On 2/5/2023 at 4:39 PM, ford.anthonyj said:
FCP keeps informing me that my system is throwing an MCE error, but I can't seem to figure out what it might be.
Here's the full diagnostic.
Feb  5 15:12:01 Leviathan mcelog: failed to prefill DIMM database from DMI data
Feb  5 15:12:01 Leviathan mcelog: Kernel does not support page offline interface
BIOS update might fix.  Otherwise safe to ignore
  • Replies 2.6k
  • Views 696.6k
  • kennymc.c
    kennymc.c
Feb 16 22:24:35 Tower  mcelog: failed to prefill DIMM database from DMI data
Feb 16 22:24:35 Tower  mcelog: Kernel does not support page offline interface
BIOS update might fix if available, but otherwise harmless
I have a bunch of duplicate files on multiple disks due to a crash during a unBalance operation and I wanted to run the Extended Test to find them but the button seems to be missing from the plugin.
I thought it was there previously but I may be mistaken.
Any thoughts on how to get the button back?
On 12/10/2022 at 8:46 AM, Squid said:
Extended Tests are now removed from FCP
Extended tests had their use a number of years ago, but nowadays
  1. No matter what you do it's a given that it will always return issues
  2. Those issues are not "real" per se
  3. They're primarily tests for SMB compatibility, (and any errors are once again not "real" issues)
  4. It takes forever to run
FCP Error:  * **Out Of Memory errors detected on your server**
I suspect it was a nordlynx container, which i wasn't using anyway, and looked funny so i removed it.  But please let me know if there is something else here?  Thanks!
EDIT: now contains older diag file from before I removed nordlynx
unraid-diagnostics-20230225-1100.zip
unraid-diagnostics-20230223-0528.zip
Edited by btrcp2000
Added a diag file from before nordlynx removal
Update: OOM errors continue, so it wasn't nordlynx.  Anybody have a minute to look at those diags?
Bump.  Can someone please take a look?  I'm down to one functioning VM, no Dockers due to this memory issue.
Thanks!
How much RAM did you leave open for Unraid? Your sig says you have 32GB RAM, perhaps you need to lower your VM's allocation. Oftentimes the best performance is obtained by reserving only the minimum necessary for the VM to function, and allow Unraid to use the majority of the RAM for I/O caching. Try running the VM with 4 or 8GB and see how it performs.
Thanks for respionding. Sig is outdated, I now have 64gb.  The functioning VM uses 8gb.  ANother one somehow is now using 24gb, which is not something I would have set on purpose, and certainly hadnt made any changes in at least a year. That can't be helping, so I will push it back down to 8gb.  But the strange thing is that VM hadnt booted in over a week, and I was still getting OOM errors.  is that RAM reserved even if the VM isnt running?
I don't think it should be, but sometimes memory fragmentation comes into play, where the total amount free is fine, but the largest contiguous block of memory is too small. Rebooting is the only thing I know to do in that situation.
Hello I am a bit stumped on how to solve this problem. I apparently have added a folder that does not belong in /mnt and my Rootfs is getting full (currently 100 % used).
Not sure how to solve this issue. Can someone point me in the right direction? I cannot seem to find how to access this files to even take a look at it.
jarvis-diagnostics-20230302-0835.zip
The easiest way would be to go the Linux command line using the _> icon at the top right of the GUI and use
ls -l /mnt/*
To see what folder is there.   Chances are it is being created by a bad mapping in a volume container.
as an alternative you could use the ‘mc’ command to bring up Midnight Commander which is a simple file manager.
So I noticed fix common problems was displaying an error stating "Invalid folder addons contained within /mnt" shortly after I received an update for unassigned devices.
I was able to find this post on the forum that mentions that specific path. Is this a fix common problems plugin issue or should I post on the unassigned devices thread?
I don't have anything special going on with my instance (no ZFS etc) so I'm not sure why this would have suddenly popped up...
Edited by Reptar
I get the same message from fix common problems displaying an error stating "Invalid folder addons contained within /mnt" shortly after I received an update for unassigned devices.
Other stage behavior, I know of read errors on my one disk and will check cables over the weekend.
Further than that it seems there is another problem as my Unraid Server looses network connectivity and I cannot ping or access anything
datavault-diagnostics-20230304-0411.zip
Same to the above.
A few hours ago my server completely crashed. Plex stopped working, the docker wouldn't start, and Fix Common Problems reported an error about a file system being corrupt or read only. The times I've seen that error were because docker.img was full or cache was full. Neither of those were the case.
I tried stopping all my Docker containers to debug a possibly failing drive but Docker just crashed entirely. My array wouldn't stop because the drives were unmountable. It was stuck on a loop of trying to unmount disks. Docker containers had tasks running judging by lsof but I couldn't access anything Docker related. Ended up just running a reboot command which ended up being an unclean shutdown.
Started my array in maintenance mode, checked all the drives, no errors. There were some plugin updates (I'm guessing the recent ones for this and Unassigned Devices) so I updated.
Everything seems to be fine now except the error "Invalid folder addons contained within /mnt". This is what's there:
All my plugins are up to date and I still have that error. Judging by previous posts here, specifically this one:
...I'm speculating the crash is related to the posts above or what the 03.03.2023 Unassigned Devices update fixed? I don't know what Rootfs is but something getting 100% full sounds like it would cause the corrupt file system or read only error that's usually from cache or docker.img being full. I've never seen a crash like this before.
Hopefully this info helps. Currently everything seems to be working fine again. Sorry for the probably unrelated post.
Edited by s449
Ignore it.  The UD update added the folder and FCP is reporting it as a problem, but it is not.
14 minutes ago, Garett said:
This is weird..
See the post just before yours in this thread.
@dlandon : Thanks for the  clarification.  Was this folder addition for a specific purpose or just a happy accident?
Hello
I have been running years never had any errors but i see some changes have been made.
The error points me to no specific location
I have read thread and added my diagnostics file please can somebody help me fix the issue ?
bearcave-diagnostics-20230304-0911.zip
I read that many people have the same problem as me: "Invalid folder addons contained within /mnt ". I ran the command ls -l /mnt/* but there doesn't seem to be anything wrong. Thanks to whoever will answer me, and sorry for my english.
unraidserver-diagnostics-20230304-1126.zip
Edit : Fixed by updating FCP to 2023.03.04
Edited by Sionree
solved
That folder is for people to add their mounts for things like zfs devices and rclone , rather than putting the mounts in places like /mnt/disks or /mnt/remotes.  FCP was updated to not flag that folder, but appears to need another update.  For now ignore the FCP warning.  Read the UD release notes for more info.  Your system doesn’t have a problem.
2 hours ago, OsoPolar said:
Hello
Nothing to fix.  Ignore FCP for now until it gets an update.  UD added that folder.  Read UD release notes for more info.
