Jump to content
[Plugin] Linuxserver.io - Unraid DVB
2 minutes ago, nuhll said:
Yep.
Could not upgrade from latest dvb version to the newest unraid dvb version, so i changed back to normal unraid version (latest).
Hang on, I'm confused, is this a problem with the plugin parsing the available builds or a problem with the build once it's installed?
Link to comment
I think the problem is it times out, but why, is the question.
May 23 22:39:16 Unraid-Server nginx: 2018/05/23 22:39:16 [error] 4429#4429: *358315 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.86.42, server: , request: "POST /plugins/UnraidDVB/include/exec.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock", host: "192.168.86.2:81", referrer: "http://192.168.86.2:81/Settings/UnraidDVB"
Link to comment
I don't know.  I can't reproduce it here, you using a VPN or anything?
Link to comment
https://mirror.linuxserver.io/unraid-dvb/
You can download the builds manually here.
Link to comment
Next problem, after the backup plugin restartet tvheadend, it came to a bug:
May 27 10:14:39 Unraid-Server CA Backup/Restore: Stopping tvheadend
May 27 10:14:39 Unraid-Server kernel: BUG: unable to handle kernel paging request at 00000002e57c3200
May 27 10:14:39 Unraid-Server kernel: IP: dvb_frontend_release+0x28/0xfe [dvb_core]
May 27 10:14:39 Unraid-Server kernel: PGD 0 P4D 0
May 27 10:14:39 Unraid-Server kernel: Oops: 0002 [#1] SMP PTI
May 27 10:14:39 Unraid-Server kernel: Modules linked in: xt_CHECKSUM iptable_mangle ipt_REJECT nf_reject_ipv4 ebtable_filter ebtables ip6table_filter ip6_tables vhost_net tun vhost tap macvlan xt_nat veth ipt_MASQUERADE nf_nat_masquerade_ipv4 iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 iptable_filter ip_tables nf_nat xfs md_mod nct6775 hwmon_vid em28xx_rc a8293 ts2020 m88ds3103 i2c_mux regmap_i2c em28xx_dvb dvb_core x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel em28xx kvm tveeprom v4l2_common videodev crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel pcbc aesni_intel aes_x86_64 crypto_simd glue_helper cryptd media r8169 intel_cstate intel_uncore mpt3sas i2c_i801 intel_rapl_perf i2c_core mii ahci video button libahci raid_class backlight scsi_transport_sas
May 27 10:14:39 Unraid-Server kernel: CPU: 0 PID: 22228 Comm: tvheadend Not tainted 4.14.41-unRAID #1
May 27 10:14:39 Unraid-Server kernel: Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./H81 Pro BTC, BIOS P2.30 03/22/2016
May 27 10:14:39 Unraid-Server kernel: task: ffff88002e30ec00 task.stack: ffffc90009124000
May 27 10:14:39 Unraid-Server kernel: RIP: 0010:dvb_frontend_release+0x28/0xfe [dvb_core]
May 27 10:14:39 Unraid-Server kernel: RSP: 0018:ffffc90009127ea0 EFLAGS: 00010202
May 27 10:14:39 Unraid-Server kernel: RAX: 00000001045423fa RBX: ffff88040a153908 RCX: 0000000000000001
May 27 10:14:39 Unraid-Server kernel: RDX: ffff88002d89abc8 RSI: ffff88002d89ab00 RDI: ffff88010ad94320
May 27 10:14:39 Unraid-Server kernel: RBP: ffff88040b3399c0 R08: 0000000000000000 R09: 0000000000000000
May 27 10:14:39 Unraid-Server kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffff88010ad94320
May 27 10:14:39 Unraid-Server kernel: R13: 00000002e57c3000 R14: ffff88002d89ab10 R15: ffff88010ad94320
May 27 10:14:39 Unraid-Server kernel: FS:  000014c5beb20b18(0000) GS:ffff88041f200000(0000) knlGS:0000000000000000
May 27 10:14:39 Unraid-Server kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
May 27 10:14:39 Unraid-Server kernel: CR2: 00000002e57c3200 CR3: 00000000274e4002 CR4: 00000000001626f0
May 27 10:14:39 Unraid-Server kernel: Call Trace:
May 27 10:14:39 Unraid-Server kernel: __fput+0xdb/0x18b
May 27 10:14:39 Unraid-Server kernel: task_work_run+0x77/0x8b
May 27 10:14:39 Unraid-Server kernel: exit_to_usermode_loop+0x46/0x75
May 27 10:14:39 Unraid-Server kernel: do_syscall_64+0xf7/0xfe
May 27 10:14:39 Unraid-Server kernel: entry_SYSCALL_64_after_hwframe+0x3d/0xa2
May 27 10:14:39 Unraid-Server kernel: RIP: 0033:0x14c5c70e2f33
May 27 10:14:39 Unraid-Server kernel: RSP: 002b:00007ffed53696b8 EFLAGS: 00000246 ORIG_RAX: 0000000000000003
May 27 10:14:39 Unraid-Server kernel: RAX: 0000000000000000 RBX: 000014c5beb20b18 RCX: 000014c5c70e2f33
May 27 10:14:39 Unraid-Server kernel: RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000014
May 27 10:14:39 Unraid-Server kernel: RBP: 0000000000000003 R08: 0000000000000000 R09: 0000000000000000
May 27 10:14:39 Unraid-Server kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 000055a5fc5247c0
May 27 10:14:39 Unraid-Server kernel: R13: 0000000000000000 R14: 00007ffed5369910 R15: 000055a5fc1e82c9
May 27 10:14:39 Unraid-Server kernel: Code: eb af c3 41 55 41 54 55 53 48 8b ae c0 00 00 00 f6 46 40 03 48 8b 9d 90 00 00 00 4c 8b ab 28 03 00 00 74 11 48 8b 05 06 35 9d e1 <49> 89 85 00 02 00 00 0f ae f0 e8 3f 95 ff ff 83 7d 34 ff 41 89
May 27 10:14:39 Unraid-Server kernel: RIP: dvb_frontend_release+0x28/0xfe [dvb_core] RSP: ffffc90009127ea0
May 27 10:14:39 Unraid-Server kernel: ---[ end trace c5b681203de2cd33 ]---
May 27 10:14:42 Unraid-Server kernel: device br0 left promiscuous mode
May 27 10:14:42 Unraid-Server kernel: veth281d338: renamed from eth0
May 27 10:14:42 Unraid-Server CA Backup/Restore: docker stop -t 60 tvheadend
After backup plugin restartet tvheadend, it cant find the adapter anymore.
unraid-server-diagnostics-20180528-1328.zip
Link to comment
When I plug in my USB tv tuner to my server it gets recognized as /dev/dvb. However, if I try to use a usb extender w/ it then /dev/dvb is gone.
I know the usb extender and cat6 cable and jumpers work because I did the same test with a windows laptop and it all works.
Can someone please help?
Link to comment
I'm not sure I have anything to offer here, the drivers are present and working, but the presence of the USB extender seems to not work under Linux.
Link to comment
Since now i get
Jun 25 12:07:35 Unraid-Server login[9817]: ILLEGAL ROOT LOGIN on '/dev/pts/8'
when i click on Terminal.
i use the librelec 6.5.3 RC1
COuld thta have something to do with wrong chmod on dev/dvb?
unraid-server-diagnostics-20180625-1209 (1).zip
Not that I can see. And if the permission were an issue we'd be having everyone seeing the same issue. Nothing with the perms has changed since I released the first version of the plugin.
Link to comment
Ive restartet, now i got Kernel Panics (and i get the feeling this whole thing is just not working, for me, maybe wrong hardware)
But it seems like its caused by usb connecting and disconnecting (wtf), its inside a server rack, there is nothing moving, ofc.
Is there maybe a bios setting i could check to provent usb from disconnecting?
Will upload log asap.
unraid-server-diagnostics-20180625-1528.zip
Edited by nuhll
Link to comment
1 hour ago, Zan said:
Yes, LibreElec is the build to use.
Thanks! Got ant problem with tvheadend? It works for 2 minutes (+ -) and then I get timeout?
LibVLC/3.0.2"
2018-07-05 12:03:42.501 [WARNING] linuxdvb: Unhandled ERROR_BLOCK_COUNT scale: 0
2018-07-05 12:03:43.355 [WARNING] linuxdvb: Silicon Labs Si2168 #3 : DVB-C #0 - poll TIMEOUT
Link to comment
  • Create New...
