Wednesday at 06:23 PM1 day Fix Common Problems lives under the Unraid organisation at https://github.com/unraid/fix.common.problems. When a repository moves to a new home it starts again from zero stars, and right now it has one.Why this matters: the Unraid repositories use CodeRabbit, a service that reviews every pull request automatically. It reads the change and points out bugs, edge cases and mistakes before the change is merged. CodeRabbit skips repositories with fewer than 10 stars. On a pull request to FCP it posts this note instead of a review:> This repository does not receive automatic reviews because it has fewer than 10 stars.FCP runs on a lot of servers, and every new check that goes into it is code that runs on your box. A second pair of eyes on each change means fewer false alarms and fewer broken scans after an update. Several new checks are waiting for review right now, and none of them get that automatic review.If FCP ever caught something for you (a bad container setting, a full docker image, a share set up the wrong way, an unclean shutdown), please consider spending one click on it:1. Open https://github.com/unraid/fix.common.problems2. Click Star at the top right. It needs a free GitHub account.That's all. Ten stars switches on automatic reviews for every future change. Thanks!
