Oct 18 08:23:33 Tower kernel: mce: [Hardware Error]: Machine check events logged
Oct 18 08:23:33 Tower kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 8: cc1750400001009f
Oct 18 08:23:33 Tower kernel: mce: [Hardware Error]: TSC 0 ADDR c80c0 MISC 38a462200001080
Oct 18 08:23:33 Tower kernel: mce: [Hardware Error]: PROCESSOR 0:206c2 TIME 1539876192 SOCKET 0 APIC 0 microcode 1f
Oct 18 08:23:33 Tower kernel: Hierarchical SRCU implementation.
Oct 18 08:23:33 Tower kernel: smp: Bringing up secondary CPUs ...
Oct 18 08:23:33 Tower kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 8: cc0000c00001009f
Oct 18 08:23:33 Tower kernel: mce: [Hardware Error]: TSC 1b2f36abf0 ADDR 8fb9c380 MISC 1e0a060200000080
Happened early in the boot process.  Nothing logged by mcelog until it happens again.  Maybe more information in your event log in the BIOS
  • Replies 2.5k
  • Views 667.2k
  • kennymc.c
    kennymc.c
Unraid 6.6.3, FCP 2018.10.19 get a php error:
Edited by dlandon
Is the Ryzen Zenstates warning still relevant to v. 6.6.3? To Threadripper?
Same footer font issue in FCP as in Backup/Restore:
Have you been told yet?  😁
Again, just doing my part 🙂 putting it on the radar
Edited by cybrnook
Would you rather users not report these issues to you? Only better to have fatal or serious issues rather than minor ones?
2 minutes ago, Squid said:
I'm laughing...  Keep 'em coming.
And yes, I would prefer to know about any and all issues.  Not just the big ones.
Thanks, glad it didn't take 2 hours of searching ;-)
I've ignored this warning since my thread searches hasn't turned up anything critical or relevant to Zenstates + Threadripper. Plus, the Unraid OS has been running just fine *knock on wood*.
  • I didn't see anything in the 6.6.3 announcement when I used the "Search This Topic" function in the forum search.
  • Ditto with a search in the 6.6.2 topic
Whether its needed or not I honestly have no clue.  Until someone states definitively that no you should not be using it, then the test remains.
I apologise in advance for not scanning all 39 pages of this thread and maybe having missed the answer to this, but I opened another thread in general support (why can't I see the "link" icon in the editor here?) which has gotten zero replies, so I thought it's best to link to it from here:
Edited by tillkrueger
addendum
IIRC it’s in system log. tools>system log
Edited by wgstarks
sorry if I sound dim, but what does IIRS mean? it's part of the system log...and that would be on the USB Flash drive then?
IIRC = if I recall correctly
You can go to tools>system log and download it.
Edited by wgstarks
oh, as a German-American my command of the language, especially when it comes to abbreviations like that, still appears to be lacking ;)
k, gonna try to retrieve the System.log file and see whether it contains the Extended Test results, then. Thanks.
no, the results from the Extended Test are nowhere to be found in the syslog file(s), which leaves me wondering whether there is some other way to retrieve them, since calling up the results in Safari fails, every time...the page is empty after about 100 lines of errors (duplicate files), where the last line I can see is actually cut in half, vertically.
anyone know of a way to retrieve that log file in some other way?
cat /tmp/fix.common.problems/extendedLog | todos > /boot/extendedLog.txt
thanks Squid...a 39.9MB log file, that's what I call logging...afraid to open it.
is there some other app I'll need to open this log file with than the Mac Text.app?
many sections are all but unreadable to me because they appear to be lacking basic formatting, like line-returns.
but it's obvious that I have countless duplicate files, which I am already beginning to eliminate (at least the ones I could read at the top of the log file).
Opening in your browser should display it properly.  Might have to rename it to be .html
