Pducharme Posted June 13, 2016 Share Posted June 13, 2016 Hi, I deciced to move away from the owncloud Docker for multiple reasons. I was looking for a good appliance VM with Owncloud and automated updates, webmin, other enhencements over the official owncloud VM. It's where I found the great site techandme.se. They create and maintain multiple VM appliances; one of them is an "owncloud VM". Getting started 1. Get the "Ubuntu 16.04 main (or mirror) Preinstalled Owncloud (PHP 7.0)" from this site : https://www.techandme.se/pre-configured-owncloud-installaton/ 2. Extract the ZIP or RAR to a folder on your cache drive (or SSD where you want to store the VMs) I suggest : /mnt/cache/VMs/Disks/owncloud/ 3. Logon in SSH to your Unraid box with root and convert the vmdk using this command : qemu-img convert -p -f vmdk -O raw /mnt/cache/VMs/Disks/owncloud/owncloud.vmdk /mnt/cache/VMs/Disks/owncloud/owncloud.img 4. When the conversion is completed, delete the VMDK and other VMware files (*.vmdk, *.vmx, etc) in the /mnt/cache/VMs/Disks/owncloud/ folder and keep only the new "owncloud.img" 5. create a new VM that point to a Ubuntu template. You can use my XML provided below. 7. Boot the VM and follow the Install scripts questions, it's all automated! VM details from my XML : 1 CPU, 2 Core (6 and 7) - change to the core you want to pin 2GB RAM, max 3GB RAM - change to RAM you want, 2GB works fine for me br0 network - give an IP from your router, accessible from the LAN VNC passwd is 'test', keymap is 'fr-ca' - change to what you want 9p Mount: /unraid (point to /mnt/user) Code of the XML : <domain type='kvm' id='4'> <name>Owncloud</name> <uuid>581679d8-547d-5591-e63e-60b274d871da</uuid> <description>Owncloud VM (techandme.se)</description> <metadata> <vmtemplate xmlns="unraid" name="Ubuntu" icon="ubuntu.png" os="ubuntu"/> </metadata> <memory unit='KiB'>3145728</memory> <currentMemory unit='KiB'>2097152</currentMemory> <memoryBacking> <nosharepages/> </memoryBacking> <vcpu placement='static'>2</vcpu> <cputune> <vcpupin vcpu='0' cpuset='6'/> <vcpupin vcpu='1' cpuset='7'/> </cputune> <resource> <partition>/machine</partition> </resource> <os> <type arch='x86_64' machine='pc-q35-2.5'>hvm</type> </os> <features> <acpi/> <apic/> </features> <cpu> <topology sockets='1' cores='2' threads='1'/> </cpu> <clock offset='utc'> <timer name='rtc' tickpolicy='catchup'/> <timer name='pit' tickpolicy='delay'/> <timer name='hpet' present='no'/> </clock> <on_poweroff>destroy</on_poweroff> <on_reboot>restart</on_reboot> <on_crash>restart</on_crash> <devices> <emulator>/usr/local/sbin/qemu</emulator> <disk type='file' device='disk'> <driver name='qemu' type='raw' cache='writeback'/> <source file='/mnt/cache/VMs/Disks/owncloud/owncloud.img'/> <backingStore/> <target dev='hdc' bus='virtio'/> <boot order='1'/> <alias name='virtio-disk2'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x04' function='0x0'/> </disk> <controller type='usb' index='0' model='ich9-ehci1'> <alias name='usb'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x7'/> </controller> <controller type='usb' index='0' model='ich9-uhci1'> <alias name='usb'/> <master startport='0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x0' multifunction='on'/> </controller> <controller type='usb' index='0' model='ich9-uhci2'> <alias name='usb'/> <master startport='2'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x1'/> </controller> <controller type='usb' index='0' model='ich9-uhci3'> <alias name='usb'/> <master startport='4'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x2'/> </controller> <controller type='sata' index='0'> <alias name='ide'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/> </controller> <controller type='pci' index='0' model='pcie-root'> <alias name='pcie.0'/> </controller> <controller type='pci' index='1' model='dmi-to-pci-bridge'> <model name='i82801b11-bridge'/> <alias name='pci.1'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x1e' function='0x0'/> </controller> <controller type='pci' index='2' model='pci-bridge'> <model name='pci-bridge'/> <target chassisNr='2'/> <alias name='pci.2'/> <address type='pci' domain='0x0000' bus='0x01' slot='0x01' function='0x0'/> </controller> <controller type='virtio-serial' index='0'> <alias name='virtio-serial0'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x03' function='0x0'/> </controller> <filesystem type='mount' accessmode='passthrough'> <source dir='/mnt/user/'/> <target dir='unraid'/> <alias name='fs0'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x01' function='0x0'/> </filesystem> <interface type='bridge'> <mac address='52:54:00:2a:5f:99'/> <source bridge='br0'/> <target dev='vnet0'/> <model type='virtio'/> <alias name='net0'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x02' function='0x0'/> </interface> <serial type='pty'> <source path='/dev/pts/1'/> <target port='0'/> <alias name='serial0'/> </serial> <console type='pty' tty='/dev/pts/1'> <source path='/dev/pts/1'/> <target type='serial' port='0'/> <alias name='serial0'/> </console> <channel type='unix'> <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/domain-Owncloud/org.qemu.guest_agent.0'/> <target type='virtio' name='org.qemu.guest_agent.0' state='disconnected'/> <alias name='channel0'/> <address type='virtio-serial' controller='0' bus='0' port='1'/> </channel> <input type='tablet' bus='usb'> <alias name='input0'/> </input> <input type='mouse' bus='ps2'/> <input type='keyboard' bus='ps2'/> <graphics type='vnc' port='5900' autoport='yes' websocket='5700' listen='0.0.0.0' keymap='fr-ca'> <listen type='address' address='0.0.0.0'/> </graphics> <video> <model type='qxl' ram='65536' vram='65536' vgamem='16384' heads='1'/> <alias name='video0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0'/> </video> <memballoon model='virtio'> <alias name='balloon0'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x05' function='0x0'/> </memballoon> </devices> </domain> Configuring 9P Sharing (passthrough of Unraid /mnt/user) : 1. Login on the newly build VM using the ocadmin user and the password you setup in the first boot of the VM. 2. become root by typing sudo -i 3. Create the folder /mnt/unraid: mkdir /mnt/unraid 4. type the following command to go inside the fstab file : nano /etc/fstab 5. On the last blank line of file fstab, add the following : unraid /mnt/unraid 9p rw,dirsync,relatime,trans=virtio,version=9p2000.L,posixacl,cache=loose 0 0 6. Quit & save the fstab file (ctrl+x, Yes to save). 7. Reboot the VM. reboot The new sharing should work and in your Owncloud, you should be able to use "External Storage Support" to point a "local" share to the /mnt/unraid/WhateverFolderYouDesire. Quote Link to comment
KShips Posted July 11, 2016 Share Posted July 11, 2016 Thanks for this, I have used it with their NextCloud VM and works well. Quote Link to comment
jpimlott Posted August 25, 2016 Share Posted August 25, 2016 the VM works without using 9p for networking I followed the instructions but it starts in emergency mode when using the 9p network addon. john 1 Quote Link to comment
HumidGnome Posted August 16, 2020 Share Posted August 16, 2020 I am new to all of this. I don't know much shell script, so please bear with me. How do i ssh into my unraid usb stick to mount the vm? Quote Link to comment
Energen Posted August 16, 2020 Share Posted August 16, 2020 Just use a console window from the unraid gui. Quote Link to comment
mauriceatkinson@btconnect. Posted April 8, 2021 Share Posted April 8, 2021 I tried to install the 1TB nextcloud vm from Hanssonit.se but it fails on the installation stating "your data directory is invalid" I have attached an image of the failure. Any ideas welcome Quote Link to comment
chrismuc Posted April 14, 2022 Share Posted April 14, 2022 I'm having trouble getting this working, using the latest NextcloudVM ova package, I'm stuck in the UEFI shell ('exit' doesn't lead anywhere else). This is my vm-xml: <?xml version='1.0' encoding='UTF-8'?> <domain type='kvm'> <name>NextcloudVM</name> <uuid>58aff6d9-0004-ac5c-1915-0fd1042d336c</uuid> <metadata> <vmtemplate xmlns="unraid" name="Ubuntu" icon="ubuntu.png" os="ubuntu"/> </metadata> <memory unit='KiB'>4194304</memory> <currentMemory unit='KiB'>4194304</currentMemory> <memoryBacking> <nosharepages/> </memoryBacking> <vcpu placement='static'>2</vcpu> <cputune> <vcpupin vcpu='0' cpuset='3'/> <vcpupin vcpu='1' cpuset='7'/> </cputune> <os> <type arch='x86_64' machine='pc-q35-6.2'>hvm</type> <loader readonly='yes' type='pflash'>/usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi.fd</loader> <nvram>/etc/libvirt/qemu/nvram/58aff6d9-0004-ac5c-1915-0fd1042d336c_VARS-pure-efi.fd</nvram> </os> <features> <acpi/> <apic/> </features> <cpu mode='host-passthrough' check='none' migratable='on'> <topology sockets='1' dies='1' cores='1' threads='2'/> <cache mode='passthrough'/> </cpu> <clock offset='utc'> <timer name='rtc' tickpolicy='catchup'/> <timer name='pit' tickpolicy='delay'/> <timer name='hpet' present='no'/> </clock> <on_poweroff>destroy</on_poweroff> <on_reboot>restart</on_reboot> <on_crash>restart</on_crash> <devices> <emulator>/usr/local/sbin/qemu</emulator> <disk type='file' device='disk'> <driver name='qemu' type='raw' cache='writeback'/> <source file='/mnt/cache_appdata_vms/domains/nextcloudvm/40GB_Nextcloud-VM_www.hanssonit.se-disk1.img'/> <target dev='hdc' bus='virtio'/> <boot order='1'/> <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0'/> </disk> <disk type='file' device='disk'> <driver name='qemu' type='raw' cache='writeback'/> <source file='/mnt/cache_appdata_vms/domains/nextcloudvm/40GB_Nextcloud-VM_www.hanssonit.se-disk2.img'/> <target dev='hdd' bus='virtio'/> <address type='pci' domain='0x0000' bus='0x05' slot='0x00' function='0x0'/> </disk> <controller type='usb' index='0' model='ich9-ehci1'> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x7'/> </controller> <controller type='usb' index='0' model='ich9-uhci1'> <master startport='0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x0' multifunction='on'/> </controller> <controller type='usb' index='0' model='ich9-uhci2'> <master startport='2'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x1'/> </controller> <controller type='usb' index='0' model='ich9-uhci3'> <master startport='4'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x2'/> </controller> <controller type='pci' index='0' model='pcie-root'/> <controller type='pci' index='1' model='pcie-root-port'> <model name='pcie-root-port'/> <target chassis='1' port='0x10'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0' multifunction='on'/> </controller> <controller type='pci' index='2' model='pcie-root-port'> <model name='pcie-root-port'/> <target chassis='2' port='0x11'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x1'/> </controller> <controller type='pci' index='3' model='pcie-root-port'> <model name='pcie-root-port'/> <target chassis='3' port='0x12'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x2'/> </controller> <controller type='pci' index='4' model='pcie-root-port'> <model name='pcie-root-port'/> <target chassis='4' port='0x13'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x3'/> </controller> <controller type='pci' index='5' model='pcie-root-port'> <model name='pcie-root-port'/> <target chassis='5' port='0x14'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x4'/> </controller> <controller type='pci' index='6' model='pcie-root-port'> <model name='pcie-root-port'/> <target chassis='6' port='0x15'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x5'/> </controller> <controller type='pci' index='7' model='pcie-root-port'> <model name='pcie-root-port'/> <target chassis='7' port='0x16'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x6'/> </controller> <controller type='virtio-serial' index='0'> <address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x0'/> </controller> <controller type='sata' index='0'> <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/> </controller> <filesystem type='mount' accessmode='passthrough'> <source dir='/mnt/user/slownas/'/> <target dir='slownas'/> <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/> </filesystem> <interface type='bridge'> <mac address='52:54:00:d9:4d:4d'/> <source bridge='br0'/> <model type='virtio'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x00' function='0x0'/> </interface> <serial type='pty'> <target type='isa-serial' port='0'> <model name='isa-serial'/> </target> </serial> <console type='pty'> <target type='serial' port='0'/> </console> <channel type='unix'> <target type='virtio' name='org.qemu.guest_agent.0'/> <address type='virtio-serial' controller='0' bus='0' port='1'/> </channel> <input type='tablet' bus='usb'> <address type='usb' bus='0' port='1'/> </input> <input type='mouse' bus='ps2'/> <input type='keyboard' bus='ps2'/> <graphics type='vnc' port='-1' autoport='yes' websocket='-1' listen='0.0.0.0' keymap='de'> <listen type='address' address='0.0.0.0'/> </graphics> <audio id='1' type='none'/> <video> <model type='qxl' ram='65536' vram='65536' vgamem='16384' heads='1' primary='yes'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0'/> </video> <memballoon model='virtio'> <address type='pci' domain='0x0000' bus='0x06' slot='0x00' function='0x0'/> </memballoon> </devices> </domain> Any ideas why it's not starting? Cheers! Quote Link to comment
