***GUIDE*** Plex Hardware Acceleration using Intel Quick Sync
 Just run touch \flash\config\modprobe.d\i915.conf in a terminal
5 minutes ago, sittingmongoose said:
creating the empty file
  • Replies 500
  • Views 545.6k
  • You might find this useful (Yes means the iGPU can both encode and decode.):   BTW: this chart is from the Quick Sync Video Wikipedia page.
  • Please be courteous and respectful to one another. Thank you
  • To anyone who is having trouble with the modified go file saving the changes after a system restart, you may be making the same stupid mistake as me. When you edit your go file via the terminal with "
Thanks, didnt work for me still.  I am actually trying with emby not Plex.  But I also cant get emby working with nvidia either...using settings from tdarr that work and trying my plex docker settings.  running 6.9.2 so not sure whats going on.  Plex works with nvidia currently.
Sorry cut from the prev post, should be touch /boot/config/modprobe.d/i915.conf This will cause the module to be loaded at boot.
You can run modprobe i915 to load.
I thought you shouldnt use modprobe if you are on 6.9.2?
It will be done automatically once you create the file when the system boots.
But you can run it so you dont need to reboot this time. The file just over writes the one in the image that has a blacklist command to stop it running. But that only happens at boot.
Edited by SimonF
Hmmm still didnt work...weird.  Something is funky, nvidia isnt showing up either and that works perfectly in plex and tdarr.  Odd.
i915 Is for the Intel’s GPU.
you can also create the file in windows just by navigating there and creating a new text file with extension .conf.
craigr
Hey guys. With this thread I've had hw transcode working great on my intel i3 10100. Recently I stupidly upgraded unraid from 6.9.0 to 6.9.1 (those upgrade banners will get ya) and noticed HW transcode stopped working. I came back to this thread and thanks to @craigr and @simonf for pointing out the fix.
So I removed the 2 lines from my go file:
modprobe i915 gpu
chmod -R 777 /dev/dri
ran the touch command:
And rebooted my server. Unfortunately it still isn't working. So I shutdown the server and checked that the USB drive actually has the empty file "\config\modprobe.d\i915.conf", which it surely did!
Booted server back up, tested a stream and still no hw transcode :(
I've double checked the plex setting "Use hardware acceleration when available" is enabled
and my plex container I have device "/dev/dri" (still same from original that worked pre 6.9.1).
What else could cause this to not work?
Edited by TopherHax
Little update.
I downgraded unraid from 6.9.1 back to 6.9.0 RC2, then added everything back to my go file, deleted the i915.conf file, rebooted, and it still isn't working🤦‍♂️
Maybe latest version of PMS is causing this?
In 6.9.0, if the docker you are using is unable to access the GPU, add/keep this line to your go script:
All the info is in the documentation.  There is also plenty on runnin the Nvidia drivers.
https://wiki.unraid.net/Unraid_OS_6.9.0#GPU_Driver_Integration
See what happens if you leave “chmod -R 777 /dev/dri” in your go file.  Mine didn’t need it, but some may.
craigr
craigr
So I tried that, rebooted, confirmed it "stuck" but no change.
I wonder if something in PMS has become corrupt?
Here's my go file:
  GNU nano 5.3                                          /boot/config/go
#!/bin/bash
# Start the Management Utility
/usr/local/sbin/emhttp &
I installed the "intel-gpu-tools" docker app and ran it to see if I could spot any activity.
I noticed that when I started a stream that should be a HW transcode, the first second or two showed light activity, then immediately back to 0%.
Im following your issue, I have the exact same problem but with emby.
I did some more diagnostics...
1. Upgrade back to 6.9.1
No change
2. Mobo BIOS video was set to "AUTO", changed to "iGPU".
No change
3. Connected physical monitor and keyboard (in case mobo needs to see HDMI? Worked fine before)
No change
4. I read how I should be using linuxserver plex container, so I installed that container, copied my plex data over, gave it container device: "/dev/dri".
No change
5. Quadruple checked all other settings: go file is clear, i915.conf file exists. ls in /dev/dri correctly reports "card0  renderD128". Plex set to "Use hardware acceleration when available", "Use hardware-accelerated video encoding".
No change
So I am giving up for now, probably put 4hrs into this today 😑
Of course just as I posted that I have somewhat of a positive result....
I tried playing a different "test 4K video", this time avatar instead of finding dory and... ITS WORKING? But not on other 4K files?
Finding dory still doesn't work, how/why would it work on some files and not others?
Check out the screenshots.
Both movies are MKV containers.
Eureka!
First, I am sorry for so many posts.
So I disabled "Enable HDR tone mapping" and tada, every 4K video now uses hw perfectly.
Newbie, can you test and report back?
So either unraid or plex broke the HDR tone mapping, how can I figure out which to report it?
Edit: This seems to be the exact issue reported to Plex if anyone else is interested: https://forums.plex.tv/t/4k-hdr-hevc-hw-transcoding-is-broken-on-1-22-1-4200/702328/31
Edited by TopherHax
I think I read somewhere this was an issue but I thought it was solved.  I’ll try turning mine off and on later if I can (got second covid shot yesterday and it kicked my butt).  It may be that you need plexpass for it?  Do you have a license?
craigr
I just crawled out of bed and tried with tone mapping on or off, both work fine.  I am using the official PLEX server docker.  Based on your thread, the problem may be only with certain CPU's.  I'm running an Xeon E-2288G.
craigr
craigr
Yes I have lifetime plex pass.
i3-10100 , from intel's documentation supports codecs even up to h265 10bit.
5 hours ago, craigr said:
Hi There,
I face this issue as well since Plex 1.22.1.4200.
I tried reinstalling Intel Compute Runtime (ICR) manually in the container, but no luck, still failing...
So I came back to the scripted solution I proposed about four months ago which will compile and install the old Intel Beignet driver :
Same advice as before, it takes a few long minutes to install, but it works !!!
An you need to reinstall it each time Plex container is updated and this issue still remains...
What is the thing to do, if I'm upgraded to Unraid 6.9.1, and I still got working hw transcode for everything like before, except 4K HDR to something like 1080 SDR with tone mapping?
Since I still got hw working for other stuff, do I need to change in my GO file or do something else?
Thanks.
/Söder
Is this guide still the way to go for quicksync under 6.9.1?
Edit: I just checked, I dont have the "/dev/dri" not even after I added "i915.alpha_support=1" to the "syslinux.cfg" I guess unraid does not support the quicksync on the 4th gen cpus
Edited by isvein
Nothing to do with unRAID.  I am running Quicksync just fine on an i5-4590 with i915 drivers.
With the new new way of loading i915 drivers introduced in unRAID 6.9, many do not see the /dev/dri folder but iGPU still works for hardware transcoding.
Aha, so I just follow the rest of the guide?
Edit: got it to work :) Works fine for the formats supported. One day I may upgrade the server to an 10th gen to get more supported formats and better quality, but it works just fine.
Edited by isvein
