comet424 Posted November 30, 2018 Share Posted November 30, 2018 hi i not sure but i find rsync very slow its taken over 1 Week to transfer 3TBs of data of 6 TB it seems Copy through windows from Unraid to Unraid is faster rsync -avzu -s --stats --numeric-ids --progress -e "ssh -i /root/.ssh/id_rsa -T -o Compression=no -x" "/mnt/user/Videos/TV Shows" "root@mitchtower:/mnt/user/Videos/TV Shows" >> /boot/logs/cronlogs/MitchServerVideos.log but id also like to see a Percentage of current file and overall progress like Freenas offered.. but mainly is there a way to speed rsync i have no idea why its so slow.. as copying is faster Link to comment
John_M Posted November 30, 2018 Share Posted November 30, 2018 32 minutes ago, comet424 said: but id also like to see a Percentage of current file and overall progress Have you tried using the -i flag, or the --progress flag? Link to comment
comet424 Posted November 30, 2018 Author Share Posted November 30, 2018 im not home so cant test but i havent what does the -i do and i remember there is a comma and more options do you have to do -i --option name Link to comment
John_M Posted November 30, 2018 Share Posted November 30, 2018 --progress show progress during transfer -i, --itemize-changes output a change-summary for all updates I suspect you'll find --progress more useful than -i. Link to comment
comet424 Posted November 30, 2018 Author Share Posted November 30, 2018 oh i already have --progress i really have no idea when you put things in like do you type it -i, --itemsize.. with the comma but i have the progress it shows it when a file is complete 100% but it doesnt show a running count say a file 5% then 20% etc.. and it doesnt show over all entire %progress overall so 25% complete of the entire rysnc procedure.. so 25% complete of the entire area its rsyncing Link to comment
John_M Posted November 30, 2018 Share Posted November 30, 2018 There isn't a comma. You either use the long form of the option --itemize-changes or the short form -i It's no different from some of the other flags you've used, such as -a, --archive archive mode; equals -rlptgoD (no -H,-A,-X) which also doesn't use a comma. Link to comment
JorgeB Posted November 30, 2018 Share Posted November 30, 2018 Don't use -z (compression), it should only be used for very low bandwidth transfers and/or highly compressible data. Link to comment
comet424 Posted November 30, 2018 Author Share Posted November 30, 2018 ok i removed the -z and testing as for the -i and a comma reason why i ask. is its -i comma and then they give 4 or 5 different options for that -I reason why i ask as for the other ones i just copied and pasted from another link that was using it for syncing but what confuused me was the comma then more options its listed when you just type rysnc Link to comment
comet424 Posted November 30, 2018 Author Share Posted November 30, 2018 so from rysncing its showing the speed i only getting like 497 k/bs so a 200 meg file takes 8 min to copy over the network of a Gigabit so somewhat is wrong even though 1 hd is 7200rpm the other is 5900 rpm old drive still should be faster then that... what could cause it being slow... and this is what i ment with the commas how you choose the options after the comma -i, --itemize-changes output a change-summary for all updates --out-format=FORMAT output updates using the specified FORMAT --log-file=FILE log what we're doing to the specified FILE --log-file-format=FMT log updates using the specified FMT --password-file=FILE read daemon-access password from FILE --list-only list the files instead of copying them --bwlimit=RATE limit socket I/O bandwidth --outbuf=N|L|B set output buffering to None, Line, or Block --write-batch=FILE write a batched update to FILE --only-write-batch=FILE like --write-batch but w/o updating destination --read-batch=FILE read a batched update from FILE --protocol=NUM force an older protocol version to be used --iconv=CONVERT_SPEC request charset conversion of filenames --checksum-seed=NUM Link to comment
JorgeB Posted November 30, 2018 Share Posted November 30, 2018 7 minutes ago, comet424 said: i only getting like 497 k/bs Is that without compression? If yes something else wrong, I usually get around 80MB/s average, transfer around 300GB per hour. Link to comment
comet424 Posted November 30, 2018 Author Share Posted November 30, 2018 ya without the compression im getting for my tv shows im just backup.. its faster to just put my dvd and blue rays in the drive hit play faster then copying my backups to a 2nd computer TV Shows/Comedy/My Wife and Kids/Season 2/My Wife and Kids - S02E01 - Moms Away (1).mp4 252,160,859 100% 497.60kB/s 0:08:14 (xfr#3, ir-chk=1033/13285) TV Shows/Comedy/My Wife and Kids/Season 2/My Wife and Kids - S02E02 - Moms Away (2).mp4 253,153,727 100% 499.32kB/s 0:08:15 (xfr#4, ir-chk=1032/13285) TV Shows/Comedy/My Wife and Kids/Season 2/My Wife and Kids - S02E03 - No Rules.mp4 253,367,040 100% 499.83kB/s 0:08:15 (xfr#5, ir-chk=1031/13285) TV Shows/Comedy/My Wife and Kids/Season 2/My Wife and Kids - S02E04 - Perfect Dad.mp4 252,741,432 100% 499.92kB/s 0:08:13 (xfr#6, ir-chk=1030/13285) TV Shows/Comedy/My Wife and Kids/Season 2/My Wife and Kids - S02E05 - Thru Thick and Thin.mp4 254,687,317 100% 499.92kB/s 0:08:17 (xfr#7, ir-chk=1029/13285) Link to comment
Hoopster Posted November 30, 2018 Share Posted November 30, 2018 1 hour ago, johnnie.black said: I usually get around 80MB/s average, transfer around 300GB per hour. 45 minutes ago, comet424 said: ya without the compression I see about the same performance as @johnnie.black so, it would appear you have other network issues slowing down your transfers. In my last rsync backup on Monday, the largest amount of new data transferred in any one share was 33GB. This was copied over to the backup server in about 6.5 minutes, so, roughly the same 300GB per hour that he is seeing. Link to comment
John_M Posted November 30, 2018 Share Posted November 30, 2018 3 hours ago, comet424 said: its -i comma and then they give 4 or 5 different options for that -I reason why i ask No they don't. You're misunderstanding the help text or the man page for the rsync command. The comma isn't a part of the -i option. Just like it isn't a part of the -a option that I showed you. The hyphen followed by a single letter is the short form of the option. The double hyphen followed by a longer string of characters is the long form of the option. The comma is just a separator in the help text. You don't use it in the actual command. 3 hours ago, comet424 said: and this is what i ment with the commas how you choose the options after the comma -i, --itemize-changes output a change-summary for all updates --out-format=FORMAT output updates using the specified FORMAT --log-file=FILE log what we're doing to the specified FILE Those are three unrelated options. --out-format=FORMAT has nothing to do with the -i option. Neither has --log-file=FILE. Link to comment
JorgeB Posted December 1, 2018 Share Posted December 1, 2018 Run some single thread iperf tests to check all is well with your network bandwidth. Link to comment
Hoopster Posted December 1, 2018 Share Posted December 1, 2018 @comet424 Here is a thread that discusses iperf use between two unRAID servers. In my example, I ran 10 threads to saturate network, but, as johnnie.black mentioned, you may wish to try just one at first to see what that reports. Link to comment
comet424 Posted December 1, 2018 Author Share Posted December 1, 2018 i ran the example i guess that was 10 times?? well here is the report it showed root@MitchTower:~# iperf3 -c 192.168.0.3 -t 10 -P 10 Connecting to host 192.168.0.3, port 5201 [ 4] local 192.168.0.8 port 55652 connected to 192.168.0.3 port 5201 [ 6] local 192.168.0.8 port 55654 connected to 192.168.0.3 port 5201 [ 8] local 192.168.0.8 port 55656 connected to 192.168.0.3 port 5201 [ 10] local 192.168.0.8 port 55658 connected to 192.168.0.3 port 5201 [ 12] local 192.168.0.8 port 55660 connected to 192.168.0.3 port 5201 [ 14] local 192.168.0.8 port 55662 connected to 192.168.0.3 port 5201 [ 16] local 192.168.0.8 port 55664 connected to 192.168.0.3 port 5201 [ 18] local 192.168.0.8 port 55666 connected to 192.168.0.3 port 5201 [ 20] local 192.168.0.8 port 55668 connected to 192.168.0.3 port 5201 [ 22] local 192.168.0.8 port 55670 connected to 192.168.0.3 port 5201 [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-1.00 sec 1.24 MBytes 10.4 Mbits/sec 0 56.6 KBytes [ 6] 0.00-1.00 sec 1.29 MBytes 10.8 Mbits/sec 0 66.5 KBytes [ 8] 0.00-1.00 sec 1.91 MBytes 16.1 Mbits/sec 0 93.3 KBytes [ 10] 0.00-1.00 sec 2.03 MBytes 17.0 Mbits/sec 0 97.6 KBytes [ 12] 0.00-1.00 sec 1.18 MBytes 9.89 Mbits/sec 0 42.4 KBytes [ 14] 0.00-1.00 sec 1.18 MBytes 9.93 Mbits/sec 0 42.4 KBytes [ 16] 0.00-1.00 sec 1.65 MBytes 13.9 Mbits/sec 0 80.6 KBytes [ 18] 0.00-1.00 sec 1.23 MBytes 10.3 Mbits/sec 0 53.7 KBytes [ 20] 0.00-1.00 sec 1.17 MBytes 9.80 Mbits/sec 0 41.0 KBytes [ 22] 0.00-1.00 sec 1.06 MBytes 8.85 Mbits/sec 0 41.0 KBytes [SUM] 0.00-1.00 sec 13.9 MBytes 117 Mbits/sec 0 - - - - - - - - - - - - - - - - - - - - - - - - - [ 4] 1.00-2.00 sec 891 KBytes 7.30 Mbits/sec 0 56.6 KBytes [ 6] 1.00-2.00 sec 954 KBytes 7.82 Mbits/sec 0 66.5 KBytes [ 8] 1.00-2.00 sec 1.30 MBytes 10.9 Mbits/sec 0 93.3 KBytes [ 10] 1.00-2.00 sec 1.49 MBytes 12.5 Mbits/sec 0 97.6 KBytes [ 12] 1.00-2.00 sec 891 KBytes 7.30 Mbits/sec 0 42.4 KBytes [ 14] 1.00-2.00 sec 891 KBytes 7.30 Mbits/sec 0 42.4 KBytes [ 16] 1.00-2.00 sec 1.49 MBytes 12.5 Mbits/sec 0 80.6 KBytes [ 18] 1.00-2.00 sec 891 KBytes 7.30 Mbits/sec 0 53.7 KBytes [ 20] 1.00-2.00 sec 891 KBytes 7.30 Mbits/sec 0 41.0 KBytes [ 22] 1.00-2.00 sec 1018 KBytes 8.34 Mbits/sec 0 41.0 KBytes [SUM] 1.00-2.00 sec 10.6 MBytes 88.6 Mbits/sec 0 - - - - - - - - - - - - - - - - - - - - - - - - - [ 4] 2.00-3.00 sec 1018 KBytes 8.34 Mbits/sec 0 56.6 KBytes [ 6] 2.00-3.00 sec 954 KBytes 7.82 Mbits/sec 0 66.5 KBytes [ 8] 2.00-3.00 sec 1.43 MBytes 12.0 Mbits/sec 0 93.3 KBytes [ 10] 2.00-3.00 sec 1.74 MBytes 14.6 Mbits/sec 0 97.6 KBytes [ 12] 2.00-3.00 sec 1018 KBytes 8.34 Mbits/sec 0 42.4 KBytes [ 14] 2.00-3.00 sec 1018 KBytes 8.34 Mbits/sec 0 42.4 KBytes [ 16] 2.00-3.00 sec 1.30 MBytes 10.9 Mbits/sec 0 80.6 KBytes [ 18] 2.00-3.00 sec 1018 KBytes 8.34 Mbits/sec 0 53.7 KBytes [ 20] 2.00-3.00 sec 891 KBytes 7.30 Mbits/sec 0 41.0 KBytes [ 22] 2.00-3.00 sec 891 KBytes 7.30 Mbits/sec 0 41.0 KBytes [SUM] 2.00-3.00 sec 11.1 MBytes 93.3 Mbits/sec 0 - - - - - - - - - - - - - - - - - - - - - - - - - [ 4] 3.00-4.00 sec 891 KBytes 7.30 Mbits/sec 0 56.6 KBytes [ 6] 3.00-4.00 sec 954 KBytes 7.82 Mbits/sec 0 66.5 KBytes [ 8] 3.00-4.00 sec 1.55 MBytes 13.0 Mbits/sec 0 93.3 KBytes [ 10] 3.00-4.00 sec 1.49 MBytes 12.5 Mbits/sec 0 97.6 KBytes [ 12] 3.00-4.00 sec 891 KBytes 7.30 Mbits/sec 0 42.4 KBytes [ 14] 3.00-4.00 sec 891 KBytes 7.30 Mbits/sec 0 42.4 KBytes [ 16] 3.00-4.00 sec 1.30 MBytes 10.9 Mbits/sec 0 80.6 KBytes [ 18] 3.00-4.00 sec 891 KBytes 7.30 Mbits/sec 0 53.7 KBytes [ 20] 3.00-4.00 sec 1018 KBytes 8.34 Mbits/sec 0 41.0 KBytes [ 22] 3.00-4.00 sec 1018 KBytes 8.34 Mbits/sec 0 41.0 KBytes [SUM] 3.00-4.00 sec 10.8 MBytes 90.2 Mbits/sec 0 - - - - - - - - - - - - - - - - - - - - - - - - - [ 4] 4.00-5.00 sec 1018 KBytes 8.34 Mbits/sec 0 56.6 KBytes [ 6] 4.00-5.00 sec 954 KBytes 7.82 Mbits/sec 0 66.5 KBytes [ 8] 4.00-5.00 sec 1.37 MBytes 11.5 Mbits/sec 0 93.3 KBytes [ 10] 4.00-5.00 sec 1.74 MBytes 14.6 Mbits/sec 0 97.6 KBytes [ 12] 4.00-5.00 sec 1018 KBytes 8.34 Mbits/sec 0 42.4 KBytes [ 14] 4.00-5.00 sec 1018 KBytes 8.34 Mbits/sec 0 42.4 KBytes [ 16] 4.00-5.00 sec 1.30 MBytes 10.9 Mbits/sec 0 80.6 KBytes [ 18] 4.00-5.00 sec 891 KBytes 7.30 Mbits/sec 0 53.7 KBytes [ 20] 4.00-5.00 sec 891 KBytes 7.30 Mbits/sec 0 41.0 KBytes [ 22] 4.00-5.00 sec 891 KBytes 7.30 Mbits/sec 0 41.0 KBytes [SUM] 4.00-5.00 sec 10.9 MBytes 91.7 Mbits/sec 0 - - - - - - - - - - - - - - - - - - - - - - - - - [ 4] 5.00-6.00 sec 891 KBytes 7.30 Mbits/sec 0 56.6 KBytes [ 6] 5.00-6.00 sec 954 KBytes 7.82 Mbits/sec 0 66.5 KBytes [ 8] 5.00-6.00 sec 1.49 MBytes 12.5 Mbits/sec 0 93.3 KBytes [ 10] 5.00-6.00 sec 1.74 MBytes 14.6 Mbits/sec 0 97.6 KBytes [ 12] 5.00-6.00 sec 891 KBytes 7.30 Mbits/sec 0 42.4 KBytes [ 14] 5.00-6.00 sec 891 KBytes 7.30 Mbits/sec 0 42.4 KBytes [ 16] 5.00-6.00 sec 1.49 MBytes 12.5 Mbits/sec 0 80.6 KBytes [ 18] 5.00-6.00 sec 1018 KBytes 8.34 Mbits/sec 0 53.7 KBytes [ 20] 5.00-6.00 sec 1018 KBytes 8.34 Mbits/sec 0 41.0 KBytes [ 22] 5.00-6.00 sec 1018 KBytes 8.34 Mbits/sec 0 41.0 KBytes [SUM] 5.00-6.00 sec 11.2 MBytes 94.4 Mbits/sec 0 - - - - - - - - - - - - - - - - - - - - - - - - - [ 4] 6.00-7.00 sec 1018 KBytes 8.34 Mbits/sec 0 56.6 KBytes [ 6] 6.00-7.00 sec 954 KBytes 7.82 Mbits/sec 0 66.5 KBytes [ 8] 6.00-7.00 sec 1.24 MBytes 10.4 Mbits/sec 0 93.3 KBytes [ 10] 6.00-7.00 sec 1.68 MBytes 14.1 Mbits/sec 0 97.6 KBytes [ 12] 6.00-7.00 sec 891 KBytes 7.30 Mbits/sec 0 42.4 KBytes [ 14] 6.00-7.00 sec 891 KBytes 7.30 Mbits/sec 0 42.4 KBytes [ 16] 6.00-7.00 sec 1.30 MBytes 10.9 Mbits/sec 0 80.6 KBytes [ 18] 6.00-7.00 sec 891 KBytes 7.30 Mbits/sec 0 53.7 KBytes [ 20] 6.00-7.00 sec 891 KBytes 7.30 Mbits/sec 0 41.0 KBytes [ 22] 6.00-7.00 sec 891 KBytes 7.30 Mbits/sec 0 41.0 KBytes [SUM] 6.00-7.00 sec 10.5 MBytes 88.1 Mbits/sec 0 - - - - - - - - - - - - - - - - - - - - - - - - - [ 4] 7.00-8.00 sec 891 KBytes 7.30 Mbits/sec 0 56.6 KBytes [ 6] 7.00-8.00 sec 1.12 MBytes 9.38 Mbits/sec 0 66.5 KBytes [ 8] 7.00-8.00 sec 1.43 MBytes 12.0 Mbits/sec 0 93.3 KBytes [ 10] 7.00-8.00 sec 1.49 MBytes 12.5 Mbits/sec 0 97.6 KBytes [ 12] 7.00-8.00 sec 1018 KBytes 8.34 Mbits/sec 0 42.4 KBytes [ 14] 7.00-8.00 sec 1018 KBytes 8.34 Mbits/sec 0 42.4 KBytes [ 16] 7.00-8.00 sec 1.30 MBytes 10.9 Mbits/sec 0 80.6 KBytes [ 18] 7.00-8.00 sec 1018 KBytes 8.34 Mbits/sec 0 53.7 KBytes [ 20] 7.00-8.00 sec 1018 KBytes 8.34 Mbits/sec 0 41.0 KBytes [ 22] 7.00-8.00 sec 1018 KBytes 8.34 Mbits/sec 0 41.0 KBytes [SUM] 7.00-8.00 sec 11.2 MBytes 93.8 Mbits/sec 0 - - - - - - - - - - - - - - - - - - - - - - - - - [ 4] 8.00-9.00 sec 1018 KBytes 8.34 Mbits/sec 0 56.6 KBytes [ 6] 8.00-9.00 sec 954 KBytes 7.82 Mbits/sec 0 66.5 KBytes [ 8] 8.00-9.00 sec 1.37 MBytes 11.5 Mbits/sec 0 93.3 KBytes [ 10] 8.00-9.00 sec 1.74 MBytes 14.6 Mbits/sec 0 97.6 KBytes [ 12] 8.00-9.00 sec 891 KBytes 7.30 Mbits/sec 0 42.4 KBytes [ 14] 8.00-9.00 sec 891 KBytes 7.30 Mbits/sec 0 42.4 KBytes [ 16] 8.00-9.00 sec 1.30 MBytes 10.9 Mbits/sec 0 80.6 KBytes [ 18] 8.00-9.00 sec 891 KBytes 7.30 Mbits/sec 0 53.7 KBytes [ 20] 8.00-9.00 sec 891 KBytes 7.30 Mbits/sec 0 41.0 KBytes [ 22] 8.00-9.00 sec 891 KBytes 7.30 Mbits/sec 0 41.0 KBytes [SUM] 8.00-9.00 sec 10.7 MBytes 89.7 Mbits/sec 0 - - - - - - - - - - - - - - - - - - - - - - - - - [ 4] 9.00-10.00 sec 891 KBytes 7.30 Mbits/sec 0 56.6 KBytes [ 6] 9.00-10.00 sec 954 KBytes 7.82 Mbits/sec 0 66.5 KBytes [ 8] 9.00-10.00 sec 1.49 MBytes 12.5 Mbits/sec 0 93.3 KBytes [ 10] 9.00-10.00 sec 1.49 MBytes 12.5 Mbits/sec 0 97.6 KBytes [ 12] 9.00-10.00 sec 1018 KBytes 8.34 Mbits/sec 0 42.4 KBytes [ 14] 9.00-10.00 sec 1018 KBytes 8.34 Mbits/sec 0 42.4 KBytes [ 16] 9.00-10.00 sec 1.30 MBytes 10.9 Mbits/sec 0 80.6 KBytes [ 18] 9.00-10.00 sec 1018 KBytes 8.34 Mbits/sec 0 53.7 KBytes [ 20] 9.00-10.00 sec 1018 KBytes 8.34 Mbits/sec 0 41.0 KBytes [ 22] 9.00-10.00 sec 891 KBytes 7.30 Mbits/sec 0 41.0 KBytes [SUM] 9.00-10.00 sec 10.9 MBytes 91.7 Mbits/sec 0 - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 9.56 MBytes 8.02 Mbits/sec 0 sender [ 4] 0.00-10.00 sec 9.31 MBytes 7.81 Mbits/sec receiver [ 6] 0.00-10.00 sec 9.87 MBytes 8.28 Mbits/sec 0 sender [ 6] 0.00-10.00 sec 9.50 MBytes 7.97 Mbits/sec receiver [ 8] 0.00-10.00 sec 14.6 MBytes 12.2 Mbits/sec 0 sender [ 8] 0.00-10.00 sec 14.2 MBytes 11.9 Mbits/sec receiver [ 10] 0.00-10.00 sec 16.6 MBytes 14.0 Mbits/sec 0 sender [ 10] 0.00-10.00 sec 16.3 MBytes 13.6 Mbits/sec receiver [ 12] 0.00-10.00 sec 9.51 MBytes 7.97 Mbits/sec 0 sender [ 12] 0.00-10.00 sec 9.26 MBytes 7.76 Mbits/sec receiver [ 14] 0.00-10.00 sec 9.51 MBytes 7.98 Mbits/sec 0 sender [ 14] 0.00-10.00 sec 9.29 MBytes 7.79 Mbits/sec receiver [ 16] 0.00-10.00 sec 13.8 MBytes 11.6 Mbits/sec 0 sender [ 16] 0.00-10.00 sec 13.5 MBytes 11.3 Mbits/sec receiver [ 18] 0.00-10.00 sec 9.56 MBytes 8.02 Mbits/sec 0 sender [ 18] 0.00-10.00 sec 9.27 MBytes 7.78 Mbits/sec receiver [ 20] 0.00-10.00 sec 9.50 MBytes 7.97 Mbits/sec 0 sender [ 20] 0.00-10.00 sec 9.27 MBytes 7.77 Mbits/sec receiver [ 22] 0.00-10.00 sec 9.38 MBytes 7.87 Mbits/sec 0 sender [ 22] 0.00-10.00 sec 9.24 MBytes 7.75 Mbits/sec receiver [SUM] 0.00-10.00 sec 112 MBytes 93.8 Mbits/sec 0 sender [SUM] 0.00-10.00 sec 109 MBytes 91.5 Mbits/sec receiver iperf Done. Link to comment
Hoopster Posted December 1, 2018 Share Posted December 1, 2018 14 minutes ago, comet424 said: [SUM] 0.00-10.00 sec 109 MBytes 91.5 Mbits/sec receiver iperf Done. You're only getting about 90 Mbps. That's as good as you can expect if one or both of your NICs is only 100 megabit. If it is a gigabit LAN, something is misconfigured. What does ethtool report for the speed of your NICs? Link to comment
comet424 Posted December 1, 2018 Author Share Posted December 1, 2018 im not sure what setting to use that ethtool -h shows soooo many options and i truly dont know the order its a big listing what would be the proper command line to get what you need and they both 1 gigabit lan nics Link to comment
Hoopster Posted December 1, 2018 Share Posted December 1, 2018 4 minutes ago, comet424 said: what would be the proper command line ethtool eth0 (or whatever the number of your NIC is) Somewhere in the middle of the output you'll see current NIC speed. Post the output for NICs on both servers. Link to comment
comet424 Posted December 1, 2018 Author Share Posted December 1, 2018 server 1 -------------- oot@MitchTower:~# ethtool eth0 Settings for eth0: Supported ports: [ TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Supported pause frame use: No Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Advertised pause frame use: Symmetric Receive-only Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Link partner advertised pause frame use: Symmetric Receive-only Link partner advertised auto-negotiation: Yes Link partner advertised FEC modes: Not reported Speed: 1000Mb/s Duplex: Full Port: MII PHYAD: 0 Transceiver: internal Auto-negotiation: on Supports Wake-on: pumbg Wake-on: g Current message level: 0x00000033 (51) drv probe ifdown ifup Link detected: yes server 2 --------------- root@Tower:~# ethtool eth0 Settings for eth0: Supported ports: [ TP ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Supported pause frame use: No Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Advertised pause frame use: No Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Speed: 1000Mb/s Duplex: Full Port: Twisted Pair PHYAD: 1 Transceiver: internal Auto-negotiation: on MDI-X: on (auto) Supports Wake-on: pumbg Wake-on: g Current message level: 0x00000007 (7) drv probe link Link detected: yes Link to comment
Hoopster Posted December 1, 2018 Share Posted December 1, 2018 Both NICs are reporting a speed of 1000Mbps. In that case, you have a problem with switch ports, Ethernet cables, etc. Start by checking your switch ports and see what speed they are reporting if you have a managed switch or ports built into the router. Verify that your switch ports, are in fact gigabit ports. Somewhere, you are limited to 100Mbps speeds. Link to comment
comet424 Posted December 1, 2018 Author Share Posted December 1, 2018 ill check tommorow checking everything i have 2 gigabit switchs but we have had power out/ surges lately maybe it cooked my switchs ill test it tommorow and report back when i find more info Link to comment
itimpi Posted December 1, 2018 Share Posted December 1, 2018 It is also worth pointing out that being limited to 100 Mbps can be a cabling Issue. You only require two pairs of connectors in the cable to be working to get 100 Mbps while 1000 Mbps requires all four pairs in the cable to be working. This can be confusing as the cable still appears to work but you silently get degraded to 100 Mbps. Link to comment
comet424 Posted December 1, 2018 Author Share Posted December 1, 2018 @itimpi is there a tool i can buy that tests for silent wire degrade that i can just plug in and says this wire is silently degrading or your not getting your max speed of this cable etc? Link to comment
NewDisplayName Posted December 1, 2018 Share Posted December 1, 2018 U can also test if u have some energy saving enabled on any ports of any router/switch Link to comment
