***GUIDE*** Passing Through Network Controllers to unRAID 6 Virtual Machines
Because of the IOMMU groups above you could pass two controllers through to each VM but not individually.  If you turn on the "PCIe ACS Override:" in VM settings you might be able to separate them but it still may not work.  If you don't turn on the ACS Override you will have better luck but you have to settle for passing both nics in the IOMMU group to the VM together.  So 04:00.0 & 04:00.1 would go to one VM and 05:00.0 & 05:00.1 to another.  I would expect that to work.  I must confess however I have never tried a quad nic card and pass through just my MB built in quad nics.
Edit: OH yes you can't just pass a single nic of the pair through at a time they would have to be passed together for it to work at all - if I'm right.
I have PCIe ACS Override on to pass through my GPU I believe.
I also tried passing through one, a pair, and all four but still receive the same error.
I would check with jonp now.  I am out of ideas.
  • Replies 197
  • Views 201.5k
  • gfjardim
    gfjardim
    A easier method of discovering the right card to passthrough is running:   #!/bin/bash for ETH in $(find /sys/devices/ -type d -iname "eth[0-9]"); do   port=$(basename $ETH);   export $(cat $ETH
  • I’ll write up a quick guide when I finish work. Sent from my iPhone using Tapatalk
  • L0rdRaiden
    L0rdRaiden
    I have followed the 3rd method in this video to bypass one of my nics. I have a pcie network card with 2 nics i350   This is the iommu group IOMMU group 6:
Created new post
5 - Obtain the vendor/product ID for that device from the last column.  00:19.0 from my example is 8086:153b.
6 - Edit your syslinux.cfg file and add the following after the append but before initrd=/bzroot.
Code: [select]
pci-stub.ids=8086:153b
what does this do?
i have a on board network and a pci 2 port
but all show up same
05:00.0 0200: 10ec:8168 (rev 0c)
06:00.0 0200: 10ec:8168 (rev 0c)
0d:00.0 0200: 10ec:8168 (rev 09)
i did add the 2 port to my vm and its working but what happens when i reboot the system? will unraid try to use it ?
Silly question, perhaps, but does this guide assume your CPU has VT-d support? Does this work if you only have VT-x?
Vt-d is a requirement for passing through PCI/pcie devices, so yes vt-d support is assumed.
Hi Guys!
Trying to add a network card to my pfsense vm.
3Com Corporation 3c940              37:09.0 0200: 10b7:1700
Realtek RTL8111/8168/8411          03:00.0 0200: 10ec:8168
Added pci-stub.ids=10ec:8168,10b7:1700 to my syslinux.cfg
rebooted
Added the following line to my .xml-file
(Im only testing ONE card at the moment for a proof of concept)
      <driver name='vfio'/>
      <source>
        <address domain='0x0000' bus='0x37' slot='0x09' function='0x0'/>
      </source>
    </hostdev>
That was changed to:
(2 last lines automatically added)
      <source>
      </source>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x06' function='0x0'/>
    </hostdev>
However i receive the following error when trying to start the vm:
virsh start pfSense160325
error: Failed to start domain pfSense160325
error: internal error: early end of file from monitor: possible problem:
2016-03-25T20:01:38.358902Z qemu-system-x86_64: -device vfio-pci,host=37:09.0,id=hostdev0,bus=pci.2,addr=0x6: vfio: failed to set iommu for container: Operation not permitted
2016-03-25T20:01:38.358943Z qemu-system-x86_64: -device vfio-pci,host=37:09.0,id=hostdev0,bus=pci.2,addr=0x6: vfio: failed to setup container for group 13
2016-03-25T20:01:38.358957Z qemu-system-x86_64: -device vfio-pci,host=37:09.0,id=hostdev0,bus=pci.2,addr=0x6: vfio: failed to get group 13
2016-03-25T20:01:38.358969Z qemu-system-x86_64: -device vfio-pci,host=37:09.0,id=hostdev0,bus=pci.2,addr=0x6: Device initialization failed
2016-03-25T20:01:38.358982Z qemu-system-x86_64: -device vfio-pci,host=37:09.0,id=hostdev0,bus=pci.2,addr=0x6: Device 'vfio-pci' could not be initialized
Any clues?!
Hi All...
Can anyone here recommend a good / Compatible multiport nic?... 6 ports ideally but 4 ports being acceptable... i'd like the ability to pass each NIC individually to V/Ms .... I have currently an 'Intel Pro/1000 PT Quad port LP SVR' but cant pass ports individually i have to pass them in pairs to my V/Ms
Cheers
I have the SAME Exact Problem. Trying to install Astaro Security Gateway in a physically separated Network VM...
The XML gets "appended with a "special" line without any of my action AND the VM won't start.
My cpu supports all the VM shananagans
http://ark.intel.com/products/33910/Intel-Core2-Duo-Processor-E8400-6M-Cache-3_00-GHz-1333-MHz-FSB
Don't know what to do...
Hi Guys!
rebooted
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
Any clues?!
Hi Guys!
rebooted
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
Any clues?!
You should try this from the unraid wiki
The extra line added is supposed to be added. It is the address inside the specific VM. So nothing to worry about.
  • 2 months later...
Thank you!
adding "vfio_iommu_type1.allow_unsafe_interrupts=1" to my sysliunux.cfg did the job !!
I have tried to follow the OP's directions and cannot get this working. I want to pass through a quad port NIC to a VM.
lspci reports the 4 port card as this:
04:00.0 Ethernet controller: Intel Corporation 82571EB Gigabit Ethernet Controller (Copper) (rev 06)
04:00.1 Ethernet controller: Intel Corporation 82571EB Gigabit Ethernet Controller (Copper) (rev 06)
05:00.0 Ethernet controller: Intel Corporation 82571EB Gigabit Ethernet Controller (Copper) (rev 06)
05:00.1 Ethernet controller: Intel Corporation 82571EB Gigabit Ethernet Controller (Copper) (rev 06)
lspci -n reports:
04:00.0 0200: 8086:10bc (rev 06)
04:00.1 0200: 8086:10bc (rev 06)
05:00.0 0200: 8086:10bc (rev 06)
05:00.1 0200: 8086:10bc (rev 06)
I've edited syslinux.cfg to add this line:
  append pci-stub.ids=8086:10bc initrd=/bzroot
I've added this to the xml for the vm:
      <source>
        <address domain='0x0000' bus='0x04' slot='0x00' function='0x0'/>
      </source>
    </hostdev>
After I add this, I click "update" to save the changes. When I look at the XML again it shows an extra line which I've bolded:
      <source>
      </source>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x06' function='0x0'/>    <----This line was added.
    </hostdev>
When I try to start the VM, I get "Execution error, Requested operation is not valid: PCI device 0000:04:00.0 is not assignable."
I'm running unraid 6.1.9 pro.  Would appreciate some help.
You have only passed through one of the ports on your card. You need to add three more hostdev tags with the PCI number if you want all four.
It's normal that there is a line added, so nothing to worry about.
@saag  I have added all 4 of the nics on the card to xml, but I still get the same error "Execution error, Requested operation is not valid: PCI device 0000:04:00.0 is not assignable."
I checked the bios and vt-d is enabled. Are there any other bios settings to check?
Here's xml I added for the 4 ports:
      <source>
      </source>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x04' slot='0x00' function='0x1'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x07' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x05' slot='0x00' function='0x0'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x08' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x05' slot='0x00' function='0x1'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x09' function='0x0'/>
    </hostdev>
Have you turned on the ACS override in the VM settings?
Your network card is in groups with other devices.
I saw this error message in the libvirtd log: internal error: Device 0000:04:00.0 is behind a switch lacking ACS and cannot be assigned
So I turned on the ACS override option. After rebooting, tried to start the VM, but got the same error message as before.
You could try to add allow_unsafe_assigned_interrupts=1  in your syslinux.cfg after append and see if that changes anything.
I've added allow_unsafe_assigned_interrupts=1 to syslinux.cfg and tried it with and without the ACS override. I still get the same error.
Thanks for your help saarg. I appreciate your efforts.
Update:  I think I've got this working now. The answer was to uncomment relaxed_acs_check = 1 in /etc/libvirt/qemu.conf.
Update:  Turned off PCIe ACS override, rebooted. Confirmed that VM still starts up without error
Update:  Removed vfio_iommu_type1.allow_unsafe_interrupts=1 from syslinux.cfg. Confirmed that VM starts up without error.
Sorry to revive an old thread. But how do I pass through a NIC with multiple ports? I followed John's original post and can get the NIC to pass through however I only see one port, the other three are not available.
A little more info would be nice to have.
Post the  VM's XML and which operating system is it?
Which PCI numbers do the card have?
The OS is PFSense. The NIC is an Intel I350.
8086:1521
07:00:0
07:00:1
07:00:2
07:00:3
<domain type='kvm'>
  <name>PFSense</name>
  <uuid>13ba092b-df1b-cc8a-e2bf-d544dff69a57</uuid>
  <metadata>
    <vmtemplate name="Custom" icon="freebsd.png" os="freebsd"/>
  </metadata>
  <memory unit='KiB'>4194304</memory>
  <currentMemory unit='KiB'>4194304</currentMemory>
  <memoryBacking>
    <nosharepages/>
    <locked/>
  </memoryBacking>
  <vcpu placement='static'>3</vcpu>
  <cputune>
    <vcpupin vcpu='0' cpuset='0'/>
    <vcpupin vcpu='1' cpuset='6'/>
    <vcpupin vcpu='2' cpuset='7'/>
  </cputune>
  <os>
    <type arch='x86_64' machine='pc-q35-2.3'>hvm</type>
  </os>
  <features>
    <acpi/>
    <apic/>
  </features>
  <cpu mode='host-passthrough'>
    <topology sockets='1' cores='3' threads='1'/>
  </cpu>
  <clock offset='utc'>
    <timer name='rtc' tickpolicy='catchup'/>
    <timer name='pit' tickpolicy='delay'/>
  </clock>
  <on_crash>restart</on_crash>
  <devices>
    <emulator>/usr/bin/qemu-system-x86_64</emulator>
      <source file='/mnt/cache/vdisks/PFSense/vdisk1.img'/>
      <target dev='hdb' bus='virtio'/>
      <boot order='1'/>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x04' function='0x0'/>
    </disk>
      <source file='/mnt/user/ISOs/pfSense-CE-2.3.1-RELEASE-amd64.iso'/>
      <target dev='hda' bus='sata'/>
      <readonly/>
      <boot order='2'/>
    </disk>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x02' function='0x7'/>
    </controller>
      <master startport='0'/>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x02' function='0x0' multifunction='on'/>
    </controller>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
    </controller>
    <controller type='pci' index='0' model='pcie-root'/>
    <controller type='pci' index='1' model='dmi-to-pci-bridge'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1e' function='0x0'/>
    </controller>
    <controller type='pci' index='2' model='pci-bridge'>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x01' function='0x0'/>
    </controller>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x03' function='0x0'/>
    </controller>
    <interface type='bridge'>
      <mac address='52:54:00:d7:76:76'/>
      <source bridge='br0'/>
      <model type='virtio'/>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x01' function='0x0'/>
    </interface>
    <serial type='pty'>
      <target port='0'/>
    </serial>
    <console type='pty'>
    </console>
    <channel type='unix'>
      <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/PFSense.org.qemu.guest_agent.0'/>
    </channel>
    <input type='tablet' bus='usb'/>
    <graphics type='vnc' port='-1' autoport='yes' websocket='-1' listen='0.0.0.0' keymap='en-us'>
    </graphics>
    <video>
      <model type='vmvga' vram='16384' heads='1'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0'/>
    </video>
    <memballoon model='virtio'>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x05' function='0x0'/>
    </memballoon>
      <source>
        <address domain='0x0000' bus='0x00' slot='0x07' function='0x0'/>
      </source>
    </hostdev>
  </devices>
</domain>
I want the Intel Quad NIC to be accessible only via PFSense. I followed John's instruction however only one port on the NIC comes through (igb0). Even when I selected PCIe ACS Override.
8086:1521
07:00:0
07:00:1
07:00:2
07:00:3
<domain type='kvm'>
  <metadata>
  </metadata>
  <memoryBacking>
    <nosharepages/>
    <locked/>
  </memoryBacking>
  <cputune>
  </cputune>
  <os>
  </os>
  <features>
    <acpi/>
    <apic/>
  </features>
  </cpu>
  </clock>
  <devices>
      <boot order='1'/>
    </disk>
      <readonly/>
      <boot order='2'/>
    </disk>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </interface>
    <serial type='pty'>
      <target port='0'/>
    </serial>
    </console>
    </channel>
    </graphics>
    <video>
    </video>
    </memballoon>
      <source>
      </source>
    </hostdev>
  </devices>
</domain>
You need to add a hostdev tag for every device you want to pass through. You have only passed through the first port.
07:00:0
07:00:1
07:00:2
07:00:3
      <source>
      </source>
    </hostdev>
You have not loaded the above correctly.  "07" is the bus not the slot and you need to load all of them not just one as saarg said.
So replace:
      <source>
      </source>
    </hostdev>
With this:
      <source>
        <address domain='0x0000' bus='0x07' slot='0x00' function='0x0'/>
      </source>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x07' slot='0x00' function='0x1'/>
      </source>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x07' slot='0x00' function='0x2'/>
      </source>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x07' slot='0x00' function='0x3'/>
      </source>
    </hostdev>
Thankyou! Ill try that.
