7 hours ago, matty2k said:
Unraid uses the same DNS like all other clients in my network (which is pihole).
Within pihole client list, NASA.fritz.box is also listed with its IP addresses.
Other clients are not able to resolve or connect via NASA.fritz.box.
My Unraid server is also not listed within Windows Explorer Network tap.
I always have to connect via IP address.
The server's full hostname is made by concatenating the servername (NASA) and the Local TLD (fritz.box), with a period in between. The clients on your network need to be able to resolve this hostname.
If NASA.frtiz.box doesn't resolve for anybody, then you should not put "fritz.box" as the Local TLD.  Change it to "local". This will enable mdns on the server and you should be able to access the server via http://NASA.local
  • Replies 2.6k
  • Views 690.4k
  • kennymc.c
    kennymc.c
1 hour ago, Strayer said:
I seem to have trouble with the new 'Invalid DNS entry for TLD' warning too… it says: "The DNS entry for 'noatun.lan.gru.earth' resolves to 192.168.178.2, you should ensure that it resolves to Array."
No need to take action here, we'll fix the message
The certificate I'm using is a wildcard certificate and definitely valid for the server:
        Subject: CN = lan.gru.earth
            X509v3 Subject Alternative Name:
                DNS:*.lan.gru.earth, DNS:lan.gru.earth
If this works in your current version of Unraid, it is not intentional. It won't work in 6.10
Unraid only looks at the "Subject: CN" line.  Normally that line needs to match [servername].[LocalTLD] exactly, but we made an exception for wildcard certs.
When the wildcard character exists in that line:
  Subject: CN = *.lan.gru.earth
Then we replace the * with the [servername] and the result needs to match [servername].[LocalTLD] exactly (case does not matter)
So for a wildcard cert to work in Unraid, the * needs to appear in the "Subject: CN" line not in the "Subject Alternative Name" area.
On 1/9/2022 at 1:34 AM, sonofdbn said:
Thanks. I had already done some Googling and couldn't find anything that explains enough down at my level. Bottom line is: will there be any problems with 6.10 if I just leave things as they are?
DNS rebinding only needs to be disabled if you want to use an unraid.net SSL certificate, it will not cause issues with self-signed certs. We'll be issuing an update to Fix Common Problems that addresses the shortcomings folks have found with the new tests, if that doesn't catch anything then you should be good to go as far as these settings are concerned.
Thank you!
Interesting, thanks for letting me know. I issued a new certificate with the wildcard as its common name and the warning is gone now. Any particular reason why this is unsupported?
"INVALID CERTIFICATE 1" warning??
'Your xxtower_unraid_bundle.pem certificate is for 'xxtower' but your system's hostname is 'xxtower.local'. Either adjust the system name and local TLD to match the certificate, or get a certificate that matches your settings. Even if things generally work now, this mismatch could cause issues in future versions of Unraid. The local TLD can be adjusted here: '
First time ever seeing this out of Fix Common Problems, can someone explain to me why and what's changed?
I presume FCP has been 'tightened' without a mention ...
I only ever use my machine on local network.
Thanks.
Edited by superloopy1
Thanks.
Seems like this needs a bit more testing so i'm adopting a hands off approach and just ignoring the warning for now, i've no idea how to get, or why i need a new 'certificate that matches your settings' when nothinh has changed at my (local) end. Just the plugin tht's changed, why??
A new test to prepare for changes coming in unRAID 6.10.
There is some discussion of it in the past 10 or 12 posts if you scroll up/back.
More than that actually.  This series of tests (and yes we're finding some corner cases regarding it) actually began due to changes on Windows 11 which prevented me from mounting any SMB share hosted on Win11 to any of my servers.
My system is well and truly screwed up with no gui access after calling 'rm /boot/config/ssl/certs/*.pem' as previosuly referenced in an attempt to tidy up this invalid certificate error, and then setting management access ssl/tls to 'yes', i stupidly misread the help. It was previously set to auto which i now need to reinstate cos i'm apparently not using SSl and each login attempt comes up as https//: not http:// as before. Server is only local to me so this is a real pain of a problem. how can i reinstate http: only access??
<Edit> Fixed!
Thanks.
Please test again when the next version of Fix Common Problems is available, thanks!
<Edit> Fixed!
Not sure what went wrong, but glad you are back up and running ;)
Hi folks, if you think you were hitting some false positives with the recent certificate and LocalTLD tests, please update to the latest Fix Common Problems and run the tests again.  If it is still flagging issues I'd recommend cleaning them up before moving to 6.10.
If you have a custom certificate this tests that the "Subject: CN" of that certificate matches the [servername].[LocalTLD] settings of your server.  If you use a custom wildcard cert, it verifies that the "Subject: CN" is *.[LocalTLD] . Unraid does not use the "Subject Alternative Name" fields.
See Settings -> Identification to set the [servername] and Settings -> Management Access to set the [LocalTLD]
If there are warnings about a "Missing or Wrong DNS Entry for host" that means the server is not able to lookup an IP address for [servername].[LocalTLD] . In other words, if your servername is "Tower" and you specify the LocalTLD as "mydomain.com" then this tests that Unraid is able to do a DNS lookup for "Tower.mydomain.com". The point of this is to catch errors where people have provided an invalid LocalTLD. (i.e. don't add your ISP's domain name to the LocalTLD, unless Tower.myispsdomain.com actually resolves to the server's IP)
(There is a corner case where you might have Unraid setup to use a different DNS server than the rest of your network. In this case, as long as the rest of the network is able to resolve the server's IP, it should be ok to ignore the test.)
If you get warnings about having a blank LocalTLD, you should either set that to "local" or an actual domain name. This will help with any SMB connections that rely on MDNS (including Windows 11) regardless of the version of Unraid that you are running.
Need clarification on something? Feel free to ask if the above does not cover it
Warning is gone now, thanks for looking into this!
Just a typo: "It is highliy recommended" should be "highly"
Non persistent share excludes in Fix Common Problems Solved (not a problem except me being stupid)
I wanted to use Docker Safe New Perms and want to exclude some shares from the process. This led me to Fix Common Problems.
I can select the shares I want and when clicking [EXCLUDE SELECTED] the selected shares ends up on the top line.
But, when I go back to DSNP the only share that is listed as excluded is the default appdata. And if I refresh Fix Common Problems the selections are gone.
I'm running 6.9.2 and FCP is updated to latest. Discussed it on the Discord server and one other person tested with 6.10RC2 with the same problem. Same person also checked editing the FCP settings.json file to add the excluded share(s), and then saw the share listed together with appdata on the Docker Safe New Perms page.
Edited by tetrapod
Upgraded to the latest FCP (2022.01.16), and got an error message "Docker application Docker application binhex-rtorrentvpn has volumes being passed that are mounted by Unassigned Devices, but they are not mounted with the slave option has volumes being passed that are mounted by Unassigned Devices, but they are not mounted with the slave option".
So I went to the settings for binhex-rtorrentvpn and fixed that, but after running Rescan under FCP I get the same message. Not sure what I should be doing. Also, haven't changed the docker app settings for a while, so not sure why this error is being picked up now - perhaps it's a new check?
[Edit: My bad. Forgot that I had two volumes mounted, and had only fixed one of them. After fixing the other one it all looks good now.]
Edited by sonofdbn
Update
On 1/16/2022 at 9:33 PM, Squid said:
Did you hit Apply?  works for me
f..k - second time today I feel really stupid :-$
Only consolation is that now I can go back to discord and get somebody else to feel stupid too ;-)
Greetings!
I'm trying to find the cause of the changes of permissions in my appdata folder.  I noticed appdata is not listed in the "Permission Test/Fix Excluded ON" list, it does however say "Docker Appdata Folders and CA backup Destination is automatically excluded".   I haven't touched this setting for a long time and have not made changes I could think of that would reset permissions for everything in the appdata folder, except for the fact the plugin was updated recently.
I'm not making accusations, just trying to rule out all the possibilities and trying to figure the cause of it.  Thanks.
Permissions aren't changed by Fix Common Problems.  They are changed if you run New Permissions against the appdata share (Docker Safe New Permissions won't touch appdata)
Appologies..  I should have post this in appdata backup and restore..  moving there now.
My warning regarding DNS is gone since I added local domain „fritz.box“ in pi-hole.
So you mean the pihole is now resolving NASA.fritz.box to the correct IP inside your network? That is perfect.
Yes. And I do not get any error from CA.
IP address was correct before too, but not the local domain name.
Edited by matty2k
