Reduce power consumption with powertop
1 hour ago, mgutt said:
But it was connected through SATA?
Yes
  • Replies 1.2k
  • Views 685.8k
  • genesisdoeswhatnintendont
    Good news everyone! I managed to get C10 pkg C-State (previously I get no higher than C3) on Asrock LGA1700 mobo and you can too. Yay!   My setup is:   Motherboard: Asroc
  • I added a warning:   And a further explanation to the initial post:
  • TheLinuxGuy
    TheLinuxGuy
    Yeah I faced problems with proxmox GUI installer; I had to do CTRL+ALT+F2 to get console then add some forced configuration override to properly detect the iGPU. Here's the guide for the error (e
I took out the disk from where I moved it, instead of reading the serial from Unifi (where I moved the disk into and read serial from the UI... sorry)
WD500AAKS
WD Caviar SE16
MDL: WD5000AAKS - 00A7B0
Bit different identifiers then the previous I posted....
Edited by Chopsting
i have finally got it working.
Asrock C236 WSI
Xeon E3-1275 V6
32 GB ECC
Intel® X710 DUAL 10 GB SFP+
2x 2,5" Samsung 850 2 TB SSD
4x 2,5" Samsung 860 EVO 250 GB SSD
2x 20 TB Western Digital Ultrastar DC HC560
IDLE C7: OK, Mainboard cant go deeper 26,3 Watt
Parity and Full Smart Tests of all SSDs 42,2 Watt
Im Happy :-).
Without HDDs 14,7 Watt
Edited by cuddles
Aren't you using spindown?! 12W difference is only possible because of spinning Disks.
Has anyone else run into this issue with the system locking up during parity check?
There's a few solutions saying it resolved when C States were disable - which goes against the power savings..
Read the link. It's a bug of several Ryzen CPUs.
Ok thanks for clarification.
intel i9 11-900t
In intel chips we seem to have general boost all cores (performance governer) which keeps all cores (8c 8t) cpu at 3.6ghz with turbo boosts to 4.5ghz or Keep as low as possible (power saving) which actually changes the cores from 0.8 - 1.1ghz
Is there no middle ground or a better way for unraid to distribute tasks to the cpu. Or something that says ok prefer to only boost these 4/6 cores. In windows theres alot of controlling the cpu happening but my vague understanding is unraid leaves to the CPU to decide.
I can manually do it in bios under volting the CPU getting it to hover around 1.5ghz with boosting up to 2.5ghz. More cores also default to the lower 0.8ghz this way if not in use. This is on the performance governor.
There should be 37 powerstates to use with turbo at 90% 'when needed'.
cat /sys/devices/system/cpu/intel_pstate/num_pstates
37
cat /sys/devices/system/cpu/intel_pstate/max_perf_pct
100
cat /sys/devices/system/cpu/intel_pstate/min_perf_pct
18
cat /sys/devices/system/cpu/intel_pstate/no_turbo
0
cat /sys/devices/system/cpu/intel_pstate/status
active
cat /sys/devices/system/cpu/intel_pstate/turbo_pct
90
cat /sys/devices/system/cpu/intel_pstate/hwp_dynamic_boost
0
Powertop shows this: note the readout of CPU frequencies seem to differ between powertop and running: watch -n3 "cpufreq-info | grep 'current CPU'
821701811_Screenshot2023-01-11at13_17_47.thumb.png.78682548976bdf633ddb49c72b571d5b.png
My system seems to be using C1_ACPI - C3_ACPI
873268721_Screenshot2023-01-11at13_17_20.thumb.png.1cd3cbcafe639d125f63ae8af092a1a5.png
Edited by dopeytree
The actual question is how do I manually tell unraid which CPU I have because it seems to be using C_ACPM instead of the Intel PSATE's
I want to tell the kernal I have an intel i9 11-900t
Or should I just leave as is.
Edited by dopeytree
I'm building a new server to downgrade my power hungry Intel Xeon D-1528...
I've already bought a Fujitsu D3417-B motherboard, I'm planning to use it with an Intel i5 6400 (that I already have) or an i3 7100 or something similar.
I've seen that the most power efficient 10Gb NICs are the Intel X550 or X710 based.
I found this card below 100€: 94Y5200 IBM Intel X710 Quad-Ports SFP+ 10Gbps PCI Express 3.0x8 Gigabit Ethernet Network Adapter (servers4less.com)
Do you think it'll be ok? I'll use only 1 SFP+ port, can I disable the other 3?
Regarding power supply I was thinking about an RM550X. How do I recognize a 2021 model from the older one?
Thank you very much!
Simone
5 hours ago, mgutt said:
Thank you very much! What do you think about the 10Gb Nic?
No experience regarding this. 🤷
Thank you, I didn't see that the card I've found was an ML2 Lenovo card 🤦‍♂️ Do tou have any advice for which card to use?
P.S. Does anyone use a card based on this chip?
57810S-PB00.fm (cisco.com)
I've found this card which is pretty cheap:
10Gb SFP+ PCI-E Network Card NIC, with Broadcom BCM57810S Chip, Dual SFP+ Port, PCI Express X8, Support Windows Server /Linux/VMware : Amazon.it: Informatica
Thank you!
Edited by Simone Valmacco
Search in the forums for other users using the 57810S and ask them 🤷
Hi all, and especially Mgutt, nice topic! Thanks for the write up!
I've been doing my homework too and I'm trying to lower the power usage of my server.
First the hardware which was sort of chosen for decent low power a couple years back (Dutch tech site Tweakers.net has a nice 'low energy server' topic that helped me choose this build. Not perfect but not a bad basis I believe):
Processor: Intel Pentium Gold G5420
Motherboard: ASRock H370M-ITX/ac
Memory: Crucial Ballistix Sport LT BLS16G4D240FSB (1x 16GB)
SSD: Toshiba RC500 500GB
Harddrives: 3x 10TB. 2x WDC_WD100EMAZ-00WJTA0_1EGLJKWZ 1x WDC_WD101EDBZ-11B1DA0_VCJDR1NP (all three shucked from a WD Elements desktop unit)
Powersupply: Seasonic G-series 360 watt
USB stick: Samsung FIT Plus 32GB
Cooler: Scythe Big Shuriken 2 Rev. B
Case: Fractal Design Node 304
HDD's spin down every 30 min
Running completely headless unless I'm twaeking bios
Running Plex, SABNZB, Radarr, Sonarr, Nextcloud, Pihole, Mariadb, SWAG, DuckDNS, unifi controller as dockers. All seem very low in cpu usage nearly all are at 0.01%
Home Assistant as VM.
I ran powertop --auto-tune and all tunables jump to good without any issue.
Server now draws 18-20W when all the drives are idle. Aprox 35-40W when active. Measured with a Shelly plug S.
C-state doesnt drop below C3, haven't fugured out why that is. Even with the array disabled, so not running anything at all for 30 min. C3 is all I get.
Tips and Tweaks Power Saving CPU govenor set to Power Save
All C-states enabled in the BIOS.
Turbo Boost disabled.
Lot of pictures and screenshots here:
https://imgur.com/a/25ZBsGY
My main goal is to see if I can get an even lower idle consumption
Questions:
Does any of the above info tell me (or you in this case) why I'm not getting a higher C-state than C3? If so, can I fix that?
I'm guessing the SSD may be preventing it as I hardly have any other hardware. but how to prove that?
I never edited the go-file before. From what I understand from your first post in this topic I should be able to disable more hardware (usb ports, PCI-e slot etc) with the list of commands you posted in the first post.
How can I test them? Just in the console run: "for i in /sys/class/net/eth?; do ethtool -s  $(basename $i) wol d; done" for example? see if it gives any errors and do all of them one by one. if all is fine add the complete list to the go file (just copy paste?)?
I am also now doing the powertop --auto-tune by hand after every boot. that can go in the go-file too right?
Any tips or tweaks to my dockers to prevent them from spinning up disks? it doesnt happen very often but a couple times a day. I expect Nextcloud does that and Plex checks the library or something.
I hope all my info you need for some tips is there.... if not, let me know what else you need!
Thanks for any tips or comments!
Edited by Wabs
Disable Array Autostart, remove all drives and boot without them. Then add one after the other, unitl the C-State becomes bad.
yes. You should leave the array stopped while testing and check your logs for new error entries.
powertop --auto-tune executes the same commands. So no. The advantage of the separate commands is that you can remove problematic commands, which are maybe incompatible to your hardware. And you wouldn't need to install powertop at all.
Search in the forums. I'm sure its already discussed.
Thanks for the reply @mgutt!
I was trying to find info in the different PowerTOP tabs to find the reason why I wasn't going above C3. Makes sense to just disconnect hardware and see what happens. Will do so later this morning. Great tip to help me find the cause.
Also thanks for explaining what and how the commands work. I did notice that both ethernet controllers have wake on LAN enabled, even after I run --auto-tune. I switched them manually in powertop. I'll try your command for that one too then.
I'll do a search for lowering the power consumption for the dockers I'm running. If I find anything useful I'll link it here.
/edit1: update to SSD firmware and BIOS made no noticable changes. still max C3
/edit2: pulled the SSD out, no change either, still max C3
/edit3: disconnected the hard drives, no change, still C3
I'm out of hardware to disconnect... I've only got RAM, a processor and the USB stick with unraid on it left. Can't figure out why it wont go beyond C state 3.
Edited by Wabs
Maybe Ubuntu is worth a try? To exclude a problem inside of unRAID.
Do you have any recommended SSD to use as cache drive? I was looking at Intel P3605 or P3700 PCI SSD or standard Sata SSD...
Have a look at the list of hardware on Hardwareluxx: https://docs.google.com/spreadsheets/d/1LHvT2fRp7I6Hf18LcSzsNnjp10VI-odvwZpQZKv_NCI/edit#gid=0 you can see very efficient systems there and see what SSD's they have used. maybe that helps.
No change in Ubuntu. I now think that it could be my PSU. Thats quite old. Bought it in 2014 and the model exisits since 2012. I also read a couple of posts online on other forums that cheap and old PSU's prevent lower c-states. I'll see if I can find an affordable PSU that has a low power usage at very low load. I know the Corsair 550 2021 version would be a nice bet.
4 hours ago, Simone Valmacco said:
in every case Sata is usually more efficient than NvMe right?
Not relevant. I wasn't able to measure any difference with a C246M-WU2. But multiple NVMe can reduce the C-States while multiple SATA SSDs do not. I think this depends on which Lanes are used (Chipset, which are already active or CPU, which maybe activate additional lanes).
I have the same motherboard as you (Asrock H370) and can reach C7.
Have you enabled all the ASPM settings in the BIOS? I also disabled the sound card and a few other settings in the BIOS.
My Hardware
Motherboard : ASRock H370M-ITX/ac
Processor: i5-8500T
Memory: 32GB (2x 16GB DDR4)
Disks:
    3x 16TG Seagate Exos.
    1 x 8TG Iron wolf,
    2x 6TG Iron wolf,
    2x 3TB WD Greens (currently in the process of clearing so I can remove)
    2x 500GB crucial SSD's
    1x Asus BW-16D1HT Bluray drive
    NVME 1TB Crucial P5 Plus 1TB M.2 PCIe Gen4 (should have got a 2TB :-)) in the m.2 slot
Array is connected via an Broadcom LSI 9207 SAS PCIe Card
PSU: Evga 500 W1, 80+ White 500W, Power Supply 100-W1-0500-K3
UPS: APC Smart-UPS 1000
I did the install one by one method last weekend and with everything installed except the SAS card and I was able to reach C7 states and was drawing 34W under idle (No HD's attached except the SSDs).
With the SAS card I could only reach C3
I also noted a maximum of 150w load on boot.
With everything installed:
Under a full parity sync I'm getting drawing 107W.
Note the 107W also includes:
    16 port Unifi managed switch
    A Unifi Controller Key
    Unifi Nano HD Wifi (via POE) + RSP pihole
They are all plugged in to the same UPS I'm using to measure.
I'm in the process of removing the SAS card and putting the NVME drive in its place.
Then putting a 4 port SATA pcie card into the M.2 slot (mainly because I already have the card)
Along with that I'm also of installing some power monitoring plugs so I can record the server separate from my other gear.
Arriving today:)
Edited by Spin-Master
When I run:
powertop --quiet --auto-tune
I get this error:
powertop: /lib64/libncursesw.so.6: no version information available (required by powertop)
powertop: /lib64/libtinfo.so.6: no version information available (required by powertop)
Cannot load from file /var/cache/powertop/saved_parameters.powertop
File will be loaded after taking minimum number of measurement(s) with battery only
My specs:
Intel® Core™ i7-8700K CPU @ 3.70GHz
ROG STRIX Z370-E GAMING
NVIDIA GeForce GTX 1080
32GB DDR4 RAM
Corsair TX850 80+ Bronze
6 120mm fans
2 80mm fans
LSI 9211-8i 6G SAS HBA
10 HDDS
2 NVME SSDs
Side question, does 90W seem normal with all drives spun down and with CPU at 2% and GPU in idle state of 10W?
Extremely bad. Consider a better and smaller power supply. If you stay with your dGPU then a Seasonic Titanium would be the best option.
Replace against an ASM1166 6 port card and use onboard SATA ports.
6 120mm fans
2 80mm fans
Check their power consumption and think about reducing the amount of fans.
Used in an VM or in unRAID? If by a VM: Do you set the GPU to standby if the VM is shutdown? German thread:
https://forums.unraid.net/topic/118039-strom-sparen-ansätze/
I would say you are wasting at least 40W.
I get this error
Only warnings, can be ignored.
