  • Replies 814
  • Views 211.4k
In my case, the drive doesn't show up in /dev/disk/by-id, or even in /dev.  Also, lsblk doesn't show it either.
I know that I used to connect drives in this way in order to preclear them.
If I connect the esata to another machine (running Arch Linux), then the drive does appear in /dev and lsblk.
I have a suspicion that the new drive limitation in unRAID is preventing the drive from being shown.
Have you tried to run this?
udevadm trigger --action=change
The limitation now applies to connected devices, not just unRAID configured devices, so that may be. What license and how many devices are you trying to use?
Okay, that made the drive appear - both in unassigned devices list and preclear devices list.
It's an UDEV problem; or a rule is bugged or your HBA is not issuing an ADD action.
Try this and see if a ACTION=add is triggered:
udevadm test --action=add $(udevadm info -q path -n /dev/SDX )
- I suspect that this is due to changes in the unRAID drive handling code.
I don't think so, because it's the kernel that identifies and sets up the devices.  Tom would not modify the kernel.
after gfjardim fixed the esata problem i have a new one:
this plugin is initializing to late, so my sabnzbd is already expecting /mnt/downloads/… directories to work with it. like resuming the downloads. is it possible to mount the drive faster before every other plugin? as fast as in the go file?
Simple answer: migrate to Docker or ask your plugin maintainer to delay it's startup to a latter event.
Like this?:
root@Tower:~# udevadm test --action=add $(udevadm info -q path -n /dev/sdk )
run_command: calling: test
adm_test: version 182
This program is for debugging only, it does not run any program,
specified by a RUN key. It may show incorrect results, because
some values may be different, or not available at a simulation run.
builtin_kmod_init: load module index
add_matching_files: unable to open '/run/udev/rules.d': No such file or directory
parse_file: reading '/lib/udev/rules.d/10-dm.rules' as rules file
parse_file: reading '/lib/udev/rules.d/11-dm-lvm.rules' as rules file
parse_file: reading '/lib/udev/rules.d/13-dm-disk.rules' as rules file
parse_file: reading '/lib/udev/rules.d/40-slackware.rules' as rules file
parse_file: reading '/lib/udev/rules.d/42-usb-hid-pm.rules' as rules file
parse_file: reading '/lib/udev/rules.d/50-udev-default.rules' as rules file
parse_file: reading '/lib/udev/rules.d/59-non-libata-devices.rules' as rules file
parse_file: reading '/lib/udev/rules.d/60-cdrom_id.rules' as rules file
parse_file: reading '/lib/udev/rules.d/60-floppy.rules' as rules file
parse_file: reading '/lib/udev/rules.d/60-persistent-alsa.rules' as rules file
parse_file: reading '/lib/udev/rules.d/60-persistent-input.rules' as rules file
parse_file: reading '/lib/udev/rules.d/60-persistent-serial.rules' as rules file
parse_file: reading '/lib/udev/rules.d/60-persistent-storage-tape.rules' as rules file
parse_file: reading '/lib/udev/rules.d/60-persistent-storage.rules' as rules file
parse_file: reading '/lib/udev/rules.d/60-persistent-v4l.rules' as rules file
parse_file: reading '/lib/udev/rules.d/61-accelerometer.rules' as rules file
parse_file: reading '/lib/udev/rules.d/65-kvm.rules' as rules file
parse_file: reading '/lib/udev/rules.d/65-permissions.rules' as rules file
udev_rules_new: ignore empty '/etc/udev/rules.d/70-persistent-cd.rules'
parse_file: reading '/etc/udev/rules.d/70-persistent-net.rules' as rules file
parse_file: reading '/lib/udev/rules.d/75-cd-aliases-generator.rules' as rules file
parse_file: reading '/lib/udev/rules.d/75-net-description.rules' as rules file
parse_file: reading '/lib/udev/rules.d/75-persistent-net-generator.rules' as rules file
parse_file: reading '/lib/udev/rules.d/75-probe_mtd.rules' as rules file
parse_file: reading '/lib/udev/rules.d/75-tty-description.rules' as rules file
parse_file: reading '/lib/udev/rules.d/78-sound-card.rules' as rules file
parse_file: reading '/lib/udev/rules.d/80-drivers.rules' as rules file
parse_file: reading '/lib/udev/rules.d/95-dm-notify.rules' as rules file
parse_file: reading '/lib/udev/rules.d/95-keyboard-force-release.rules' as rules file
parse_file: reading '/lib/udev/rules.d/95-keymap.rules' as rules file
parse_file: reading '/lib/udev/rules.d/95-udev-late.rules' as rules file
parse_file: reading '/lib/udev/rules.d/99-fuse.rules' as rules file
parse_file: reading '/etc/udev/rules.d/99_persistent_unassigned.rules' as rules file
udev_rules_new: rules use 24144 bytes tokens (2012 * 12 bytes), 15288 bytes buffer
udev_rules_new: temporary index used 15680 bytes (784 * 20 bytes)
udev_device_new_from_syspath: device 0x6276b0 has devpath '/devices/pci0000:00/0000:00:1f.2/ata6/host7/target7:0:0/7:0:0:0/block/sdk'
udev_device_new_from_syspath: device 0x62d530 has devpath '/devices/pci0000:00/0000:00:1f.2/ata6/host7/target7:0:0/7:0:0:0/block/sdk'
udev_device_read_db: no db file to read /run/udev/data/b8:160: No such file or directory
udev_rules_apply_to_event: GROUP 6 /lib/udev/rules.d/50-udev-default.rules:67
udev_device_new_from_syspath: device 0x62ea40 has devpath '/devices/pci0000:00/0000:00:1f.2/ata6/host7/target7:0:0/7:0:0:0'
udev_device_new_from_syspath: device 0x62f110 has devpath '/devices/pci0000:00/0000:00:1f.2/ata6/host7/target7:0:0'
udev_device_new_from_syspath: device 0x62ad60 has devpath '/devices/pci0000:00/0000:00:1f.2/ata6/host7'
udev_device_new_from_syspath: device 0x62b210 has devpath '/devices/pci0000:00/0000:00:1f.2/ata6'
udev_device_new_from_syspath: device 0x62b660 has devpath '/devices/pci0000:00/0000:00:1f.2'
udev_device_new_from_syspath: device 0x62bb10 has devpath '/devices/pci0000:00'
udev_rules_apply_to_event: IMPORT 'ata_id --export /dev/sdk' /lib/udev/rules.d/60-persistent-storage.rules:32
udev_event_spawn: starting 'ata_id --export /dev/sdk'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_TYPE=disk'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_BUS=ata'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_MODEL=WDC_WD10EARS-00Y5B1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_MODEL_ENC=WDC\x20WD10EARS-00Y5B1\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_REVISION=80.00A80'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_SERIAL=WDC_WD10EARS-00Y5B1_WD-WCAV56040419'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_SERIAL_SHORT=WD-WCAV56040419'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_WRITE_CACHE=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_WRITE_CACHE_ENABLED=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_FEATURE_SET_HPA=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_FEATURE_SET_HPA_ENABLED=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_FEATURE_SET_PM=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_FEATURE_SET_PM_ENABLED=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_FEATURE_SET_SECURITY=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_FEATURE_SET_SECURITY_ENABLED=0'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_FEATURE_SET_SECURITY_ERASE_UNIT_MIN=204'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_FEATURE_SET_SECURITY_ENHANCED_ERASE_UNIT_MIN=204'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_FEATURE_SET_SMART=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_FEATURE_SET_SMART_ENABLED=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_FEATURE_SET_AAM=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_FEATURE_SET_AAM_ENABLED=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_FEATURE_SET_AAM_VENDOR_RECOMMENDED_VALUE=128'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_FEATURE_SET_AAM_CURRENT_VALUE=128'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_FEATURE_SET_PUIS=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_FEATURE_SET_PUIS_ENABLED=0'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_DOWNLOAD_MICROCODE=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_SATA=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_SATA_SIGNAL_RATE_GEN2=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_ATA_SATA_SIGNAL_RATE_GEN1=1'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_WWN=0x50014ee203cca9b8'
spawn_read: 'ata_id --export /dev/sdk'(out) 'ID_WWN_WITH_EXTENSION=0x50014ee203cca9b8'
spawn_wait: 'ata_id --export /dev/sdk' [8628] exit with return code 0
udev_rules_apply_to_event: LINK 'disk/by-id/ata-WDC_WD10EARS-00Y5B1_WD-WCAV56040419' /lib/udev/rules.d/60-persistent-storage.rules:44
udev_rules_apply_to_event: IMPORT builtin 'path_id' /lib/udev/rules.d/60-persistent-storage.rules:57
udev_rules_apply_to_event: IMPORT builtin 'path_id' returned non-zero
udev_rules_apply_to_event: IMPORT builtin 'blkid' /lib/udev/rules.d/60-persistent-storage.rules:72
builtin_blkid: probe /dev/sdk raid offset=0
[*****Long pause here*****]
udev_rules_apply_to_event: LINK 'disk/by-id/wwn-0x50014ee203cca9b8' /lib/udev/rules.d/60-persistent-storage.rules:82
udev_rules_apply_to_event: GROUP 6 /lib/udev/rules.d/65-permissions.rules:13
udev_node_add: handling device node '/dev/sdk', devnum=b8:160, mode=0660, uid=0, gid=6
node_fixup: preserve permissions /dev/sdk, 060660, uid=0, gid=6
node_symlink: preserve already existing symlink '/dev/block/8:160' to '../sdk'
link_find_prioritized: found 'b8:160' claiming '/run/udev/links/disk\x2fby-id\x2fata-WDC_WD10EARS-00Y5B1_WD-WCAV56040419'
link_update: creating link '/dev/disk/by-id/ata-WDC_WD10EARS-00Y5B1_WD-WCAV56040419' to '/dev/sdk'
node_symlink: preserve already existing symlink '/dev/disk/by-id/ata-WDC_WD10EARS-00Y5B1_WD-WCAV56040419' to '../../sdk'
link_find_prioritized: found 'b8:160' claiming '/run/udev/links/disk\x2fby-id\x2fwwn-0x50014ee203cca9b8'
link_update: creating link '/dev/disk/by-id/wwn-0x50014ee203cca9b8' to '/dev/sdk'
node_symlink: preserve already existing symlink '/dev/disk/by-id/wwn-0x50014ee203cca9b8' to '../../sdk'
udev_device_update_db: created db file '/run/udev/data/b8:160' for '/devices/pci0000:00/0000:00:1f.2/ata6/host7/target7:0:0/7:0:0:0/block/sdk'
ACTION=add
DEVLINKS=/dev/disk/by-id/ata-WDC_WD10EARS-00Y5B1_WD-WCAV56040419 /dev/disk/by-id/wwn-0x50014ee203cca9b8
DEVNAME=/dev/sdk
DEVPATH=/devices/pci0000:00/0000:00:1f.2/ata6/host7/target7:0:0/7:0:0:0/block/sdk
DEVTYPE=disk
ID_ATA=1
ID_ATA_SATA=1
ID_BUS=ata
ID_TYPE=disk
MAJOR=8
MINOR=160
SUBSYSTEM=block
UDEV_LOG=6
USEC_INITIALIZED=96505629495
builtin_kmod_exit: unload module index
root@Tower:~#
I've inserted 'Long pause here' text in the output above - it took many seconds, maybe more than a minute, but after that the drive did appear in the gui.
The output seems correct. I have no clue about your problem.
I wonder whether I was simply being too impatient and not waiting long enough.  I didn't time the delay above, but it was in the order of a couple of minutes.
Edit to add:
I do notice that while the 'new' esata-connected drive is attached, another 'unassigned' drive (my docker drive) gets accessed very heavily.  I wonder whether this is the reason for the delay in the esata drive being recognised.
At present, I'm still mounting the docker drive in my 'go' script - I haven't yet got around to setting it to automount with the new plugin.
I'm so late to this party, mainly because I've never had any need to SNAP any usb drives in the past... but now I'm looking for faster/bigger/more drives than the single cache drive available by the system and have finally found this. Well done gfjardim, such a fine plugin!
IMHO though, the name is an understatement. Sure it's factual and correct... but unassigned devices are like a pool of disks in waiting... like purgatory. What if we want to give a more permanent role of these disks? Just my 2 cents :)
Btw, can we raid a few disks together via btrfs and make it available through this plugin? I already have a btrfs mirorred cache drive, looking to add 3 drives in raid-5 config if possible.
They are unassigned disks from the main array. They are not in the purgatory, they just find a nice "Unassigned Devices" home.  ;D
About btrfs, I think if you mount any of the disks in the btrfs pool, the pool itself get's mounted, but I cannot test this.
I suppose I would suggest asking if you can absorb the SNAP name. dlandon has said this works better in v6 and he's going to minimally maintain SNAP from now on.
There is a new plugin that has the functionality of SNAP that integrates better with unRAID V6.  The plugin is here: http://lime-technology.com/forum/index.php?topic=38635.0  I recommend you convert to this plugin.  I will maintain SNAP as long as I can with my limited time to work on it, but I won't make any enhancements.
Maybe call this SNAP2.0 .. or PANS ;-)
SUDS: Sharing Unassigned Devices Simply / Simple Unassigned Device Sharing
MUD: Mounting Unassigned Devices
[hangs head]
Why?  WHY!?!?!?!
Stop trying to make un[insert anything] happen, its not going to happen  8):P
[hangs head]
Why?  WHY!?!?!?!
Will call it unDAMN (unRAID Disk Auto Mount for Nimrods).  ::)
[hangs head]
Why?  WHY!?!?!?!
That's perfect! Actually I really like that it uses a current tab, why add extra tabs???
I just reused the space because, let's face it, the original one is just for informational purposes (useless).
Agreed.
How about unMount
Lol
Just kidding
I like it. You could start a real "Who's on First" routine with that.
How about unMount
Lol
Just kidding
How to mount if its called unMount ?  :o :o
