[Resolved] Problems with apcupsd starting at regular times when disabled.
I was using the built in UPS settings in Unraid, but this was not sufficient for my needs as it didn't support other item on my network, so I installed NUT server on a Raspberry Pi, connected the UPS USB cable to it, added the NUT docker to Unraid and connected it all up to the Pi NUT server while switching the UPS Settings> Start APC UPS daemon to No.
Everything seems to be working with the NUT server, all my devices see it and are set up accordingly, including Unraid. Unfortunately, every week on a Sunday at approx 04:40 I get a notification
apcupsd 3.14.14 (31 May 2016) slackware startup succeeded
Communications with UPS lost
these errors continue to be logged until I manually switch off the daemon Settings>UPS Settings.
When I go to the Settings>UPS Settings tab, the status is showing as running, despite the Start APC UPS daemon showing as no. The way to switch this off is to click the default button which resets it.
FWIW, I have ran cat /etc/cron.d/root and nothing is listed as running around 4am on a weekly basis.
Has anyone else experienced this or can anyone give me an idea on how to apply a correct fix other than setting a cron job a few minutes after the daemon starts to switch it off?
Edited by Boyturtle
On 2/11/2022 at 12:58 PM, JonathanM said:
apcupsd has clients for windows, osx and linux. What other items do you need?
https://sourceforge.net/projects/apcupsd/files/
Thanks for your reply and apologies for not replying sooner nor making my earlier post clearer. My preference is to run the UPS management on a device that sips power (hence the Pi) and my unraid server is much more power hungry. Doing it this way allows me to shut unraid down before other devices on my network.
What I'd like to achieve here is to disable the apcupsd 3.14.14 (31 May 2016) slackware startup, but have no idea how to to stop this. Effectively, I'd like the deamon to revert to how it was before I made the initial changes when adding the UPS. As I stated in my earlier post, there is nothing in cron to indicate that there is anything in place to start at 4:40 every Sunday morning.
Do I need to make changes in unraids /etc/apcupsd/apcupsd.conf file, /etc/rc.d/rc.apcupsd or an altogether different file?
I am seeing this on my machine, I am using NUT but apcupsd seems to start 4.40 each sunday.
That seems to imply it's the weekly schedule.  You sure there's nothing running via user scripts (if installed)
Install Dynamix Schedules and then look at Settings - Schedules - Fixed Schedules or
ls /etc/cron.weekly
ls /etc/cron.weekly
Hi @Squid its not weekly as that is running at 4.30 its daily. Its the log rotate fuction is restarting it.
root@unraid:/usr/sbin# cat /etc/logrotate.d/apcupsd
/var/log/apcupsd.events {
  rotate 4
  weekly
  notifempty
  missingok
  postrotate
    /etc/rc.d/rc.apcupsd restart 1>/dev/null || true
  endscript
Any ideas on how the file is created or is it because I have an enabled its created logs even now I have disabled?
do I just need to delete the apcupsd.events files?
Edited by SimonF
You can run apcupsd on your pi as the host, and connect Unraid as a network client that shuts down when the pi reports an outage.
53 minutes ago, SimonF said:
log rotate fuction
You're correct.  Thanks.
My only weekly scripts are the cleaning up of plex cached files and ClamAV scan, nothing apcupsd related.
Installed Dynamix Schedules, user.script.start.weekly.sh runs at 4.30 on Sunday and exportrotate, logrotate, user.script.start.daily.sh run daily at 4.40.
My output from cat /etc/logrotate.d/apcupsd is the same as @SimonF
  rotate 4
  weekly
  notifempty
  missingok
  postrotate
  endscript
As I'm not using unraid's apcupsd, am I safe to edit /etc/logrotate.d/apcupsd and comment out the line    /etc/rc.d/rc.apcupsd restart 1>/dev/null || true? Should this stop the daemon restarting?
Would this stop the daemon from starting at 4.40 every Sunday?
Not sure I have deleted an will check next Sunday. Tried changing the schedule to run again today didn't seem to do anything so not sure how it tracks weekly.
No errors in the syslogs from 4.40 am and beyond yesterday, after I made the changes described above 😃
  • Boyturtle changed the title to [Resolved] Problems with apcupsd starting at regular times when disabled.
  • 1 year later...
To make changes persistent:
Disable apcupsd by resetting settings to Default in UPS settings
Open the terminal and copy your current logrotate script for apcupsd to your boot flash drive:
mkdir -p /boot/config/custom/ && cp /etc/logrotate.d/apcupsd /boot/config/custom/apcupsd
Open the script you copied on your flash drive using an editor (e.g. nano /boot/config/custom/apcupsd) and remove the following lines:
postrotate
endscript
Mine looks like this after making the changes:
  rotate 4
  weekly
  notifempty
  missingok
Now make sure your /boot/config/go script will overwrite the logrotate.d config with the updated file on boot:
echo "cp /boot/config/custom/apcupsd /etc/logrotate.d/apcupsd" >> /boot/config/go
To test that it works and apply the changes now, copy the file and run the logrotate job:
cp /boot/config/custom/apcupsd /etc/logrotate.d/apcupsd && /etc/cron.daily/logrotate
