Still seeing XFS cache drives show up under unassigned devices (redundant to the usual Cache Devices section).  Is there any way to hide these?
Mine is a XFS formated cache drive - it does not show up in UD.....\\
myk
  • Replies 814
  • Views 209.6k
I just reinstalled the latest version and the extra drive disappeared.  Yay!  Thanks for the great work, gfjardim!
A new copy of Unassigned Devices Log has been uploaded: http://gfjardim.maxfiles.org/prj0gprw1/iqw9jp
Will  have to wait until I have new drives available for testing.
So no obvious stupid user errors?
I tried to format 2 of the 3 drives. The third one is ready now. Guess I'll have to fire up my old server to format them to XFS.
No. This is about parted and gpt partitions not being aligned.
tr0910, can you please update your plugin and test it again?
Yes, it formats a Samsung 2tb 203WI as XFS fine.  Just not working with larger drives.
Can you update and try it again?
I had the drives in the other server and you already had it updated.  Now I formatted a 3tb in the old server.
Moved them back to the production server and formatted the third one there with your lastest version.  Thanks
Last question, did you see my comments earlier in this thread about Areca?  This is the only thing I have outstanding.
http://lime-technology.com/forum/index.php?topic=38635.msg402180#msg402180
So you confirm format is working for >2TB drives, right?
I'll take a look into your Areca problem.
I'll get 3tb of data onto a drive and add it to the array and let you know.  That will tell us more.  (converting from rfs to xfs and the formatting was a pain prior to today)
Getting better and better, thanks for the awesome plugin and the even more awesome support.
Did you intend for all this to show when the plugin is updated to 2015.09.18b?  This also shows up in the Unassigned Devices tab of Main.
| Installing new package /boot/config/plugins/unassigned.devices/unassigned.devices-2015.09.18b.txz
Verifying package unassigned.devices-2015.09.18b.txz.
Installing package unassigned.devices-2015.09.18b.txz:
PACKAGE DESCRIPTION:
Package unassigned.devices-2015.09.18b.txz installed.
Array
[DEVLINKS] => /dev/disk/by-id/ata-WDC_WD10JFCX-68N6GN0_WD-WXB1A2493019-part1 /dev/disk/by-id/wwn-0x50014ee6046e4063-part1 /dev/disk/by-uuid/2c07237d-9a0e-4703-a74c-bfdb2068a187
[DEVNAME] => /dev/sdj1
[DEVPATH] => /devices/pci0000:00/0000:00:1c.4/0000:05:00.0/ata10/host9/target9:0:0/9:0:0:0/block/sdj/sdj1
[DEVTYPE] => partition
[iD_ATA] => 1
[iD_ATA_DOWNLOAD_MICROCODE] => 1
[iD_ATA_FEATURE_SET_APM] => 1
[iD_ATA_FEATURE_SET_APM_CURRENT_VALUE] => 128
[iD_ATA_FEATURE_SET_APM_ENABLED] => 1
[iD_ATA_FEATURE_SET_HPA] => 1
[iD_ATA_FEATURE_SET_HPA_ENABLED] => 1
[iD_ATA_FEATURE_SET_PM] => 1
[iD_ATA_FEATURE_SET_PM_ENABLED] => 1
[iD_ATA_FEATURE_SET_PUIS] => 1
[iD_ATA_FEATURE_SET_PUIS_ENABLED] => 0
[iD_ATA_FEATURE_SET_SECURITY] => 1
[iD_ATA_FEATURE_SET_SECURITY_ENABLED] => 0
[iD_ATA_FEATURE_SET_SECURITY_ENHANCED_ERASE_UNIT_MIN] => 202
[iD_ATA_FEATURE_SET_SECURITY_ERASE_UNIT_MIN] => 202
[iD_ATA_FEATURE_SET_SECURITY_FROZEN] => 1
[iD_ATA_FEATURE_SET_SMART] => 1
[iD_ATA_FEATURE_SET_SMART_ENABLED] => 1
[iD_ATA_ROTATION_RATE_RPM] => 5400
[iD_ATA_SATA] => 1
[iD_ATA_SATA_SIGNAL_RATE_GEN1] => 1
[iD_ATA_SATA_SIGNAL_RATE_GEN2] => 1
[iD_ATA_WRITE_CACHE] => 1
[iD_ATA_WRITE_CACHE_ENABLED] => 1
[iD_BUS] => ata
[iD_FS_TYPE] => xfs
[iD_FS_USAGE] => filesystem
[iD_FS_UUID] => 2c07237d-9a0e-4703-a74c-bfdb2068a187
[iD_FS_UUID_ENC] => 2c07237d-9a0e-4703-a74c-bfdb2068a187
[iD_MODEL] => WDC_WD10JFCX-68N6GN0
[iD_MODEL_ENC] => WDC\x20WD10JFCX-68N6GN0\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20
[iD_PART_ENTRY_DISK] => 8:144
[iD_PART_ENTRY_NUMBER] => 1
[iD_PART_ENTRY_OFFSET] => 64
[iD_PART_ENTRY_SCHEME] => dos
[iD_PART_ENTRY_SIZE] => 1953525104
[iD_PART_ENTRY_TYPE] => 0x83
[iD_PART_TABLE_TYPE] => dos
[iD_REVISION] => 01.01A01
[iD_SERIAL] => WDC_WD10JFCX-68N6GN0_WD-WXB1A2493019
[iD_SERIAL_SHORT] => WD-WXB1A2493019
[iD_TYPE] => disk
[iD_WWN] => 0x50014ee6046e4063
[iD_WWN_WITH_EXTENSION] => 0x50014ee6046e4063
[MAJOR] => 8
[MINOR] => 145
[sUBSYSTEM] => block
[uDEV_LOG] => 3
[uSEC_INITIALIZED] => 10008532
Nope, that was a debug leftover. Please update again.
Updated.  That problem is fixed.
I am getting a lot of messages on my console:
blockdev: cannot open /dev/sr0: No medium found
sr0 is a DVD drive.
EDIT: Unassigned Devices also shows as wanting to format the DVD.
Quick question and sorry if it's already been asked.  Is it possible that a disc that is not part of the array can still contribute to a "user share?"  I would like to have my SSD drive be part of the Media share, but not part of the array.
Thank you,
craigr
No.  Only array drives and the cache drive can be part of a User Share.
What are you actually trying to achieve?    You could mount the USB drive inside the User Share (using the Unassigned Devices plugin if all you want is visibility of the drive contents through the User Share.
sr0 is a DVD drive.
Thanks for reporting. Will take a look into it soon.
sr0 is a DVD drive.
Can you please send me the output of this command: ls -la /dev/disk/by-id ?
sr0 is a DVD drive.
total 0
drwxr-xr-x 2 root root 520 Sep 19 07:45 ./
drwxr-xr-x 6 root root 120 Sep 19 07:45 ../
lrwxrwxrwx 1 root root  9 Sep 19 07:45 ata-HL-DT-ST_DVDRAM_GH24NS95_K3TD71J1251 -> ../../sr0
lrwxrwxrwx 1 root root  9 Sep 19 07:45 ata-Samsung_SSD_850_PRO_256GB_S1SUNSAF902713T -> ../../sda
lrwxrwxrwx 1 root root  10 Sep 19 07:45 ata-Samsung_SSD_850_PRO_256GB_S1SUNSAF902713T-part1 -> ../../sda1
lrwxrwxrwx 1 root root  9 Sep 19 07:45 ata-WDC_WD10EADS-00L5B1_WD-WCAU47447856 -> ../../sdb
lrwxrwxrwx 1 root root  10 Sep 19 07:45 ata-WDC_WD10EADS-00L5B1_WD-WCAU47447856-part1 -> ../../sdb1
lrwxrwxrwx 1 root root  9 Sep 19 07:45 ata-WDC_WD10EARS-00Y5B1_WD-WCAV55063796 -> ../../sdd
lrwxrwxrwx 1 root root  10 Sep 19 07:45 ata-WDC_WD10EARS-00Y5B1_WD-WCAV55063796-part1 -> ../../sdd1
lrwxrwxrwx 1 root root  9 Sep 19 07:45 ata-WDC_WD20EURS-63S48Y0_WD-WCAZAH868851 -> ../../sdc
lrwxrwxrwx 1 root root  10 Sep 19 07:45 ata-WDC_WD20EURS-63S48Y0_WD-WCAZAH868851-part1 -> ../../sdc1
lrwxrwxrwx 1 root root  9 Sep 19 07:45 ata-WDC_WD5000AACS-00ZUB0_WD-WCASU6424348 -> ../../sdf
lrwxrwxrwx 1 root root  10 Sep 19 07:45 ata-WDC_WD5000AACS-00ZUB0_WD-WCASU6424348-part1 -> ../../sdf1
lrwxrwxrwx 1 root root  9 Sep 19 07:45 usb-SanDisk_Cruzer_351421114FE1B094-0:0 -> ../../sde
lrwxrwxrwx 1 root root  10 Sep 19 07:45 usb-SanDisk_Cruzer_351421114FE1B094-0:0-part1 -> ../../sde1
lrwxrwxrwx 1 root root  9 Sep 19 07:45 wwn-0x5001480000000000 -> ../../sr0
lrwxrwxrwx 1 root root  9 Sep 19 07:45 wwn-0x50014ee1019fceab -> ../../sdb
lrwxrwxrwx 1 root root  10 Sep 19 07:45 wwn-0x50014ee1019fceab-part1 -> ../../sdb1
lrwxrwxrwx 1 root root  9 Sep 19 07:45 wwn-0x50014ee156b8d452 -> ../../sdf
lrwxrwxrwx 1 root root  10 Sep 19 07:45 wwn-0x50014ee156b8d452-part1 -> ../../sdf1
lrwxrwxrwx 1 root root  9 Sep 19 07:45 wwn-0x50014ee25910b533 -> ../../sdd
lrwxrwxrwx 1 root root  10 Sep 19 07:45 wwn-0x50014ee25910b533-part1 -> ../../sdd1
lrwxrwxrwx 1 root root  9 Sep 19 07:45 wwn-0x50014ee2b20ac1e1 -> ../../sdc
lrwxrwxrwx 1 root root  10 Sep 19 07:45 wwn-0x50014ee2b20ac1e1-part1 -> ../../sdc1
lrwxrwxrwx 1 root root  9 Sep 19 07:45 wwn-0x50025388a068e6fc -> ../../sda
lrwxrwxrwx 1 root root  10 Sep 19 07:45 wwn-0x50025388a068e6fc-part1 -> ../../sda1
[glow=red,2,300]UPDATE:[/glow]
###2015.09.19
- Fix: DVD/BluRay drives being included
when updating the plugin via GUI, I saw this:
Verifying package unassigned.devices-2015.09.19a.txz.
Installing package unassigned.devices-2015.09.19a.txz:
Package unassigned.devices-2015.09.19a.txz installed.
Warning: file_put_contents(/var/state/unassigned.devices/unassigned.devices.ini): failed to open stream: No such file or directory in /usr/local/emhttp/plugins/unassigned.devices/include/lib.php on line 42
Warning: touch(): Unable to create file /var/state/unassigned.devices/reload.state because Not a directory in /usr/local/emhttp/plugins/unassigned.devices/scripts/unassigned_mount on line 61
unassigned.devices has been installed.
This plugin requires Dynamix webGui to operate
Copyright 2015, gfjardim
Version: 2015.09.19a
plugin: updated
and going to the Unassigned Devices tab on "Main", I see this:
Warning: file_put_contents(/var/state/unassigned.devices/hdd_temp.json): failed to open stream: No such file or directory in /usr/local/emhttp/plugins/unassigned.devices/include/lib.php on line 103 Warning: file_put_contents(/var/state/unassigned.devices/unassigned.devices.ini): failed to open stream: No such file or directory in /usr/local/emhttp/plugins/unassigned.devices/include/lib.php on line 42 Warning: file_put_contents(/var/state/unassigned.devices/unassigned.devices.ini): failed to open stream: No such file or directory in /usr/local/emhttp/plugins/unassigned.devices/include/lib.php on line 42 Fatal error: Uncaught exception 'UnexpectedValueException' with message 'RecursiveDirectoryIterator::__construct(/var/state/unassigned.devices): failed to open dir: Not a directory' in /usr/local/emhttp/plugins/unassigned.devices/include/lib.php:60 Stack trace: #0 /usr/local/emhttp/plugins/unassigned.devices/include/lib.php(60): RecursiveDirectoryIterator->__construct('/var/state/unas...', 4096) #1 /usr/local/emhttp/plugins/unassigned.devices/UnassignedDevices.php(90): listDir('/var/state/unas...') #2 /usr/local/emhttp/plugins/unassigned.devices/UnassignedDevices.php(58): make_mount_button(Array) #3 /usr/local/emhttp/plugins/unassigned.devices/UnassignedDevices.php(121): render_partition(Array, Array) #4
Am I correct that this plugin is now fully 6.0 compatible?
If so, can you please edit that on the first page where the download link is.
Thanks,
Russell
Thanks,
Russell
As the subject of the thread says, it works on any version from 6beta14 to what is current as of this post, 6.1.2. It's in the 6.1 verified subforum. What other notation are you wanting? Either it's already been changed, or I don't see what you are talking about.
I'm converting the last 2 drives from RFS to XFS.  Precleared 2 disks and using the newly available format command in unassigned devices, I made them XFS.  I now had 2 3tb drives formatted XFS with Unassigned Devices and I rsynced data onto them filling them up without issue.  Now I just needed to get them into the array and pull the RFS disks out.
I then swapped them with the 2 RFS drives that were in the array and restarted the array with these 2 new drives.
Now unRaid complains about these 2 being unmountable disks.  Unassigned devices works with them fine, but they aren't quite kosher for unRaid array devices.  Some minor format difference??
