September 3, 20187 yr These are speed tests. I have a 1Gbit speed at home and during other speed tests I easily get 900Mbit easily on all tests. I have no idea on what to do. 2018-09-01 12:14 Sat Verizon (Wall, NJ) 47.92 km 29.037 ms 250.23 Mbit/s 38.28 Mbit/s http://www.speedtest.net/result/7600021293.png 2018-05-15 01:40 Tue Comcast (Plainfield, NJ) 53.33 km 18.36 ms 209.72 Mbit/s 38.34 Mbit/s http://www.speedtest.net/result/7310339912.png 2018-05-07 01:27 Mon Comcast (Plainfield, NJ) 53.33 km 28.079 ms 305.67 Mbit/s 40.64 Mbit/s http://www.speedtest.net/result/7288575952.png 2018-04-27 23:30 Fri Verizon (Wall, NJ) 47.92 km 28.883 ms 449.96 Mbit/s 34.32 Mbit/s http://www.speedtest.net/result/7264909243.png 2018-02-18 00:13 Sun Comcast (Plainfield, NJ) 53.33 km 31.048 ms 454.24 Mbit/s 32.82 Mbit/s http://www.speedtest.net/result/7068272475.png 2018-01-30 00:42 Tue Comcast (Plainfield, NJ) 53.33 km 33.141 ms 194.56 Mbit/s 36.92 Mbit/s http://www.speedtest.net/result/7012389384.png 2017-11-30 00:41 Thu Comcast (Plainfield, NJ) 53.33 km 26.83 ms 243.64 Mbit/s 37.84 Mbit/s http://www.speedtest.net/result/6836691639.png 2017-11-24 06:28 Fri Verizon (Wall, NJ) 47.92 km 31.777 ms 124.27 Mbit/s 37.91 Mbit/s http://www.speedtest.net/result/6821079187.png 2017-11-22 00:51 Wed Verizon (Wall, NJ) 47.92 km 29.036 ms 104.07 Mbit/s 32.98 Mbit/s http://www.speedtest.net/result/6814773406.png 2017-11-22 00:50 Wed Comcast (Plainfield, NJ) 53.33 km 32.284 ms 151.34 Mbit/s 35.94 Mbit/s http://www.speedtest.net/result/6814772225.png 2017-11-19 02:03 Sun Comcast (Plainfield, NJ) 53.33 km 31.566 ms 340.91 Mbit/s 37.11 Mbit/s http://www.speedtest.net/result/6806512900.png 2017-11-15 02:10 Wed Comcast (Plainfield, NJ) 53.33 km 32.582 ms 215.38 Mbit/s 36.58 Mbit/s http://www.speedtest.net/result/6794763676.png 2017-10-30 03:15 Mon Verizon (Wall, NJ) 47.92 km 35.798 ms 139.1 Mbit/s 38.08 Mbit/s http://www.speedtest.net/result/6748779698.png 2017-10-23 22:54 Mon Comcast (Plainfield, NJ) 53.33 km 29.066 ms 575.97 Mbit/s 32.16 Mbit/s http://www.speedtest.net/result/6731973071.png 2017-09-28 18:16 Thu Comcast (Plainfield, NJ) 50.04 km 28.947 ms 130.21 Mbit/s 24.07 Mbit/s http://www.speedtest.net/result/6664123941.png 2017-09-26 13:44 Tue Comcast (Plainfield, NJ) 50.04 km 28.363 ms 295.87 Mbit/s 31.22 Mbit/s http://www.speedtest.net/result/6657384381.png 2017-09-25 17:19 Mon Comcast (Plainfield, NJ) 50.04 km 29.176 ms 395.2 Mbit/s 38 Mbit/s http://www.speedtest.net/result/6654849755.png 2017-09-02 04:00 Sat Comcast (Plainfield, NJ) 49.69 km 27.644 ms 175.76 Mbit/s 10.59 Mbit/s http://www.speedtest.net/result/6590501893.png 2017-09-01 04:00 Fri T-Mobile (West Norriton, PA) 71.73 km 33.144 ms 164.49 Mbit/s 11.73 Mbit/s http://www.speedtest.net/result/6587743556.png 2017-08-31 04:00 Thu Comcast (Plainfield, NJ) 49.69 km 31.556 ms 215.63 Mbit/s 9.13 Mbit/s http://www.speedtest.net/result/6584809346.png
September 3, 20187 yr Community Expert 56 minutes ago, opentoe said: I have no idea on what to do. Have you looked and asked at the support thread for that plugin?
September 3, 20187 yr Author 2 hours ago, trurl said: Have you looked and asked at the support thread for that plugin? I didn't even think it would be the plug-in itself so I ran the GUI and came back with similar results. root@SUN:/boot/speedtest# speedtest Retrieving speedtest.net configuration... Testing from Comcast Cable (69.142.83.135)... Retrieving speedtest.net server list... Selecting best server based on ping... Hosted by Comcast (Plainfield, NJ) [53.33 km]: 27.366 ms Testing download speed................................................................................ Download: 375.99 Mbit/s Testing upload speed................................................................................................ Upload: 41.26 Mbit/s With a 1Gbit service and speaking to a couple Comcast engineers I should be getting 700-800 Mbit consistently.
October 13, 20187 yr Author On 9/3/2018 at 1:28 AM, John_M said: Isn't this a question you should be asking your service provider? Not at all, because if I hook up a Windows desktop to that same line/node I get 700-900 Mbps on all speed tests. I have to try to make sure the speed test is using an SSD drive and not a mechanical.
October 13, 20187 yr Strangely enough, I've noticed this as well. First I thought it had something to do with the bonding I have set up with my 4 intel NICs. I've dropped them, rebuilt them, moved them around my switch, switch switches, and tested connecting 1, 2, and all 4, directly to my home's core switch. Same results. I'm debating on rolling back, but I have hesitations doing so. Nevertheless, I'm extremely interested in any resolutions to this situation. Oh yeah, I too have 1Gbps service to my residence. Can confirm all other devices on the network can achieve at least 850+Mbps...
October 16, 20196 yr On 10/13/2018 at 11:29 PM, debit lagos said: Strangely enough, I've noticed this as well. First I thought it had something to do with the bonding I have set up with my 4 intel NICs. I've dropped them, rebuilt them, moved them around my switch, switch switches, and tested connecting 1, 2, and all 4, directly to my home's core switch. Same results. I'm debating on rolling back, but I have hesitations doing so. Nevertheless, I'm extremely interested in any resolutions to this situation. Oh yeah, I too have 1Gbps service to my residence. Can confirm all other devices on the network can achieve at least 850+Mbps... Same thing here! I have a Gigabit Internet Connection which works on all devices. But to add more confusion to the whole situation my setup behaves in strange ways... Nextcloud (Docker installation, bridge mode) Downloads: Gigabit speed internally (server with local ip --> client pc) Downloads: only 30 mbit/s over the internet (public ip --> client pc) Plex Media Server (Docker installtion, bridge mode) Sync works at over 100 mbit/s over internet Speedtest plugin The same 30 - 40 mbit/s for upload (like Nextcloud Docker) and only around 500 mbit/s for download Windows 10 (VM) gets Gigabit speeds in speed tests over the same bloody network interface FTP 300 to 400 Mbit/s via Internet Gigabit via local network And to reply to the most common responses beforehand... Yes, my ISP speeds are indeed confirmed working via Speedtests and external testing The network infrastructure is working (otherwise I woudn't be getting 1000 mbit/s internally when using FTP/SMB) The system is not under-powered i7-4790k 24 GB of RAM Gigabit Ethernet Port SSD for Cache (pretty much empty) Docker Image and all appdata is on an unassigned SSD So with all of this out of the way...where on earth is the damn bottleneck in my system?! Edited October 16, 20196 yr by InvicTech
October 21, 20196 yr Update: After fiddling around with reverse proxies and ssl, I apparently got Nextcloud working as intended.... I setup the "Nginx Proxy Manager"-Docker and added the SSL-Certificates and the host proxies and now everything seems to be working great. + I can use subdomains on a single port instead of having everything port forwarded
October 21, 20196 yr Glad to hear that you got this sorted (saw your email about this as well). Just for future reference, if there is ever a bottleneck like this that is only seen over the WAN but never the LAN, Unraid is very unlikely to be the culprit. It is more than likely either an issue with the application you're using, the network, or your ISP. With gigabit Internet connections, Speedtests can be unreliable as some providers don't have the ability to support 1gbps tests reliably/consistently. That's a lot of bandwidth! Another issue can be the use of proxies. If you don't have port forwarding configured properly, you can easily end up in a situation where you're transmitting all your data through a proxy service which then limits the speed at which the endpoint can receive the data.
