ijuarez Posted November 5, 2015 Share Posted November 5, 2015 I was doing some cleaning up on my unraid server 6.1.3 and notice in the dashboard that my eth0 was reporting 100/full not 1000. My board is a gigabyte with a realtek nic, and i have been reading the other post about some goofy anomalies. Everything in my network is gigabit so I Know that is not the issue. I did a quick "ifconfig" and sure enough is reporting a gig i wonder why unraid states it is not, prior to the latest update it did say 1000full. eth0: flags=4419<UP,BROADCAST,RUNNING,PROMISC,MULTICAST> mtu 1500 ether 50:e5:49:57:3c:1e txqueuelen 1000 (Ethernet) RX packets 148296302 bytes 198267741123 (184.6 GiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 91167762 bytes 30310912674 (28.2 GiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 Just thought i asked, performance does not seem to be hampered. Link to comment
trurl Posted November 5, 2015 Share Posted November 5, 2015 What does ethtools eth0 say? Link to comment
ijuarez Posted November 5, 2015 Author Share Posted November 5, 2015 What does ethtools eth0 say? says -bash ethtools: command not found Link to comment
trurl Posted November 5, 2015 Share Posted November 5, 2015 What does ethtools eth0 say? says -bash ethtools: command not found Sorry, tryethtool eth0 Link to comment
ijuarez Posted November 5, 2015 Author Share Posted November 5, 2015 root@LahomaMediaCenter:~# ethtool eth0 Settings for eth0: Supported ports: [ TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Supported pause frame use: No Supports auto-negotiation: Yes Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Advertised pause frame use: Symmetric Receive-only Advertised auto-negotiation: Yes Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full Link partner advertised pause frame use: Symmetric Receive-only Link partner advertised auto-negotiation: Yes Speed: 100Mb/s Duplex: Full Port: MII PHYAD: 0 Transceiver: internal Auto-negotiation: on Supports Wake-on: pumbg Wake-on: g Current message level: 0x00000033 (51) drv probe ifdown ifup Link detected: yes root@LahomaMediaCenter:~# Link to comment
bonienl Posted November 5, 2015 Share Posted November 5, 2015 You might want to check your cabling, since the speed is negotiated down to 100 Mb/s. Link to comment
ijuarez Posted November 5, 2015 Author Share Posted November 5, 2015 I will, its running cat6 , but that command gives me more details. I will make sure that i didnt pooch something. Link to comment
itimpi Posted November 6, 2015 Share Posted November 6, 2015 I will, its running cat6 , but that command gives me more details. I will make sure that i didnt pooch something. It is always worth trying an alternative cable as if any of the connections inside a cat6 cable are defective then speed will be negotiated down to 100Mb (as that requires less connections). Link to comment
ijuarez Posted November 6, 2015 Author Share Posted November 6, 2015 Thank you guys for the suggestions but I found the culprit. My pfSense box has two added nics and they are only 10/100. They are connected to my asus rt n66u (only used for wifi) which i used the ports as a switch (they are Gigbit) however when i connected my firewall box it slowed the whole switch. I did have gig card in my previous box but they turn out not to be supported by pfsense. Sooooo unraid is working perfectly. Link to comment
