Nevermind, Im an Idiot...
  • Replies 2.5k
  • Views 669.8k
  • kennymc.c
    kennymc.c
Hi-
Every hour I get an email from my Unraid box, which I determined was due to an hourly cronjob run:
root@Unraid:~# /usr/local/emhttp/plugins/fix.common.problems/scripts/scan.php
 HDIO_DRIVE_CMD(identify) failed: Inappropriate ioctl for device
Any ideas on how to suppress this?
Thanks!
35 minutes ago, dcoulson said:
Hi-
Thanks!
Try checking for updates.  Does today's change fix this?
I just updated to 2019.05.26 and still have the same issue.
Any way to get debug/verbose logs out of the script to see what specifically is generating it?
15 hours ago, Squid said:
Try today's update
So far so good - Updated about 3hrs ago. No more emails. Did we fix something or just suppress the output?
Suppressed it. The error is harmless
Sent via telekinesis
  • 4 weeks later...
I'm having an issue on one of my unraid servers where FCP times out, I get this in the error log:
Jun 24 07:40:31 bigbird nginx: 2019/06/24 07:40:31 [error] 3771#3771: *8043 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.12.140, server: , request: "POST /plugins/fix.common.problems/include/fixExec.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock", host: "192.168.12.250", referrer: "http://192.168.12.250/Settings/FixProblems"
Is there another error log that I can check to see what's happening?
Edited by ThatDude
typo
It's on the to do list to rearrange FCP from being subject to unRaid's hard 120 second limit on certain operations.
In the meantime, after 2 minutes, it will never close the pop up.  Give it another couple minutes, then when you reload the tab, the issue(s) will be listed if any are found.
I'm trying to fix "write cache disabled on parity". Used the solution listed- https://forums.unraid.net/topic/46802-faq-for-unraid-v6/page/2/?tab=comments#comment-755621.
I get this-
Linux 4.19.56-Unraid.
root@Brunnhilde:~# hdparm -W 1 /dev/sdc
/dev/sdc:
 setting drive write-caching to 1 (on)
 write-caching =  0 (off)
root@Brunnhilde:~#
Looks like it didn't work. The drive is an 8TB HGST (HGST Ultrastar He8 HUH728080ALE600) sata drive connected to a sata port on my motherboard. Any other ideas for a fix?
 Talk to WD or ignore it.
I'm seeing the same problem.  When I reload the page the scan starts again, does that mean no problems were found?  I've included log and diagnostics files just in case.
athena-diagnostics-20190718-1054.zip athena-syslog-20190718-1056.zip
I have run Extended Test and upon completion it says errors found.  Where can I view these errors I assume there is a log?
Settings>Fix Common Problems
If you enable email notifications on your server they should also be listed there.
This only shows the regular scan errors.  It does seem to show Extended Test results
I see it now.  Sorry for being an idiot.  Lol
September 8th update: "Don't check for docker apps having an update available for them unless running 6.8"
So not checking for docker apps updates until 6.8 installed?
I must be reading this wrong, lol.
Nope why report an update is available when an update is always available until 6.8 is released
Sent from my NSA monitored device
