BTW how do I set this to check for updates (along with other plugins.)
  • Replies 2.5k
  • Views 673.9k
  • kennymc.c
    kennymc.c
6 minutes ago, tunetyme said:
After Rescan
I thought this would automatically update (rescan) after rebooting the system
Well, its fixed now...
Absolutely zero clue what was going on, as what you're describing should be impossible, and I can't replicate it using your exact config files...:S
Settings - Notification settings.
Ask Trurl, I find things that are impossible, I've been driving him crazy for weeks. I think I will need to get a room there, my bar bill in Greensboro will be HUGE...
Sometimes it seems more like you find unusual ways of describing possible things so that they seem impossible.:D
That's what happens when you look into the glass of water from the top instead of the sides.
FCP keeps giving me a warning that inotifytools is set to install in nerdpack. I've checked nerd pack settings multiple times, inotify isn't in the list. Do I need to update something?
On 4/6/2017 at 5:44 PM, Squid said:
Always wondered at why people would take the bear that's already been asphyxiated, instead of simply getting the white bear and choking it themselves....
Because the average person is lazy!  No work ethic with today's youth.
Update FCP...  I removed that test a couple of versions ago
Started receiving the following since last update. I have neither a cache nor an SSD installed.
Dynamix SSD Trim Plugin Not installed
Your cache drive is an SSD Drive, but you do not have the Dynamix SSD Trim plugin installed. Your performance will suffer. Install the plugin via the Apps Tab (Community Applications)
Let me know if you need any logs or anything. Thanks
Edited by Riot
Nope..  It is exactly what it says it is.  Your performance is going to go downhill because your SSD cache drive won't trim itself.  Install Dynamix SSD Trim via the apps tab.
Re-read your post, and totally missed where you said no SSD or cache.  Yeah, can you give me your diagnostics...  thx
EDIT: my bad.  My secondary server (which also has no cache drive) passed the tests because for some unknown reason I had SSD Trim installed (no clue why I would!?!)
Fixed...
Edited by Squid
does the trim plug in needs to be configured in any way or executed manually?
Unraid gui under settings / scheduler
I couldn't find it either and someone told me ;-)
sweet thanks... kinda makes sense i guess but I wouldn't have found it without your help
Fixed...
Apologies for not commenting sooner. Some reason notify of replies didn't work.
Updated to newest version and I'm still getting the dynamix trim message
Here's a copy of my logs.
https://www.dropbox.com/s/3ppcbk3qogkvqpv/FCPsyslog_tail.txt?dl=0
https://www.dropbox.com/s/u2j8tqpuwjb7iuo/leviathan-diagnostics-20170414-1836.zip?dl=0
https://www.dropbox.com/s/2m6ed4fslo2ojcy/leviathan-syslog-20170414-1825.zip?dl=0
Interesting...  Your disks.ini has a slightly different structure than mine.  Mine has a cache drive entry with it being not present, but yours doesn't have a cache entry at all.  Not saying there's anything wrong on your end however.  An easy fix for me to implement
I set cache disk slots to 0 the other day for uh.. reasons?
Default is 1.
Probably what it is.
Default is 1.
Yeah, odds on...  Install the update and try it again
That got it.
Thank you much, sir!
Can we remove the Error on Plugin Update check and Warning on Docker Update check if Auto Update is enabled?
Is FCP up to date. (i thought I did remove it)
Sent from my LG-D852 using Tapatalk
Yes, FCP is current. 4.14 version, I confirmed it's still recurring with rescan.
Edited by GeekMajic
Oh ok. I see what you're saying now... Yeah you're right. I'll disable the update checks enabled if auto update checks are enabled
Fixed
It's because the author has designated it to run in bridge mode. Ignore if you want but there is zero reason to run it in host mode and is more secure
