***GUIDE*** Passing Through Network Controllers to unRAID 6 Virtual Machines
Hi All
I have a few minutes to look at my XML file and the layout is below.
I do not have a clue what to do next as this appears to be correct.
      <driver name='vfio'/>
      <source>
        <address domain='0x0000' bus='0x07' slot='0x00' function='0x0'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x07' slot='0x00' function='0x1'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x08' slot='0x00' function='0x0'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x08' slot='0x00' function='0x1'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x05' slot='0x00' function='0x0'/>
    </hostdev>
Do I need to change anything as the address is correct as per my IOMMU groups.
IOMMU group 20:	[8086:10bc] 07:00.0 Ethernet controller: Intel Corporation 82571EB/82571GB Gigabit Ethernet Controller (Copper) (rev 06)
[8086:10bc] 07:00.1 Ethernet controller: Intel Corporation 82571EB/82571GB Gigabit Ethernet Controller (Copper) (rev 06)
IOMMU group 21:	[8086:10bc] 08:00.0 Ethernet controller: Intel Corporation 82571EB/82571GB Gigabit Ethernet Controller (Copper) (rev 06)
[8086:10bc] 08:00.1 Ethernet controller: Intel Corporation 82571EB/82571GB Gigabit Ethernet Controller (Copper) (rev 06)
  • Replies 197
  • Views 201.5k
  • gfjardim
    gfjardim
    A easier method of discovering the right card to passthrough is running:   #!/bin/bash for ETH in $(find /sys/devices/ -type d -iname "eth[0-9]"); do   port=$(basename $ETH);   export $(cat $ETH
  • I’ll write up a quick guide when I finish work. Sent from my iPhone using Tapatalk
  • L0rdRaiden
    L0rdRaiden
    I have followed the 3rd method in this video to bypass one of my nics. I have a pcie network card with 2 nics i350   This is the iommu group IOMMU group 6:
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
Try changing the guest address so both pci devices are on the same bus - same slot
Add multifunction on the 1st device and change the second device to function 0x1
Same on the 3rd and 4th just change bus number.
Each pair should be on one bus.
Just copy paste this over your XML for those 4 devices.
Should work.
DISCLAIMER! I don't know if its the right way to do this. But this was what fixed it for me!
I have very small idea on what i'm doing in KVM!
      <source>
      </source>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0' multifunction='on'/>
    </hostdev>
      <source>
      </source>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x1'/>
    </hostdev>
      <source>
      </source>
      <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0' multifunction='on'/>
    </hostdev>
      <source>
      </source>
      <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x1'/>
    </hostdev>
It has semi worked. I now have 2 ports showing, it seems as if each pair has been bundled together.
I has given me a starting point on setting up Pfsense.
Any more thoughts on this would be most appreciated.
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
      <source>
      </source>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x2'/>
    </hostdev>
      <source>
      </source>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x3'/>
    </hostdev>
This should work now.
I just tricked it to see the whole nic as one pci device and multiple functions.
It was one of the ways that worked for me. Haven't tested yet neither setting pfsense or speed. but this made mine show up
The same problem persists only two show up.
After starting Pfsense and confirming only 2 ports were available, I wnet back in to the XML and found the file below.
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
I could find no way to remove the multifunction on command.
      <source>
        <address domain='0x0000' bus='0x0b' slot='0x00' function='0x0'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x0' multifunction='on'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x0b' slot='0x00' function='0x1'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x1'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x0c' slot='0x00' function='0x0'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x06' function='0x0' multifunction='on'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x0c' slot='0x00' function='0x1'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x06' function='0x1'/>
    </hostdev>
Here is how my XML is now and pfsense sees all 4 ports
Here is my IOMMU
IOMMU group 18:	[111d:8018] 0a:02.0 PCI bridge: Microsemi / PMC / IDT PES12N3A 12-lane 3-Port PCI Express Switch (rev 0e)
				[8086:10bc] 0b:00.0 Ethernet controller: Intel Corporation 82571EB/82571GB Gigabit Ethernet Controller (Copper) (rev 06)
				[8086:10bc] 0b:00.1 Ethernet controller: Intel Corporation 82571EB/82571GB Gigabit Ethernet Controller (Copper) (rev 06)
IOMMU group 19:	[111d:8018] 0a:04.0 PCI bridge: Microsemi / PMC / IDT PES12N3A 12-lane 3-Port PCI Express Switch (rev 0e)
				[8086:10bc] 0c:00.0 Ethernet controller: Intel Corporation 82571EB/82571GB Gigabit Ethernet Controller (Copper) (rev 06)
				[8086:10bc] 0c:00.1 Ethernet controller: Intel Corporation 82571EB/82571GB Gigabit Ethernet Controller (Copper) (rev 06)
I dont know what else you could try. ill leave it to the pros.
Hi All
I also purchased myself a Intel 4 NIC for a pfsense but I cannot get it removed from Unraid and made visible on the VM
The netcard is in these two groups:
0a:00.0 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
0a:00.1 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
0b:00.0 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
0b:00.1 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
0a:00.0 0200: 8086:10e8 (rev 01)
0a:00.1 0200: 8086:10e8 (rev 01)
0b:00.0 0200: 8086:10e8 (rev 01)
0b:00.1 0200: 8086:10e8 (rev 01)
I have tried both:
vfio-pci.ids=8086:10e8
pci-stub.ids=8086:10e8
I have read through many post and I keep getting this under network...
The two first is on the MB and the 4 NIC is shown like this "Shutdown (Inactive) shouldn't they be gone?
Also I can't see them show up when creating a VM like people show on their youtube videos?
(The card works because I used it before in Unraid, and I have removed it from the Bridge and network conf)
Could it be because I boot in GUI mode? - Do I need to add this here?
Yes, if you boot into GUI mode, then you need to add it there.
Had been using @L0rdRaiden's video to pass through a nic to my CentOS vm.
Since upgrading to 6.8.1 that guide no longer appears to work.   My XML is here:
    <interface type='bridge'>
      <mac address='52:54:00:fd:f4:bb'/>
      <source bridge='br1'/>
      <model type='virtio'/>
    </interface>
    <serial type='pty'>
        <model name='isa-serial'/>
      </target>
    </serial>
    <console type='pty'>
    </console>
    <channel type='unix'>
    </channel>
    </input>
    <graphics type='vnc' port='-1' autoport='yes' websocket='-1' listen='0.0.0.0' keymap='en-us'>
    </graphics>
    <video>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0'/>
    </video>
      <source>
        <address domain='0x0000' bus='0x02' slot='0x00' function='0x0'/>
      </source>
    </hostdev>
    <memballoon model='virtio'>
    </memballoon>
  </devices>
  <seclabel type='dynamic' model='dac' relabel='yes'/>
</domain>
What appears most obvious to me is the 'hostdev' tag is no longer in use on the xml.
How to fix?
Edited by eds
edit xml
Just an quick update.
It is all working now and I am on the way to using Pfsense.
I would like to thank evryone for the advice.
@Beaker69Which was the solution?
Wish everyone could be so lucky.   Still crickets for my issue.
@bza I eventually used @skois path to a solution. This has the 4 ports in 2 pairs.
I've been trying to pass though my HP NC365T 4 port NIC to my OPNsense VM all day, every time I boot, it acts like I have no interfaces. Here is my current setup.
IOMMU group 30:	[8086:150e] 03:00.0 Ethernet controller: Intel Corporation 82580 Gigabit Network Connection (rev 01)
IOMMU group 31:	[8086:150e] 03:00.1 Ethernet controller: Intel Corporation 82580 Gigabit Network Connection (rev 01)
IOMMU group 32:	[8086:150e] 03:00.2 Ethernet controller: Intel Corporation 82580 Gigabit Network Connection (rev 01)
IOMMU group 33:	[8086:150e] 03:00.3 Ethernet controller: Intel Corporation 82580 Gigabit Network Connection (rev 01)
Unraid OS
kernel /bzimage
append vfio-pci.ids=8086:150e initrd=/bzroot
      <source>
        <address domain='0x0000' bus='0x03' slot='0x00' function='0x0'/>
      </source>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x03' slot='0x00' function='0x1'/>
      </source>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x03' slot='0x00' function='0x2'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x06' slot='0x00' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x03' slot='0x00' function='0x3'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x07' slot='0x00' function='0x0'/>
    </hostdev>
On 12/21/2019 at 5:59 PM, skois said:
I have stubbed the NIC and it appears on the VM editor. I'm selecting all 4 ports and boot the VM.
pfSense only sees 1 port. (em0).
The only way i managed to make pfSense to see all 4 ports was to manually change XML to this:
By changing guest nic's addresses to:
01:00.0
01:00.1
01:00.2
01:00.3
from
01:00.0
03:00.0
04:00.0
05:00.0
Is this correct way to do it? Why with the default XML it only lists 1 port?
Edited XML Part:
      <source>
      </source>
      <alias name='hostdev0'/>
    </hostdev>
      <source>
      </source>
      <alias name='hostdev1'/>
    </hostdev>
      <source>
      </source>
      <alias name='hostdev2'/>
    </hostdev>
      <source>
      </source>
      <alias name='hostdev3'/>
    </hostdev>
i have been trying for days literally following multiple guides, videos, etc to get my 4 port intel nic recognized in ANY vm with more than 1 port, this is the only thing on hundreds of pages of google results as well as posts here that got it working with not just more than 1 port but all 4 work without issue
I'm happy that this helped you!
But i REALLY would like an explanation why it is working by doing a manually edit like this.
Why the VM form creator doen't make it by it self.
And how come none of the "geniuses" around here give that kind of solution. Does the auto xml creation work on others? Is this happening only on specific systems? I remember getting the exact same NIC card as SI just to avoid any problems. and also remember that i had a simillar system as SI.
I'm totally noob in KVM stuff and i only figured this while i was watching a SI's video about passing a video card and he mentions about the multifunction thing.
That was a lot of questions heh? :D
SI = SpaceInvader
SI = SpaceInvader
This issue is pretty ridiculous.  I had virtual machine capability on my qnap nas and it didn't have any of these issues.
I thought Unraid would be much better in the  implementation.  Go figure it's worse!
And the video in this thread which used to work is now useless.
Hi all
I seem to be having the same issues as others are having, but I'm using a 2 port SFP+ NIC. Might be a little different.
Here's my xml:
      <source>
        <address domain='0x0000' bus='0x81' slot='0x00' function='0x0'/>
      </source>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x81' slot='0x00' function='0x1'/>
      </source>
    </hostdev>
If anybody could help me id be sooo happy.
Just now, Partial said:
Hi all
Here's my xml:
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
Change the second adress tags to
<address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x0' multifunction='on'/>
<address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x1'/>
So it will be in the same virtual bus
Now you should see 2 ports when booted
Hey guys,
i try to passthrough my nic to a win 10 vm.
2b:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
8086:10d3
These are the details about my nic.
When I start the VM there is the following error:
internal error: Unknown PCI header type '127' for device '0000:2b:00.0'
What can I do?
MB ist an ASRock Rack X470D4U with a Ryzen 7 2700.
Thank you very much for your help.
Edited by willi_jan9393
❤️ That worked! TY!
This might be answered (didn't see it but I could be wrong), if I have a dual port i350 NIC built into my server I cannot pass just one of them through to a VM correct?
If this has been solved, I haven't seen it.
Not a huge deal for me, I have another dual port NIC I can drop in until I get my switch with two SFP+ ports so I can use my SolarFlare NIC in a virtualized pfSense install.
