I ungraded 2 unRAID server's Unassigned Devices plugin and on the Main Page, I just get a spinning wheel with a message "Please wait... retrieving information!"
I did a couple of reboots of the server and no luck.
Thanks,
H.
  • Replies 814
  • Views 209.6k
Same thing here. I upgraded at the same time to unraid 6.1.3 and to unassigned devices 2015.9.22b and had some issues. Even though the smb shares were mounting (i could access them from midnight commander or command line) they weren't available to the plex docker (of course I made sure to change the plex docker settings to reflect the changes in the smb connection folders). Then I updated to 2015.9.24 and I had the infinitely spinning wheel with "Please wait... retrieving information!". I updated to 2015.9.25 and the problem persists. The last working version (for me at least) was 2015.9.19 . Could I find this specific plg somewhere?
Well the last working veriosn for me is 2015.09.22b
https://raw.githubusercontent.com/gfjardim/unRAID-plugins/5efb7e8ad45751c0086054daece3d000b9b5dd6c/plugins/unassigned.devices.plg
version 2015.09.19 is here:
https://raw.githubusercontent.com/gfjardim/unRAID-plugins/762470eac43bbf00aac46f668745bc264dd2b2f7/plugins/unassigned.devices.plg
You can also walk the history of the file to get the desired version (or ask gfjardim himself)
much obliged dear sir! I reinstalled version 19 and everything is working fine. Could I ask for a clarification? You mentioned "walking the version of the file" to find a previous version. Do you mean that unraid keeps previous versions of packages? If yes could you explain where to find it?
Also, how did you find the link?
Thank you very much!!
Guys, very sorry for this. I've changed loads of code, and sometimes it breaks where you didn't  tested thoroughly.
I'll release a debug version latter, and a fix sooner as possible.
Thank you very much for your hard work. The new version looks very nice and has intuitive interface. Waiting eagerly for the working update!
Guys, there's a new version online. It's not a fix, just a debug version. Please update and send me a log:
Sorry - I meant tracing the commits in the github repository.
I upadated and it seems to be working fine now... I uploaded the log just in case. Thanks again for this plugin!
USB thumb drive that used to mount does not mount because serial number is blank.  Log sent.
Guys, you have to send me the link.
Sorry.  Didn't know I did that.
On the latest version, it mounts an ext4 drive fine, when you click on unmount it goes through the motions but the unraid log shows it as still mounted. Will submit a log
I can no longer use this plugin for my docker.
I currently have the mythtv docker mapped to my external drive. It is set to automount. Had no trouble until I updated the plugin. Now when  I map a folder to a folder on my unassigned device, it does not correctly pass through. No error message in docker.
I then tried to mount a folder on my cache drive, and it worked flawlessly. Not sure why it is no longer mounting drives from unassigned plugins.
Help?
EDIT: Seems to be a race condition https://lime-technology.com/forum/index.php?topic=38635.msg410787#msg410787 .
i would like to ask if any one with ntfs usb drives are having problems??
i have been using this plugin with great success but the last 2 versions i cannot mount my drive..
i have done scandisk in windows [no problems found according to windows  ::)] and have run the correct flag several times with no success...
i do realise you want a log but i am just asking if this is a problem for other people?
thanks for your most excellent plugin, really appreciated..
I'll try this in a couple of days when I do my monthly offsite backup. Worked OK last month.
Removing the unassigned.devices plugin is not removing packages so removing one version and installing a different version is failing.
Is it possible to enable SMB Security on speciffic device/share and not all mounted via Unassigned Devices?
I have just encountered an issue with the plugin.
I precleared a drive (using the preclear plugin) and it completed successfully.
Now I want to format and mount it using Unassigned Devices plugin but format button is grayed out (with array running and also stopped).
when I go into the new (sdf) and existing (sde) drives I don't see any format type option.
See attached
I also uploaded a logfile from the main screen as you described
Just finished my montly backup with this, and it worked.
It is a little different than I remember from last time though. There is no checkbox for running the script in the background, I assume because it always runs in the background now. Also, when I push the Mount button, it does mount and run the script, but the Mount button just sits there "spinning" until the script completes. Not sure that is expected behavior or not, or whether I would even consider it a bug, but it might be a little disconcerting if you aren't aware of what's happening. Once the script completes, the button does show the drive is mounted. My script doesn't take any action on the unmount, so that happens quickly. Don't know if it would also "spin" if the script did anything or not.
DataPoint: I recently installed the latest version and could no longer access my VMs. So I went back to 2015.09.19 and all is well again. (unRaid is also on latest version).
Richard
