November 25, 20178 yr Author 8 hours ago, dlandon said: I'm moving the discussion of FCP not having the network running when it is dong the github check. In my situation, the network is being messed with at about the same time as FCP is trying to do network things. I think you should add a check for the network being up and running with a max time limit before doing the github check, etc. I think it is just happenstance that the network is dropping out at about the time you need it to be running, especially in my case. I think the better solution as far as FCP is concerned is to instead delay the scan done at disks_mounted by something like 30 minutes. Problem that others have with the network issue is usually related to running pfSense as a VM in which case the startup time is significantly longer than any timeout that I would be comfortable with
November 25, 20178 yr 12 hours ago, Squid said: Nothing changed there. Show me your diagnostics Being new to this, would you mind telling me which diagnostics you would like?
November 25, 20178 yr 7 hours ago, fmp4m said: Being new to this, would you mind telling me which diagnostics you would like? That would mean tools>diagnostics. A zip file will be downloaded. Just attach it to your next post.
November 25, 20178 yr Author 7 hours ago, fmp4m said: Being new to this, would you mind telling me which diagnostics you would like? fixed
November 26, 20178 yr 17 hours ago, Squid said: fixed Thank you, sorry I PM'd the diagnostics. what caused it?
November 26, 20178 yr Author Quote Fixed: PHP error displayed if cache floor not set in unRaid settings
November 28, 20178 yr I am still a little new to unRAID and I was having an issue with an application not launching so I ran CA Fix Common Problems and I received the following error: "Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 127381536 bytes) in /usr/local/emhttp/plugins/fix.common.problems/include/tests.php on line 1586" This is the first time I have seen this so I am not too sure how to fix it or what has caused this. Please let me know if you have any advise. Thanks!
November 29, 20178 yr Author On 11/27/2017 at 11:08 PM, Pidoma said: I am still a little new to unRAID and I was having an issue with an application not launching so I ran CA Fix Common Problems and I received the following error: "Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 127381536 bytes) in /usr/local/emhttp/plugins/fix.common.problems/include/tests.php on line 1586" This is the first time I have seen this so I am not too sure how to fix it or what has caused this. Please let me know if you have any advise. Thanks! You have a very large syslog. Possibly recurring errors in it constantly. But either way, FCP has to accomodate that. Won't be fixed however for about 1.5 weeks (I'm AFK)
November 29, 20178 yr Author 4 hours ago, GeekMajic said: Is there the ability to schedule Extended Tests? Not really. You could however schedule something via user scripts plugin and execute this line: echo "/usr/local/emhttp/plugins/fix.common.problems/scripts/extendedTest.php" | at NOW -M > /dev/null 2>&1 But there's currently no way to disable to start / finished notifications.
November 30, 20178 yr 17 hours ago, Squid said: You have a very large syslog. Possibly recurring errors in it constantly. But either way, FCP has to accomodate that. Won't be fixed however for about 1.5 weeks (I'm AFK) Thank you for the reply. Enjoy your AFK
November 30, 20178 yr Author Go AFK from work!!!One of those rare special jobs where I wake up every morning and ask my wife if I'm allowed to quit
November 30, 20178 yr 42 minutes ago, Squid said: 47 minutes ago, Pidoma said: Go AFK from work!!! One of those rare special jobs where I wake up every morning and ask my wife if I'm allowed to quit I understand that. I am finally in a position that I enjoy.
December 4, 20178 yr Thanks a lot for this plugin! I have experienced a freeze of unRAID where this will be great to preserve the logs past the required, forced reboot! Quote When running in this mode the syslog is continually captured to the flash drive, and a diagnostics dump is performed every 30 minutes
December 4, 20178 yr Author 6 hours ago, cholzer said: Thanks a lot for this plugin! I have experienced a freeze of unRAID where this will be great to preserve the logs past the required, forced reboot! Just FYI that if you do not have the problems, then do not run FCP in this mode. On a properly running, stable system if you want logs preserved after a reboot, use the Tips & Tweaks plugin instead
December 5, 20178 yr 11 hours ago, Squid said: Just FYI that if you do not have the problems, then do not run FCP in this mode. On a properly running, stable system if you want logs preserved after a reboot, use the Tips & Tweaks plugin instead I had unRAID freeze after it was running for about one week. SMB shares and webGUI did not respond anymore - I could still ping the unRAID box though. Had to do a hard reboot of the system which meant that all logs were gone. Troubleshooting mode should help me out here to track down the source of this freeze (should it occur again within the next 14 days), right? Or should I use the Tips & Tweaks plugin instead. Edited December 5, 20178 yr by cholzer
December 9, 20178 yr Author On 11/27/2017 at 11:08 PM, Pidoma said: I am still a little new to unRAID and I was having an issue with an application not launching so I ran CA Fix Common Problems and I received the following error: "Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 127381536 bytes) in /usr/local/emhttp/plugins/fix.common.problems/include/tests.php on line 1586" This is the first time I have seen this so I am not too sure how to fix it or what has caused this. Please let me know if you have any advise. Thanks! *Should* be fixed on today's update. But kinda hard for me to test for it
December 9, 20178 yr Author On 12/7/2017 at 9:01 AM, zin105 said: I keep getting "Unable to communicate with GitHub.com" all of a sudden although internet and DNS lookups works fine from unRAID. How do you know internet and DNS lookups work fine? The github test is the test to see if your server has internet connectivity (so that unRaid etc can check for updates, etc) and is a simple ping to github.com Could also be that when you were running the tests github was down.
December 10, 20178 yr On 12/9/2017 at 12:14 PM, zin105 said: Pinging other sites and even downloading plug-ins that fetch files from github works. I'm seeing this same behavior. Fix Common Problems reports it's unable to communicate with github.com but all internet connectivity, including to github.com works from the host.
December 10, 20178 yr Author I'm seeing this same behavior. Fix Common Problems reports it's unable to communicate with github.com but all internet connectivity, including to github.com works from the host.At what point are you seeing this? Only at the initial array start or on all subsequent scans?
December 11, 20178 yr 5 hours ago, Squid said: 7 hours ago, rjorgenson said: I'm seeing this same behavior. Fix Common Problems reports it's unable to communicate with github.com but all internet connectivity, including to github.com works from the host. At what point are you seeing this? Only at the initial array start or on all subsequent scans? I continue to see the error if I rescan. I also haven't restarted my array since before this started. It showed up on my weekly scan on Sunday morning(~22 hours ago), and was not present the week before.
December 11, 20178 yr 6 hours ago, Squid said: 7 hours ago, rjorgenson said: I'm seeing this same behavior. Fix Common Problems reports it's unable to communicate with github.com but all internet connectivity, including to github.com works from the host. At what point are you seeing this? Only at the initial array start or on all subsequent scans? I had some time and dug into this a little more. I saw in the code that it's running a ping check against github.com which is indeed failing from my unRAID machine. It does not fail from other systems on my network though and my unRAID box is still able to connect to github.com, just not over ICMP. root@mnemos:~/usr/local/emhttp/plugins/fix.common.problems# ping -c 2 github.com PING github.com (18.194.104.89) 56(84) bytes of data. --- github.com ping statistics --- 2 packets transmitted, 0 received, 100% packet loss, time 1005ms root@mnemos:~/usr/local/emhttp/plugins/fix.common.problems# telnet github.com 80 Trying 18.194.104.89... Connected to github.com. Escape character is '^]'. ^] telnet> quit Connection closed. root@mnemos:~/usr/local/emhttp/plugins/fix.common.problems# I don't see anything in iptables that would be blocking this(though I'm not the best with iptables so I could be missing something), and I am able to ping other public sites such as google and yahoo from the unraid host. Edited December 11, 20178 yr by rjorgenson
