trurl Posted January 31 Share Posted January 31 7 minutes ago, Rob_Dingen said: I try to mount the old disk with data on my windows machine And don't do this either. Windows can't do anything good with any of these disks. Quote Link to comment
Rob_Dingen Posted January 31 Author Share Posted January 31 I put the new disk 4 back and it's starting to rebuild. Quote Link to comment
Rob_Dingen Posted January 31 Author Share Posted January 31 (edited) tower-diagnostics-20240131-2059.zip Edited January 31 by Rob_Dingen Quote Link to comment
trurl Posted January 31 Share Posted January 31 56 minutes ago, Rob_Dingen said: I put the new disk 4 back and it's starting to rebuild. We specifically told you to not do this!!! And as you can see from the screenshot, it is rebuilding an unmountable filesystem. Probably because xfs is the wrong filesystem. But maybe, it is actually rebuilding the original reiserfs and only thinks it is unmountable because it is trying to mount it as xfs. ? ? ? You have taken things far away from where they should be, not sure I know what to do now. Hopefully we can still get something from the original disks. DO NOT do anything at all with the original disks! Don't do anything else except what we tell you to do. If you don't understand, ask for further explanation. Quote Link to comment
Rob_Dingen Posted January 31 Author Share Posted January 31 I told before I cannot put the old disk 4 back. I already try to do that but before that the array already started with the new disk. Quote click on disk4, change fs to reiser and post new diags after array start. That was the question but I cannot select reiserfs Quote Link to comment
trurl Posted January 31 Share Posted January 31 1 minute ago, Rob_Dingen said: I told before I cannot put the old disk 4 back. I agree 30 minutes ago, trurl said: DO NOT do anything at all with the original disks! I guess we will wait for rebuild to complete, and see if we can figure out how to tell it to use reiserfs instead of xfs to mount the rebuilt disk. Quote Link to comment
Rob_Dingen Posted January 31 Author Share Posted January 31 If there are no options to restore the old disk's. Then I can download the free version of unraid en mount te old disk I can take the data off and copy it back? Quote Link to comment
Rob_Dingen Posted January 31 Author Share Posted January 31 Can you explain why on disk 5 is 55,8GB used. It's a new disk and I format it and put nothing on, also if I check there is nothing. Thanks for al your help Rob Quote Link to comment
trurl Posted January 31 Share Posted January 31 1 minute ago, Rob_Dingen said: Can you explain why on disk 5 is 55,8GB used. Filesystem overhead. Quote Link to comment
trurl Posted January 31 Share Posted January 31 23 minutes ago, Rob_Dingen said: If there are no options to restore the old disk's. Then I can download the free version of unraid en mount te old disk I can take the data off and copy it back? Shouldn't be necessary. We can try to mount them as Unassigned Devices. But don't do anything with them yet. Quote Link to comment
JorgeB Posted February 1 Share Posted February 1 12 hours ago, trurl said: But maybe, it is actually rebuilding the original reiserfs and only thinks it is unmountable because it is trying to mount it as xfs. ? ? ? It should still mount after changing the fs back to reiser. Quote Link to comment
trurl Posted February 1 Share Posted February 1 @Rob_Dingen 17 hours ago, trurl said: wait for rebuild to complete Has it? Quote Link to comment
Rob_Dingen Posted February 1 Author Share Posted February 1 I'm a couple days out of the country and it's still rebuilding and need 12 hours to finish. I'll be back. Quote Link to comment
Rob_Dingen Posted February 6 Author Share Posted February 6 The rebuild has finished and the drive is unmountable unsupported or no file system. Quote Link to comment
JorgeB Posted February 6 Share Posted February 6 On 1/31/2024 at 7:12 PM, JorgeB said: click on disk4, change fs to reiser and post new diags after array start. Quote Link to comment
Rob_Dingen Posted February 6 Author Share Posted February 6 I think it works fine now. tower-diagnostics-20240206-1642.zip Quote Link to comment
JorgeB Posted February 6 Share Posted February 6 Looks fine, as mentioned before you cannot change to a different filesystem for a rebuild, it won't work, parity is not filesystem aware, it will rebuild the filesystem as it was. Quote Link to comment
Rob_Dingen Posted February 6 Author Share Posted February 6 Ok understand now. Is it better to convert to XFS later? How can I get my data from the old disk 4 and disk 5 back to the array? Quote Link to comment
trurl Posted February 6 Share Posted February 6 22 minutes ago, Rob_Dingen said: How can I get my data from the old disk 4 and disk 5 back to the array? See if they will mount using Unassigned Devices plugin. Then Dynamix File Manager plugin will let you work with files and folders directly on your server, including all mounted disks, assigned or unassigned. Quote Link to comment
JorgeB Posted February 6 Share Posted February 6 32 minutes ago, Rob_Dingen said: the old disk 4 Old disk4 should have the same data as current disk4. Quote Link to comment
Rob_Dingen Posted February 6 Author Share Posted February 6 (edited) I cannot mount the old disk, the only option is format. I use the disk in a sharkoon sata to usb device. 14 minutes ago, JorgeB said: Old disk4 should have the same data as current disk4. Remeber that when rebuild disk 4 the old disk 5 was replaced with a new one and I format it so there was no data. Edited February 6 by Rob_Dingen Quote Link to comment
trurl Posted February 6 Share Posted February 6 7 minutes ago, Rob_Dingen said: cannot mount the old disk, the only option is format. You can try check filesystem on that original disk. Quote Link to comment
Rob_Dingen Posted February 6 Author Share Posted February 6 I tried but don't know how to do it if I put reiserfsck -v /dev/mdh I only get the options list Quote Link to comment
trurl Posted February 6 Share Posted February 6 mdh is not an unassigned device. In fact it isn't any device. Is it sdh? If so, you would need to also specify the partition, so it would be /dev/sdh1 Quote Link to comment
