July 8, 20179 yr Hi I use latest unraid on my gen8 microserver with Xeon and 16g of ram, worked perfectly until last week, I get this error on your excellent plugin: Your server has detected hardware errors. You should install mcelog via the NerdPack plugin, post your diagnostics and ask for assistance on the unRaid forums. The output of mcelog (if installed) has been logged I have done this but dont really understand the log - attached in Word format. please can you help. Log file.docx
July 8, 20179 yr 9 minutes ago, keymaster said: Hi I use latest unraid on my gen8 microserver with Xeon and 16g of ram, worked perfectly until last week, I get this error on your excellent plugin: Your server has detected hardware errors. You should install mcelog via the NerdPack plugin, post your diagnostics and ask for assistance on the unRaid forums. The output of mcelog (if installed) has been logged I have done this but dont really understand the log - attached in Word format. please can you help. Log file.docx Post always the diagnostics zip instead. You CPU is overheating: Jul 5 17:32:57 Tower kernel: CPU7: Package temperature above threshold, cpu clock throttled (total events = 1)
July 8, 20179 yr Hi Ok sorry, will do in future, so fault was overheated CPU - it was very hot day. Thank you K
July 29, 20179 yr Likely this is an issue with the Docker container template owners but my dockers started alerting about template URL not matching. However, two of the docker container errors are as follows: "The template URL the author specified is Array. The template can be updated automatically with the correct URL." Seems odd that the solution is "Array" and FCP can't seem to actually resolve the issue. Edit: The containers in question are Davos and Letsencrypt Thoughts? Edited July 29, 20179 yr by wreave
July 29, 20179 yr 5 hours ago, wreave said: Likely this is an issue with the Docker container template owners but my dockers started alerting about template URL not matching. However, two of the docker container errors are as follows: "The template URL the author specified is Array. The template can be updated automatically with the correct URL." Seems odd that the solution is "Array" and FCP can't seem to actually resolve the issue. Edit: The containers in question are Davos and Letsencrypt Thoughts? Add DuckDNS to the list of "Array"
July 29, 20179 yr Author 5 hours ago, wreave said: Seems odd that the solution is "Array" and FCP can't seem to actually resolve the issue. Edit: The containers in question are Davos and Letsencrypt The problem is actually a template error on the part of lsio. I already fixed ubooquity for them to let them know what the problem was, and dropped @CHBMB a line to let him know about 8 other templates (those 2 were part of them) that suffered the same issue.
July 29, 20179 yr Did you? I must have forgotten, although I did have a look in CA the other day and thought all our templates were ok...Sent from my LG-H815 using Tapatalk
July 29, 20179 yr Author 2 minutes ago, CHBMB said: Did you? I must have forgotten, although I did have a look in CA the other day and thought all our templates were ok... Sent from my LG-H815 using Tapatalk Look at my PR on ubooquity that @sparklyballs already accepted. It listed everything with the mistake. CA doesn't make use of that tag, but FCP shows a URL of "array" if the mistake is there and the container is installed.
July 30, 20179 yr Is this a problem or should I ignore it. I thought I read that I can ignore it but not sure. Template URL for docker application LetsEncryptis missing. Template URL for docker application ombi is missing. Template URL for docker application plexpy is missing. Template URL for docker application radarr is missing.
July 30, 20179 yr Author 29 minutes ago, squirrellydw said: Is this a problem or should I ignore it. I thought I read that I can ignore it but not sure. Template URL for docker application LetsEncryptis missing. Template URL for docker application ombi is missing. Template URL for docker application plexpy is missing. Template URL for docker application radarr is missing. Fix it. When its fixed, lsio will be able to pump out updates to the templates (ie: ports get added, etc), and you will in most cases pick up those changes automatically
July 31, 20179 yr Fix Common Problems keeps telling me that my Crashplan and Plex docker are configured wrong, they have the wrong network type... They actually do not.. since the new unraid version it is possible to give dockers their own ip address and this is what I have chosen to do very specifically.. Maybe it is possible to change the check in such a way that when the other requirements for a docker ip address are met the interface type is no longer recognised as an error ? This is what it shows now: Jul 29 17:52:19 Tower root: Fix Common Problems: Error: Docker Application CrashPlan is currently set up to run in br0 mode ** Ignored Jul 29 17:52:19 Tower root: Fix Common Problems: Error: Docker Application plex is currently set up to run in br0 mode ** Ignored This is because the "Network type" is set to BR0, that however is not wrong when you need the docker to have its own IP address, if you want this then the "fixed ip address" field is also filled. So if BR0 is set for these containers and the fixed ip address field is empty, then it should trigger an error If BR0 is set and the fixed ip address is fild, then there should be no error..
July 31, 20179 yr Author 1 hour ago, Helmonder said: Fix Common Problems keeps telling me that my Crashplan and Plex docker are configured wrong, they have the wrong network type... They actually do not.. since the new unraid version it is possible to give dockers their own ip address and this is what I have chosen to do very specifically.. Maybe it is possible to change the check in such a way that when the other requirements for a docker ip address are met the interface type is no longer recognised as an error ? This is what it shows now: Jul 29 17:52:19 Tower root: Fix Common Problems: Error: Docker Application CrashPlan is currently set up to run in br0 mode ** Ignored Jul 29 17:52:19 Tower root: Fix Common Problems: Error: Docker Application plex is currently set up to run in br0 mode ** Ignored This is because the "Network type" is set to BR0, that however is not wrong when you need the docker to have its own IP address, if you want this then the "fixed ip address" field is also filled. So if BR0 is set for these containers and the fixed ip address field is empty, then it should trigger an error If BR0 is set and the fixed ip address is fild, then there should be no error.. I thought that would eventually happen. Surprised it took so long though. I'll check it out
July 31, 20179 yr 2 hours ago, Helmonder said: So if BR0 is set for these containers and the fixed ip address field is empty, then it should trigger an erro When the fixed IP address field is empty, the container gets an auto-assigned IP address. The range for these assignments is set under general Docker settings.
July 31, 20179 yr what is then the correct way to determine if a docker is set up for a different ip address ?
August 13, 20179 yr I am having an issue with Fix Common Problems. System this is on is: Intel S2600CP4 2x E5-2640 2x 16GB DDR3 ECC SAS Key for onboard ports SAS Expander 16 2.5" bays (9 drives hooked up) When using a HBA there is no issue. When I moved over to the onboard SAS I could not get the system to come fully up. Unraid would boot but dockers, vm, shares, etc were down. I traced it to Fix Common Problems. Here is the log: Aug 12 22:06:14 Tower root: Fix Common Problems Version 2017.07.28 Aug 12 22:06:16 Tower kernel: BUG: unable to handle kernel NULL pointer dereference at (null) Aug 12 22:06:16 Tower kernel: IP: isci_task_abort_task+0x1c/0x36b [isci] Aug 12 22:06:16 Tower kernel: PGD 0 Aug 12 22:06:16 Tower kernel: P4D 0 Aug 12 22:06:16 Tower kernel: Aug 12 22:06:16 Tower kernel: Oops: 0000 [#1] PREEMPT SMP Aug 12 22:06:16 Tower kernel: Modules linked in: md_mod bonding igb ptp pps_core i2c_algo_bit x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel pcbc aesni_intel aes_x86_64 crypto_simd glue_helper cryptd intel_cstate intel_uncore isci libsas intel_rapl_perf i2c_i801 i2c_core ahci scsi_transport_sas wmi ipmi_si libahci button [last unloaded: pps_core] Aug 12 22:06:16 Tower kernel: CPU: 0 PID: 2258 Comm: kworker/u288:8 Not tainted 4.12.3-unRAID #1 Aug 12 22:06:16 Tower kernel: Hardware name: Intel Corporation S2600CP/S2600CP, BIOS SE5C600.86B.02.06.0006.032420170950 03/24/2017 Aug 12 22:06:16 Tower kernel: Workqueue: scsi_tmf_8 scmd_eh_abort_handler Aug 12 22:06:16 Tower kernel: task: ffff88081829b500 task.stack: ffffc90004334000 Aug 12 22:06:16 Tower kernel: RIP: 0010:isci_task_abort_task+0x1c/0x36b [isci] Aug 12 22:06:16 Tower kernel: RSP: 0018:ffffc90004337c98 EFLAGS: 00010292 Aug 12 22:06:16 Tower kernel: RAX: ffffffffa0193329 RBX: ffff8807dcecfda8 RCX: 0000000000000000 Aug 12 22:06:16 Tower kernel: RDX: ffff88081cc20420 RSI: 0000000000002400 RDI: 0000000000000000 Aug 12 22:06:16 Tower kernel: RBP: ffffc90004337e28 R08: 00000000000000d7 R09: 0000001918aa7c00 Aug 12 22:06:16 Tower kernel: R10: 000000000000003a R11: 071c71c71c71c71c R12: 0000000000000000 Aug 12 22:06:16 Tower kernel: R13: ffff8807f2a69000 R14: 0000000000000000 R15: 0000000000000008 Aug 12 22:06:16 Tower kernel: FS: 0000000000000000(0000) GS:ffff88081d200000(0000) knlGS:0000000000000000 Aug 12 22:06:16 Tower kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 Aug 12 22:06:16 Tower kernel: CR2: 0000000000000000 CR3: 000000000180a000 CR4: 00000000000406f0 Aug 12 22:06:16 Tower kernel: Call Trace: Aug 12 22:06:16 Tower kernel: ? freed_request+0x36/0x51 Aug 12 22:06:16 Tower kernel: ? __blk_put_request+0xfb/0x13c Aug 12 22:06:16 Tower kernel: ? blk_put_request+0x4a/0x51 Aug 12 22:06:16 Tower kernel: ? scsi_execute+0x17a/0x18a Aug 12 22:06:16 Tower kernel: ? cpuacct_charge+0x6d/0x74 Aug 12 22:06:16 Tower kernel: ? dequeue_entity+0x4d2/0x4ec Aug 12 22:06:16 Tower kernel: ? put_prev_entity+0x26/0x2f8 Aug 12 22:06:16 Tower kernel: sas_eh_abort_handler+0x2e/0x49 [libsas] Aug 12 22:06:16 Tower kernel: scmd_eh_abort_handler+0x3a/0x93 Aug 12 22:06:16 Tower kernel: process_one_work+0x147/0x222 Aug 12 22:06:16 Tower kernel: worker_thread+0x1da/0x2a5 Aug 12 22:06:16 Tower kernel: ? rescuer_thread+0x258/0x258 Aug 12 22:06:16 Tower kernel: kthread+0x11c/0x124 Aug 12 22:06:16 Tower kernel: ? kthread_create_on_node+0x3a/0x3a Aug 12 22:06:16 Tower kernel: ret_from_fork+0x25/0x30 Aug 12 22:06:16 Tower kernel: Code: 89 e5 5d c3 55 b8 05 00 00 00 48 89 e5 5d c3 55 48 89 e5 41 57 41 56 41 55 41 54 49 89 fc 53 4d 8d 7c 24 08 48 81 ec 68 01 00 00 <48> 8b 07 c7 85 80 fe ff ff 00 00 00 00 c7 85 88 fe ff ff 00 00 Aug 12 22:06:16 Tower kernel: RIP: isci_task_abort_task+0x1c/0x36b [isci] RSP: ffffc90004337c98 Aug 12 22:06:16 Tower kernel: CR2: 0000000000000000 Aug 12 22:06:16 Tower kernel: ---[ end trace 03433dd934a37e08 ]--- Any ideas? Removing the plugin everything works fine.
August 13, 20179 yr Author 6 hours ago, TType85 said: Any ideas? Removing the plugin everything works fine. No real good answer for you at this point in time. Just remove it.
August 13, 20179 yr On 7/31/2017 at 10:48 PM, Helmonder said: what is then the correct way to determine if a docker is set up for a different ip address ? docker inspect <container-name> Shows the IP address assigned to the container. Or when creating/editing a container from the GUI, click on "Show deployed IP addresses" which opens a list of all IP addresses used by the different containers.
August 13, 20179 yr 5 hours ago, Squid said: No real good answer for you at this point in time. Just remove it. Dang. I really liked the plugin
August 13, 20179 yr Author 26 minutes ago, TType85 said: Dang. I really liked the plugin Put it this way. The only way that I can see it being possible for the problem is when FCP issues an HDPARM (standard linux) command to figure out if there's an HPA partition on the drives. Not sure at the moment what to possibly do about it.
August 13, 20179 yr @Squid Thanks for this tool. I used every part of it last night to fully get a server to be in tip top shape. Love the extended scan. Great work!
August 24, 20179 yr Okay, I just had a power outage for about an hour, UPS took over and shut down my server with 5mins runtime left, just as it should. On reboot, however, FCP reports an unclean shutdown. Is this a known issue or is there something wrong with my server? No parity check initiated on reboot and nothing else to suggest that the shutdown was unclean. Edited August 24, 20179 yr by NeoDude
August 24, 20179 yr Author 1 hour ago, NeoDude said: Okay, I just had a power outage for about an hour, UPS took over and shut down my server with 5mins runtime left, just as it should. On reboot, however, FCP reports an unclean shutdown. Is this a known issue or is there something wrong with my server? No parity check initiated on reboot and nothing else to suggest that the shutdown was unclean. If there's no parity check happening, then something in my detection went wrong somewhere. Just acknowledge the error.
August 29, 20179 yr I am getting the error Docker Application binhex-delugevpn, Container Port 58946 not found or changed on installed application but when I look into the binhex-delugevpn docker both the container port and host port are 58846 not 58946.
August 29, 20179 yr 6 minutes ago, mattekure said: I am getting the error Docker Application binhex-delugevpn, Container Port 58946 not found or changed on installed application but when I look into the binhex-delugevpn docker both the container port and host port are 58846 not 58946. Discussion starts here and then read the next few posts. May answer your question.
