Wake on Lan for Virtual Machines for 6.1+
2 hours ago, ingus16 said:
Nerdpack all plugins installed.
I'll let someone else comment on WOL plugin, but what do you mean by the above? Do you mean that you have installed every single one of the packages in Nerdpack? It is probably a bad idea to randomly install a lot of things that you don't know what they are and aren't going to use. I recommend only installing packages that you know what they are and that you actually intend to use.
  • Replies 130
  • Views 65.4k
  • I had the same issue and solved it that way:   1. Uninstall Python2 from the Nerd Pack Plugin 2. cli into your unraid 3. Download Python2 for Slackware: wget https://slackware.uk/s
  • Hello @dmacias   How are you? Hope you are doing well.   I started having issues with WOL plugin recently - it just won't start. I tried enabling/disabling from the VM Manager sett
  • @dlandon has created a Python 2 plugin, so WOL is now no longer being deprecated
7 hours ago, ingus16 said:
WOL plugin daemon is running ,but in fact wont work and no config at all
After research found
Any solution please?
The way you're trying to run it won't work. Everything is loaded under a python virtual environment.
/usr/share/libvirt-python-env/bin/python /usr/local/emhttp/plugins/$prog/scripts/libvirtwol.py $BRNAME
The config is under VM Manager settings.  All you need from NerdPack is python2.
I am using unraid 6.8, and status for "Libvirt wake on lan" always shows stopped. I have installed python2 in nerd and nothing shows in log
/var/log/libvirt/libvirtwakeonlan.log it's empty.
execute /etc/rc.d/rc.libvirtwol start/stop  without error
Hi, i was not able to WoL with my VM, i run a pfsense router as VM,
i have my pfsense interface as vnet0 as the same ip address as the VM and the UNRAID GUI also another PC with the same ip address range,
my pfsense was able to wake the physical PC but not the VM :(
not sure where i did wrong.
Did you try and stop then start from the settings page? You can check if it's running with
ps aux | grep libvirtwol
. It does depend on your default network bridge in the vm settings. This is the actual command and may give you some info as to why it's not starting. Just substitute br0 with your default network bridge
/usr/share/libvirt-python-env/bin/python /usr/local/emhttp/plugins/libvirtwol/scripts/libvirtwol.py br0
my pfsense was able to wake the physical PC but not the VM [emoji20]
What is your default network bridge in the vm settings? The plugin relies on that. I seem to remember to remember something about dockers and vm's not being about to see unraid. Something to do with network isolation. Try waking with another device on the same network as your unraid server.
Hello, I ssh into my unraid
I got following
root@unraid:~# ps aux | grep libvirtwol
root      2085  0.0  0.0   3912  2140 pts/6    S+   23:37   0:00 grep libvirtwol
but for running
root@unraid:~# /usr/share/libvirt-python-env/bin/python /usr/local/emhttp/plugins/libvirtwol/scripts/libvirtwol.py br0
It returned nothing, and I could only see the cursor is waiting. After I checked the status, it shows running and even I set it to no, it's still running. After I closed my ssh session, it's stopped again and I didn't get any message.
Thanks for your reply. I finally figured it out. As you said, the plugin seem monitor the br0 as default one and I was using another br0.10 (I have several vlan). After I made the vm default network to br0, the status shows correctly in web gui. And your plugin works well if I set vm client network to br0 as NIC.
But the issue is that all my vm are running in br0.10, and if I set the vm default network to br0.10, your plugin will never start from web gui.
Edited by Lilarcor
  • 4 weeks later...
i did try, and it work on my physical PC, the WoL from the VM (pfsense) br0 to wake my PC over the network.
but i cannot wake another VM within the unraid Server.
pfsense (UNRAID VM) - another PC on the same network - can wake
Pfsense (UNRAID VM) - another VM (UNRAID VM) - cannot wake
all 3 is on the same network,
pfsense (VM in UNRAID) - 192.168.1.1/24 - Br0
physical PC - 192.168.1.10/24 - connect directly to Br0 (Eth0) on UNRAID server
VM PC - 192.168.1.31/24 - Br0
UNRAID Network setting
VM Setting
VM PC
Pfsense
Edited by Ong Hui Hoong
i just tried to wake the VM from my physical PC also, cannot :(
I always get „Didn't find a vm with MAC address ..." in /var/log/libvirt/libvirtwakeonlan.log, but the MAC is correct and WOL is working in my network so far (elsewise I guess I wouldn’t get that message in the first place)
I’m not using VLANs and I have br0 selected in global VM settings as well as in the individual ones...
Any ideas?
  • 2 months later...
This won't even install on the latest unraid version (6.8.3)  I get Warning: mkdir(): Read-only file system in /usr/local/emhttp/plugins/dynamix.plugin.manager/scripts/plugin on line 268
plugin: plugin: error: unable to create parent directory for /boot/config/plugins/libvirtwol/libvirt-python-env-4.10.0-x86_64-1.txz
Other plugins seem to install and work ok, does this need to be updated to work
Are you logged in as root? Seems like a permissions problem on your end. Not sure. I removed it and reinstalled it just fine
  • 2 months later...
Many thanks for this plugin worked for me sending wake from splashtop 👍
I had to send wake twice first one put the stopped vm into pause then second send set it to run.
any got this working in a vm connection setup in guacamole?
  • 4 months later...
Yes, just in this moment. Here is what I did for my Linux VM:
  1. Create new connection with Protocol SSH
  2. Set parameter Hostname in the networks section to the IP address of the Linux machine
  3. Enter user credentials in the Authentication section
  4. Tick the checkbox "send WoL packet"
  5. Set the field "Mac address of the remote host" to the MAC address of your virtual machine (see vm template)
  6. Set the field "Broadcast address for WoL packet" to you routers IP address
  7. Set the time to wait to e.g. 35
  8. Save connection
Have fun.
Edited by T0a
1 hour ago, Spucoly said:
I installed NerdPack and this Wake on LAN plugin and now im getting this message ever time I try and do anything with VM Manager. I have rebooted after install. Any Ideas?
Do you have python 2 enabled in NerdPack? Simply installing the plugin doesn't actually install any packages, you pick and choose which ones you need and no more.
I figured it out. Needed to zoom out on my browser to see she on /off switch for python in nerpack
I'm new at Unraid, installed it yesterday first time (Trial). The goal is to find a solution for VMs for WoL over Internet and I found it.
Installed your VM WoL and it works really nice. Can now start my Test VM with a command line tool from any place in the world, tried it from NZ, RU, Emitrates and a few other locations. Thats what i was looking for.
THX for this App.
Hi, I tried this plugin where a Linux VM is suspended via the VM itself. Then tried waking it up using the WakeOnLAN Plugin - it worked!
However, I tried waking up the Linux VM from  another Linux Machine using etherwake command, but it failed.
I get error:
SIOCGIFHWADDR on br0 failed: No such device
or
SIOCGIFHWADDR on eth0 failed: No such device
Any ideas?
UPDATE:
Did a wakeonlan command and it worked.
Edited by garydapogi
updated the post
Hi everyone,
after enabling VLANs on the unraid machine and enabling trunk on the switchport, Wake on LAN for the VMs does not work anymore. The VMs still are on br0 and default / native VLAN ID is 1. WoL package both sent from Guacamole Docker but also sent from VLAN 1 network (192.168.1.0/24) do not wake any machine up..
Any ideas?
Switch configuration:
Spoiler
Layer3#sh runn
Building configuration...
Current configuration : 5726 bytes
! Last configuration change at 15:35:39 UTC Sat Jan 1 2000 by admin
! NVRAM config last updated at 15:35:57 UTC Sat Jan 1 2000 by admin
version 15.2
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname Layer3
boot-start-marker
boot-end-marker
enable secret 5 #######################
enable password 7 #######################
username admin password 7 #######################
no aaa new-model
system mtu routing 1500
ip routing
ip domain-name fritz.box
crypto pki trustpoint TP-self-signed-1733138816
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1733138816
 revocation-check none
 rsakeypair TP-self-signed-1733138816
crypto pki certificate chain TP-self-signed-1733138816
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31373333 31333838 3136301E 170D3030 30313031 30303038
  32385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 37333331
  33383831 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81008EFE A6B4AE24 2B4DE353 09341A30 9A8FC9F6 784F4681 001C1204 5AD17F07
  8A287C0E 1D4C7B1E 4F8BD451 DA06EE35 05C057C2 3C534187 33F9C45E 675C5B22
  2650CF8C 174A8F73 4E4DC337 F9268830 B16E3C15 FFB8D0C8 80016F73 0218D25A
  B339627E 5A414170 E77BB28D F29A53DF 443107D3 0896D04B 22C28897 C5855682
  3F8D0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1442C5D8 A54AB7DA 1B9D2E10 68910F56 BD6BA69E FC301D06
  03551D0E 04160414 42C5D8A5 4AB7DA1B 9D2E1068 910F56BD 6BA69EFC 300D0609
  2A864886 F70D0101 05050003 81810029 6D55A857 4D3637D6 C6AD7EDA E8449203
  F73349DD AEF03904 B23A270C 48E34AE0 AD0F25A7 90F1B2F6 615E9B3A 9F312634
  9CC317F9 AC540112 97130D4A ACC9C229 2C00DE8C D55772BB 675519CF B1400E60
  2BD3A5AF D8DF8F78 938826ED 89DFA48A 772B9BAC 24F37F25 118E0240 23D9257F
  0BF84C4F 1CF5F019 DE30EF93 CA04E9
        quit
spanning-tree mode rapid-pvst
spanning-tree extend system-id
vlan internal allocation policy ascending
ip ssh version 2
interface GigabitEthernet0/1
 description Uplink FRITZ!Box
 switchport mode access
interface GigabitEthernet0/2
 description Uplink FRITZ!Gast
 switchport access vlan 2
interface GigabitEthernet0/3
 description Uplink Layer2
 switchport mode trunk
interface GigabitEthernet0/4
 description Uplink Layer2-2
interface GigabitEthernet0/5
 description Uplink Server
interface GigabitEthernet0/6
 description Uplink TP-Link Switch
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
 no keepalive
interface GigabitEthernet0/10
 no keepalive
interface GigabitEthernet0/11
interface GigabitEthernet0/12
 description VLAN3
 switchport access vlan 3
interface Vlan1
 description Native
 ip address 192.168.1.19 255.255.255.0
interface Vlan2
 description Guest
 no ip address
interface Vlan3
 description T0r
 no ip address
ip default-gateway 192.168.1.1
ip forward-protocol nd
ip http server
ip http secure-server
snmp-server community public RO
snmp-server community private RW
snmp-server location Abstellschrank
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps transceiver all
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps license
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps cluster
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps trustsec-sxp conn-srcaddr-err msg-parse-err conn-config-err binding-err conn-up conn-down binding-expn-fail oper-nodeid-change binding-conflict
snmp-server enable traps energywise
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps event-manager
snmp-server enable traps ike policy add
snmp-server enable traps ike policy delete
snmp-server enable traps ike tunnel start
snmp-server enable traps ike tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps power-ethernet police
snmp-server enable traps cpu threshold
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps stackwise
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps errdisable
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vlan-membership
line con 0
 logging synchronous
 login local
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
end
unraid Network Settings:
Spoiler
VM XML:
Spoiler
<domain type='kvm'>
  <name>##########</name>
  <uuid>73712027-ecca-9ec3-490a-ce837b564c47</uuid>
  <description>Windows 7 (32-Bit)</description>
  <metadata>
    <vmtemplate xmlns="unraid" name="Windows 7" icon="windows7.png" os="windows7"/>
  </metadata>
  <memory unit='KiB'>3145728</memory>
  <currentMemory unit='KiB'>3145728</currentMemory>
  <memoryBacking>
    <nosharepages/>
  </memoryBacking>
  <vcpu placement='static'>4</vcpu>
  <cputune>
    <vcpupin vcpu='0' cpuset='0'/>
    <vcpupin vcpu='1' cpuset='1'/>
    <vcpupin vcpu='2' cpuset='2'/>
    <vcpupin vcpu='3' cpuset='3'/>
  </cputune>
  <os>
    <type arch='x86_64' machine='pc-i440fx-4.2'>hvm</type>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv>
      <relaxed state='on'/>
      <vapic state='on'/>
    </hyperv>
  </features>
    <topology sockets='1' dies='1' cores='4' threads='1'/>
    <cache mode='passthrough'/>
  </cpu>
  <clock offset='localtime'>
  </clock>
  <on_crash>restart</on_crash>
  <devices>
      <source file='/mnt/user/domains/Elsa-ETKA/Elsa-ETKA.img'/>
      <boot order='1'/>
    </disk>
    </controller>
      <master startport='0'/>
    </controller>
      <master startport='2'/>
    </controller>
      <master startport='4'/>
    </controller>
    </controller>
    <interface type='bridge'>
      <mac address='52:54:00:5f:f2:81'/>
      <source bridge='br0'/>
      <model type='virtio'/>
    </interface>
    <serial type='pty'>
        <model name='isa-serial'/>
      </target>
    </serial>
    <console type='pty'>
    </console>
    <channel type='unix'>
    </channel>
    </input>
    <graphics type='vnc' port='-1' autoport='yes' websocket='-1' listen='0.0.0.0' keymap='de'>
    </graphics>
    <video>
    </video>
    <memballoon model='virtio'>
    </memballoon>
  </devices>
</domain>
Edited by 3dee
added VM XML
push, please 🙃
  • 2 months later...
Hi guys,
I have a problem with the WOL Plugin.
It need's about 8 min to start when I boot my array. Unfortunately my unraid web log view is not working and I don't know how to provide useful Log Files to debug this behavior.
Can someone help me there?
Best regards,
Stephan
  • 2 months later...
Hello @dmacias
I started having issues with WOL plugin recently - it just won't start. I tried enabling/disabling from the VM Manager settings page, I tried re-installing the plugin as well as python2 in nerdpack, The daemon is not running. When trying to manually trigger start/stop scripts there are no errors thrown. When trying "python  /usr/local/emhttp/plugins/libvirtwol/scripts/libvirtwol.py br0" I am getting "GLIBC_2.33 not found, required by /usr/lib64/libpython2.7.so.1.0". I suspect an update for python in Nerdpack might have happened which triggered this (I should have probably followed the "don't touch it if aint broken" approach..., I might have accidently updated python but I can't remember if that is the case). Would you be able to advise me please?
Thank you.
Same problem here, the script stays on DISABLE what ever i do :)
yeah, same here.
The Plugin don't seem to start anymore.
Is there any update to the Problem?
The development of the Plugin seems to be stoped.
Edited by ubechtle
additional content
