be courteous and respectful to one another. Thank you
  • To anyone who is having trouble with the modified go file saving the changes after a system restart, you may be making the same stupid mistake as me. When you edit your go file via the terminal with "
