Jump to content
Problem with Mover
DigitalDivide
I had Mover scheduled last night but it appears to have failed.  The error is below.  Not sure why it's telling me that the disk is full as the disk I have the data moving to has about a 1TB free.  It should be moving the data to disk 10.
Originally the data was in a different folder on my cache drive.  I then created a root folder called TV Shows and then did a cut and paste to move the files to it.  There's a folder called TV Shows on my disk 10.  It's the same process I use when I move data to my Movies share.  So not really sure why this failed.
Aug 21 02:31:36 Tower shfs/user0: shfs_mkdir: assign_disk: TV Shows/The Walking Dead/Season 5 (28) No space left on device
Aug 21 02:31:36 Tower logger: rsync: recv_generator: mkdir "/mnt/user0/TV Shows/The Walking Dead/Season 5" failed: No space left on device (28)
Aug 21 02:31:36 Tower logger: *** Skipping any contents from this failed directory ***
Aug 21 02:31:36 Tower logger: cd+++++++++ TV Shows/The Walking Dead/Season 5/
Aug 21 02:31:37 Tower logger: rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1165) [sender=3.1.0]
Aug 21 02:31:37 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 4/CERTIFICATE/BACKUP/id.bdmv
Aug 21 02:31:37 Tower shfs/user0: shfs_mkdir: assign_disk: TV Shows/The Walking Dead/Season 5 (28) No space left on device
Aug 21 02:31:37 Tower logger: rsync: recv_generator: mkdir "/mnt/user0/TV Shows/The Walking Dead/Season 5" failed: No space left on device (28)
Aug 21 02:31:37 Tower logger: *** Skipping any contents from this failed directory ***
Aug 21 02:31:37 Tower logger: cd+++++++++ TV Shows/The Walking Dead/Season 5/
Aug 21 02:31:37 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 4/CERTIFICATE/app.discroot.crt
Aug 21 02:31:37 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 4/CERTIFICATE/bu.discroot.crt
Aug 21 02:31:37 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 4/CERTIFICATE/id.bdmv
Aug 21 02:31:37 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 4/disc.inf
Aug 21 02:31:37 Tower logger: mover finished
Aug 21 03:30:09 Tower kernel: mdcmd (95): spindown 1
Aug 21 03:30:16 Tower kernel: mdcmd (96): spindown 5
Aug 21 03:30:29 Tower kernel: mdcmd (97): spindown 3
Aug 21 03:30:29 Tower kernel: mdcmd (98): spindown 7
Aug 21 09:33:47 Tower emhttp: /usr/bin/tail -n 42 -f /var/log/syslog 2>&1
Aug 21 09:35:43 Tower emhttp: /usr/bin/tail -n 42 -f /var/log/syslog 2>&1
Link to comment
See attached syslog.
Aug 21 02:30:01 Tower logger: mover started
Aug 21 02:30:01 Tower logger: skipping "Appdata"
Aug 21 02:30:01 Tower logger: moving "TV Shows"
Aug 21 02:30:01 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00160.m2ts
Aug 21 02:30:08 Tower logger: .d..t...... ./
Aug 21 02:30:28 Tower shfs/user0: shfs_mkdir: assign_disk: TV Shows/The Walking Dead/Season 5 (28) No space left on device
Aug 21 02:30:28 Tower logger: rsync: recv_generator: mkdir "/mnt/user0/TV Shows/The Walking Dead/Season 5" failed: No space left on device (28)
Aug 21 02:30:28 Tower logger: *** Skipping any contents from this failed directory ***
Aug 21 02:30:28 Tower logger: .d..t...... TV Shows/
Aug 21 02:30:28 Tower logger: .d..tp..... TV Shows/The Walking Dead/
Aug 21 02:30:28 Tower logger: cd+++++++++ TV Shows/The Walking Dead/Season 5/
Aug 21 02:30:28 Tower logger: rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1165) [sender=3.1.0]
Aug 21 02:30:28 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00141.m2ts
Aug 21 02:30:28 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00137.m2ts
Aug 21 02:30:28 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00139.m2ts
Aug 21 02:30:28 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00135.m2ts
Aug 21 02:30:28 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00146.m2ts
Aug 21 02:30:28 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00131.m2ts
Aug 21 02:30:29 Tower logger: rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1165) [sender=3.1.0]
Aug 21 02:30:29 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00148.m2ts
Aug 21 02:30:29 Tower shfs/user0: shfs_mkdir: assign_disk: TV Shows/The Walking Dead/Season 5 (28) No space left on device
Aug 21 02:30:29 Tower logger: rsync: recv_generator: mkdir "/mnt/user0/TV Shows/The Walking Dead/Season 5" failed: No space left on device (28)
Aug 21 02:30:29 Tower logger: *** Skipping any contents from this failed directory ***
Aug 21 02:30:29 Tower logger: cd+++++++++ TV Shows/The Walking Dead/Season 5/
Aug 21 02:30:29 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00140.m2ts
Aug 21 02:30:29 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00149.m2ts
Aug 21 02:30:29 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00138.m2ts
Aug 21 02:30:29 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00128.m2ts
Aug 21 02:30:29 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00114.m2ts
Aug 21 02:30:29 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00126.m2ts
Aug 21 02:30:29 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00154.m2ts
Aug 21 02:30:29 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00157.m2ts
Aug 21 02:30:29 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00127.m2ts
Aug 21 02:30:29 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00161.m2ts
Aug 21 02:30:29 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00110.m2ts
Aug 21 02:30:30 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00155.m2ts
Aug 21 02:30:30 Tower shfs/user0: shfs_mkdir: assign_disk: TV Shows/The Walking Dead/Season 5 (28) No space left on device
Aug 21 02:30:30 Tower logger: rsync: recv_generator: mkdir "/mnt/user0/TV Shows/The Walking Dead/Season 5" failed: No space left on device (28)
Aug 21 02:30:30 Tower logger: *** Skipping any contents from this failed directory ***
Aug 21 02:30:30 Tower logger: cd+++++++++ TV Shows/The Walking Dead/Season 5/
Aug 21 02:30:30 Tower logger: rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1165) [sender=3.1.0]
Aug 21 02:30:30 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00130.m2ts
Aug 21 02:30:30 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00144.m2ts
Aug 21 02:30:30 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00129.m2ts
Aug 21 02:30:30 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00119.m2ts
Aug 21 02:30:30 Tower logger: ./TV Shows/The Walking Dead/Season 5/Disc 5/BDMV/STREAM/00164.m2ts
syslog.zip
Link to comment
How did you create the root folder called "TV Shows"?  Did you do this over SMB from another computer?
I think what may be happening is that you created the folder manually instead of creating a share from the webGui.  Here's what I'd ask that you try:
1 - Move the files to another share that you created using the webGui (not by creating a root folder off a disk device).
2 - Delete the share you created for TV Shows.
3 - Recreate the share for TV shows from the webGui, setting the Use Cache setting to Yes and disk includes to no.
4 - Put the files to be moved back in that share.
5 - Run the mover.
Report back if that works for you.
Link to comment
For the folder on the cache drive I simply used Windows.  I browsed to the cache drive, created a folder called TV Shows, then moved the files there.  On my data disks including disk 10, I already have a folder/share for movies and tv shows.
When moving a movie or tv show, currently I only want to move it to disk 10.  I'm using the exact same process for moving tv shows as I have been doing for movies.  For movies, I create a folder called Movies on the cache drive, move the movie there, then at the scheduled time Mover moves the movie to disk 10, which is where I want it.  It then deletes the folder I created.  Never fails.
If I delete the share TV Shows, what happens to the files in the folders?
Edit:  Forgot, for the folder on disk 10 called TV Shows, yes I simply browsed via windows and created that folder.
Link to comment
Well, not sure if this is a bug or something else.  On  cache drive I had TV Shows/Walking Dead/Disk1/ with a 9gb file.  Tried mover and it failed.  I then tried putting the file in TV Shows/Walking Dead/ and it worked.  So it seems the problem is a folder structure with more than 2 folders...Not sure if this is normal or not.
There should not be an inherent problem.  I regularly have paths with deeper folder levels than that.
Having said that, the Split Level settings for that share might end up being relevant if they are causing a different drive to the one you expect to be used on the main array.
Link to comment
I'm still having problems with Mover.  I had two folders on my cache drive in a folder called Movies.  One folder has an mkv movie (The Great Escape)  that is approx 28GB and the other was a blu ray structure folder for the movie Network, approx 20GB.  I ran mover and the movie Network was moved but not The Great Escape.  I can'f figure this out.  Both drives have plenty of disk space.
I could really use some help figuring this out.
Aug 23 19:10:17 Tower logger: >f+++++++++ Movies/The Great Escape/The Great Escape 1963 1080p Blu-ray Remux AVC DTS-HD MA 5.1.mkv
Aug 23 19:10:17 Tower shfs/user0: shfs_create: assign_disk: Movies/The Great Escape/The Great Escape 1963 1080p Blu-ray Remux AVC DTS-HD MA 5.1.mkv (28) No space left on device
Aug 23 19:10:31 Tower emhttp: /usr/bin/tail -n 42 -f /var/log/syslog 2>&1
Aug 23 19:11:24 Tower emhttp: /usr/bin/tail -n 42 -f /var/log/syslog 2>&1
Aug 23 19:12:31 Tower emhttp: /usr/bin/tail -n 42 -f /var/log/syslog 2>&1
Aug 23 19:13:23 Tower emhttp: /usr/bin/tail -n 42 -f /var/log/syslog 2>&1
Aug 23 19:14:56 Tower emhttp: /usr/bin/tail -n 42 -f /var/log/syslog 2>&1
Aug 23 19:15:49 Tower emhttp: /usr/bin/tail -n 42 -f /var/log/syslog 2>&1
Aug 23 19:17:04 Tower emhttp: /usr/bin/tail -n 42 -f /var/log/syslog 2>&1
Aug 23 19:18:51 Tower emhttp: /usr/bin/tail -n 42 -f /var/log/syslog 2>&1
Aug 23 19:18:55 Tower logger: rsync: open "/mnt/user0/Movies/The Great Escape/The Great Escape 1963 1080p Blu-ray Remux AVC DTS-HD MA 5.1.mkv" failed: No space left on device (28)
Aug 23 19:18:55 Tower logger: rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1165) [sender=3.1.0]
Aug 23 19:18:55 Tower logger: mover finished
Aug 23 22:05:50 Tower kernel: mdcmd (94): spindown 6
Aug 23 22:05:51 Tower kernel: mdcmd (95): spindown 4
Aug 23 22:05:58 Tower kernel: mdcmd (96): spindown 1
Aug 23 22:05:59 Tower kernel: mdcmd (97): spindown 8
Aug 23 22:06:10 Tower kernel: mdcmd (98): spindown 7
Aug 23 22:08:14 Tower kernel: mdcmd (99): spindown 0
Aug 23 22:08:15 Tower kernel: mdcmd (100): spindown 10
Aug 24 02:30:01 Tower logger: mover started
Aug 24 02:30:01 Tower logger: skipping "Appdata"
Aug 24 02:30:01 Tower logger: moving "Movies"
Aug 24 02:30:01 Tower logger: ./Movies/The Great Escape/The Great Escape 1963.mkv
Aug 24 02:30:01 Tower logger: .d..t...... Movies/The Great Escape/
Aug 24 02:30:01 Tower logger: >f+++++++++ Movies/The Great Escape/The Great Escape 1963.mkv
Aug 24 02:30:01 Tower shfs/user0: shfs_create: assign_disk: Movies/The Great Escape/The Great Escape 1963.mkv (28) No space left on device
Aug 24 02:38:19 Tower logger: rsync: open "/mnt/user0/Movies/The Great Escape/The Great Escape 1963.mkv" failed: No space left on device (28)
Aug 24 02:38:19 Tower logger: rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1165) [sender=3.1.0]
Aug 24 02:38:19 Tower logger: mover finished
tower-diagnostics-20150824-1931.zip
Link to comment
A learning moment for me, I now know the drive space is in K and not bytes in the diag file.  I don't see anything obvious misconfigured.  Have you tried to either copy the files from the command line to disk10, checked the file system on disk10 or tried changing the share options to see if you have found a combination that causes problems?  i might trying changing the allocation method to High Water or Most Free to see if that helps.
Link to comment
When you did the manual copy did you copy to /mnt/disk10 or /mnt/user0/Movies?  Copying to /mnt/disk10 ignores all the allocation logic and would prove that there are not any errors with the filesystem on the disk.  Copying to the /mnt/user0/Movies share would test the allocation logic.  Based on the error in your log shfs is returning error which is the process that performs all the allocation logic so I would experiment with the allocation setting.
Link to comment
I suspect BinHex-Deluge is not setting correct permissions. Show the output of
ls -al /mnt/cache
and
ls -la /mnt/cache/Movies
to confirm. Select Tools->New Permissions and run it on the cache disk to repair.
I used widows explorer and manually copied and pasted it to the folder on the cache drive.  What I don't understand is why did it move one folder and not the other?  If there was a problem with the allocation logic, I would assume it would fail both movies, not just one.
Link to comment
  • Create New...
