3 minutes ago, trurl said:
Probably your server is having a problem reaching the internet. Can you ping github from your server?
I'm actually currently connected to my LAN through Guacamole running on my server.  But yes, I can also confirm that my server can ping github from the terminal window with no issues.
  • Replies 2.5k
  • Views 667.2k
  • kennymc.c
    kennymc.c
Looks like several similar reports on @Squid's threads. He will probably be along soon to give us some insight.
Nothing wrong with the URLs.  What it appears to be is that where ever the users in question are are being blocked from raw.github.com, but have access to raw.githubuser.com (technically, the first redirects to the 2nd, and it works perfectly fine for me, and the urls haven't changed in years in the plugin)
Welp - this is definitely one of those "Just let it sit and mellow" kinda scenarios.  Now, 5 hours later, the updates to both FCP and CA went through with no issues. Sorry for cluttering up the forum boards!
So its a common problem needing fixing? 🤭
Apparently fixed itself according to the post just above yours.
Squid updated the URL's in the repo's, that's why it started working.
FCP is reporting this error on my unRAID 6.6.6 box:
The plugins page shows that I'm running version 2018.08.29a of the system stats plugin, which the release notes claim is compatible with 6.6.6 — 2019.01.12 is the first version to set a minimum unRAID version of 6.7.0. (The plugins page, quite correctly, won't let me update to this.)
Is FCP scanning against the latest released version of the plugin rather than the currently installed one? That seems a bit odd to me — and it certainly shouldn't be reporting it as an error when the fix involves installing a release candidate version of unRAID, as that's not really an option for important systems…
Are you on the latest version of FCP?  Pretty sure I changed the logic on what happens with System Stats and FCP, unless I introduced a regression error in my last update.
Actually, it's a change I made to the application feed that's causing this false positive.  I'll think about what to do and issue an update to FCP later on today.
Deprecated plugin fix.common.problems.plg:
This plugin has been deprecate and should no longer be used due to the following reason(s): Because this plugin has the ability to delete your entire array in the case of a severely misconfigured docker application, it is now deprecated in favour of manually deleting the appdata folders via Krusader and the like. While this plugin should still be functional, it is no recommended to continue to use it
Uhhh...  So the plug-in flagged itself?
Any advise on how to proceed?  Is there a new alternative to Fix Common Problems?
lol  Yeah, that's wrong
 It'll fix itself in 33 minutes
The text about Machine Check Events no longer works because /dev/mcelog is no longer created with the current unRAID kernel configuration - this prevents the mcelog program from doing anything.
Anyone have a suggested alternative?
What day and time does this run when I set it to weekly or monthly?
Install dynamix schedules plugin and you can adjust daily, weekly, monthly
Sent via telekinesis
How long is it supposed to take for my first scan? About 5 minutes now...and no progress whatsoever...
After 120 seconds if it doesn't complete, it never will.  Reload the page, and if it doesn't bring that back up, then it's done.  It's on the todo list to change how that popup works
Edited by Squid
Just an update on my issue with FCP always running a scan automatically when I load the page (do not want) and the scan never ending or giving any feedback to the user.
After reinstalling unraid I still am stuck in a scanning loop. If I reload the page it just scans again.
What do you mean exactly by a reinstall of Unraid? Normally I wouldn't expect a reinstall of Unraid to have any effect on a plugin or much of anything else, since Unraid installs itself fresh from the archives on flash at each boot.
Did that reinstall also include removing and reinstalling the plugin?
I've reinstalled the plugin. With my data and my configuration, I get this flaw. FCP has updated twice since, no change.
If I got to the FCP page it will run the scan.php script, which I can track in the shell and see it quit after the time runs over. If I reload the FCP settings page, it will just do this again. So I can no use FCP as I was before to list my problems and fix them.
It should never scan automatically when you open that link. Why would I ever want that?
It should provide feedback on a scan's state, and not just leave a floating status with no way for the user to provide input.
Some error handling for timeout would be nice too.
It only scans when opening that page if no scan has yet completed.  Scans run 10 minutes after start of the array and also on whatever schedule you may or may not choose.
Hey Squid. I am having a hard time finding troubleshoot mode on the plugin settings page. I could of sworn it was there last update. Where did it go?
If you're running 6.7, then it's no longer there.  Been superseded by the syslog server feature you can find in the Settings tab
While testing the "Virtual Machine Wake On Lan" plugin, I discovered that I had two VMs using the same MAC address (sloppy editing of the XML's).  It would be useful if Fix Common Problems could scan the docker configs and VM configs for duplicate MACs, and the docker configs for duplicate IP's.
I'm running 6.6.7 and it seems the syslog feature is not available with your plugin, but also not available in the Settings tab (available as of 6.7).
Could do with an easy way of tailing syslog but can't seem to be able to until I either upgrade to 6.7 or find some other solution :(
