Fix to a small issue with updating OCI docker images
So, as of today, the only way to update a docker/plugin (i have way more problems with plugins than dockers), is forcing (can't be done with plugins) update, or sheer luck?
  • Replies 144
  • Views 64.8k
  • HIGHLY recommended to NOT patch your docker files manually and instead use the plugin.  Patching manually means that if / when you update the OS to 6.12 any manually patches that you are applying auto
  • I have included your update for the next Unraid version. Thanks
  • The plugin will not install on 6.12+, so it's a install once, forget about it completely and you're safe going forward
No, should just work, you probably have some connectivity issues. This thread doesn't apply to plugins at all.
Edited by Kilrah
Same problem here on 6.11.5. It's not a problem on the Linuxserver dockers for me, but on the non-linuxserver ones mostly. Connectivity is fine, so no idea why that's pointed to as the issue.
There are multiple common image repositories, for example linuxserver uses their own, dockerhub is common, github is common...
If you can see the failing ones are mostly or mostly not a specific source then that points to the issue being either the service in question or your ability to connect to it.
Also seeing this happen again within the last few days. Still on 6.11.5, had the issue a few weeks ago and applied the patch as described previously in this thread. But about a week ago container versions started sporadically disappearing and becoming "not available" on the ui again. No pattern. Different maintainers on each image and everything. No funky DNS settings or anything either.
Uninstalling and reinstalling the plugin made... some of the update links work again. Some are still showing not available.
Edited by MaxAbsorbency
I have this issue to, seems very random, not available at random times on random dockers.
My uneducated guess is that docker is limiting the amount of requests it takes from a client, and if you have too many dockers and do a check it will flood their system and it will block some of the requests ending up in not available, none of the fixes in this thread solved my issue, it randomly comes up as not available at random dockers at random times.
I cannot use squids patch because i am on an old version, for now i have to live with it.
That was a change implemented a couple years ago
"For anonymous users, the rate limit is set to 100 pulls per 6 hours per IP address."  And an update check qualifies as a pull request.
it works thanks.
  • 5 months later...
I'm having this problem on 6.12.4. Don't know what to do.
I am getting not available on everything
Are the apps from Community Applications.  The question marks for icons however speaks volumes if they are from CA.  It basically means that most likely your server cannot reach the internet properly (Try setting static DNS addresses in Settings - Network settings) or could also be a corrupt docker image
I deploy everything from CA, as I am not a skill docker tech ( I have sys ad skills, just not in docker )  I was orginally having issues with Plex then I restarted the entire unraid system, and everything came up like not available.
I put unraid in an emergency firewall allow with in my firewalla to make sure something ad block wise wasn't blocking any reach out attempts
I am not showing any blocks for unraid at the FW level.
Edited by sstretchh
soon as i stopped docker, set the static IP addresses to the following
1.1.1.1
8.8.8.8
I get the following now
"Docker Service failed to start."
Nothing to do with changing the DNS addresses.
You should post your diagnostics
should i start a new thread ?
Yes since neither have anything to do with this thread's subject.
Is this still required with v6.12.6? I am seeing the issue for many docker containers.
Interesting side-note, if I create a new instance of a container that says "Update not available", the new instance is able to update. Even though the older one still cannot.
No.
Check these container's docs, several maintainers have been changing repos lately e.g. from dockerhub to github.
Edited by Kilrah
I now have two containers that are displaying Not Available on the version. Both containers still appear to be using their previously defined repo too. Anything else that can help resolve this? I am on 6.12.6, so the patch is not an option either.
I just install on my Unraid 6.12.6. When i login i face an error:
Init Problem
There was a problem loading init data:
Unauthorized
The credentials must be right. When modifing username password a bit i will get a error right on the login form.
Instead the dialog with many questions appear and when finish i ll be taken the main page. But the loading does not stop instead i get the error above.
Nothing in the logs at this point.
