Keep getting out of memory errors. Not sure why or what app/dock/plugin would be causing it.
Any help would be appreciated.
running 6.10.0-RC8
tower-diagnostics-20220514-1157.zip
  • Replies 2.6k
  • Views 690.4k
  • kennymc.c
    kennymc.c
My extended FCP test is stuck. Despite killing the process with htop, FCP still says it is running. How do I fix this?
Edited by mason1171
clarification
It doesn't get stuck.  It just takes absolutely forever on some systems.
But,
rm /tmp/fix.common.problems/extendedPID
But,
Gotchu. I guess I shouldn't have killed the process
Hi, I've been getting that error for some days now. Is it time to replace the flash drive ?
/boot/config/shares/Squidbait-vast.cfg corrupted Your flash drive has possible corruption on /boot/config/shares/Squidbait-vast.cfg.
Diagnostic file attached.
tower-diagnostics-20220527-1553.zip
Just delete that file.  It will be corrupted however, but if that's the only one listed, then don't worry about it.
Since I forgot to post about it, yesterday's update for the Upgrade Assistant tests for IOMMU enabled and the tg3 driver running, so that you can decide whether or not to upgrade to 6.10.2
I just updated to 6.10.2, from 6.9.2
I got errors at first (once I was able to fix my docker not working, and that cache drive not being recognized, and there being syntax errors.... etc.....) that my flash drive error'd out, and was READ ONLY. This also caused Fix Common Problems to poop the bed super hard.
Following the advice, got a new flash drive, transferred the key over.... FixCommonProblems still hates everything about me, and is throwing the same errors. Is this residual from the previous drive, or is there something in the way I have messed everything which basically wrecks whatever flash drive I put it on?
Thanks a ton for all that you do.
unraid-diagnostics-20220601-0830.zip
Hey Squid, i'm getting what appears to be a false positive on a file i created on my USB:
/boot/config/usb-rules.cfg corrupted	Your flash drive has possible corruption on /boot/config/usb-rules.cfg.
This is the contents of that file (which just maps the zwave and zigbee controller from my HUSBZ-1 to static device entities on boot):
SUBSYSTEMS=="usb", DRIVERS=="cp210x", ATTRS{interface}=="HubZ Z-Wave Com Port", SYMLINK+="zwave"
SUBSYSTEMS=="usb", DRIVERS=="cp210x", ATTRS{interface}=="HubZ ZigBee Com Port", SYMLINK+="zigbee"
There doesn't appear to be any corruption in the file, i've recreated it just to be sure, so i'm thinking there is some sort of string of characters that the scan is detecting as corruption.
Edited by PhAzE
I had some errors with my hardware and now have Unraid 6.10.2 Stable again, but its show a corrupt file on my Boot USB drive. Not sure I can remove this and it will be recreated. Your flash drive has possible corruption on /boot/config/smart-one-backup.cfg. Post your diagnostics in the forum for more assistance. Diag attached. Any help would be greatly appericated. Thanks in Advance.
unraid02-diagnostics-20220608-1624.zip
Since updating to Unraid Version: 6.10.2 after along time of not updating. I have gotten the "Multiple NICs on the same IPv4 network" with the Fix Common Problems Plugin. However in my network settings its list only one network interface. (Screenshots are attached) Any suggestion you have to resolving this would be appreciated. This was the first time my unraid server has been restarted in some time since it has just been working perfectly since I applied the last update.
I am also unable to use WireGuard now as it doesn't let me access the internet only the unraid server from the peer. This is probably tied to the same issue listed.
Network Settings
Diagnostic report attached below
tower-diagnostics-20220609-1700.zip
You seem to be getting continuous errors along the lines of
Jun 10 05:33:01 BIGDADDY kernel: sd 2:0:0:0: [sdb] tag#12 UNKNOWN(0x2003) Result: hostbyte=0x04 driverbyte=DRIVER_OK cmd_age=0s
Jun 10 05:33:01 BIGDADDY kernel: sd 2:0:0:0: [sdb] tag#12 CDB: opcode=0x2a 2a 00 0d f0 3f 60 00 00 40 00
Jun 10 05:33:01 BIGDADDY kernel: blk_update_request: I/O error, dev sdb, sector 233848672 op 0x1:(WRITE) flags 0x1800 phys_seg 6 prio class 0
Jun 10 05:33:01 BIGDADDY kernel: BTRFS warning (device sdd1): lost page write due to IO error on /dev/sdb1 (-5)
### [PREVIOUS LINE REPEATED 2 TIMES] ###
Jun 10 05:33:01 BIGDADDY kernel: BTRFS error (device sdd1): error writing primary super block to device 2
Jun 10 05:33:03 BIGDADDY kernel: BTRFS warning (device sdd1): lost page write due to IO error on /dev/sdb1 (-5)
which indicates that there are issues with your cache pool since the sdd and sdb devices belong to it.
Not sure of the best way to proceed - maybe @JorgeB might have a view?
2 hours ago, randommonth said:
Any advice appreciated!
One of the cache devices dropped offline:
Jun  8 19:56:06 BIGDADDY kernel: ata1: hard resetting link
Jun  8 19:56:12 BIGDADDY kernel: ata1: COMRESET failed (errno=-16)
Jun  8 19:56:12 BIGDADDY kernel: ata1: reset failed, giving up
Jun  8 19:56:12 BIGDADDY kernel: ata1.00: disabled
Check/replace cables, also see here for better pool monitoring for the future.
i had a power failure and my backup n.u.t. didn't do its job properly so i had a hard shutdown 9 days ago.
now i have the same error again
/var/log is getting full (currently 100 % used)
can't even download diagnostics o_O
waiting for over 5 minutes now...
guess i should reboot?
already had the same problem some weeks ago. wasn't sure if i should've revived that topic or post here 9_9
Edited by pika
forgot diagnostics
I'm going to reboot now. log shows zillions lines like this:
Jun 13 21:14:44 DataTower nginx: 2022/06/13 21:14:44 [crit] 7671#7671: ngx_slab_alloc() failed: no memory
Jun 13 21:14:44 DataTower nginx: 2022/06/13 21:14:44 [error] 7671#7671: shpool alloc failed
Jun 13 21:14:44 DataTower nginx: 2022/06/13 21:14:44 [error] 7671#7671: nchan: Out of shared memory while allocating channel /cpuload. Increase nchan_max_reserved_memory.
Jun 13 21:14:44 DataTower nginx: 2022/06/13 21:14:44 [error] 7671#7671: *1773828 nchan: error publishing message (HTTP status code 507), client: unix:, server: , request: "POST /pub/cpuload?buffer_length=1 HTTP/1.1", host: "localhost"
Jun 13 21:14:44 DataTower nginx: 2022/06/13 21:14:44 [error] 7671#7671: nchan: Out of shared memory while allocating channel /disks. Increase nchan_max_reserved_memory.
Jun 13 21:14:44 DataTower nginx: 2022/06/13 21:14:44 [error] 7671#7671: *1773829 nchan: error publishing message (HTTP status code 507), client: unix:, server: , request: "POST /pub/disks?buffer_length=1 HTTP/1.1", host: "localhost"
Jun 13 21:14:44 DataTower nginx: 2022/06/13 21:14:44 [error] 7671#7671: nchan: Out of shared memory while allocating channel /var. Increase nchan_max_reserved_memory.
Does the plugin also inform the user of best practices to prevent common problems?
For example:
  • UPS (and configured correctly)
  • Dynamix File Integrity plugin (installed and scheduled)
  • ECC Memory
  • Not sure if I'm missing anything else.  Maybe potential filesystem issues (btrfs vs. xfs recommenations).
No - It's a bit out of the realm of what FCP is supposed to do, and not particularly feasible and would be annoying, and there's many counter arguments against all of those examples.
Hi guys, following up since my post on June 10 (above). I deleted the docker image and changed to a docker directory. However I just received the same error warning about /var/log filling.
It appears I'm getting the same errors as last time, and checking the tip provided by Jorge provides the following:
[/dev/sdd1].write_io_errs    0
[/dev/sdd1].read_io_errs     0
[/dev/sdd1].flush_io_errs    0
[/dev/sdd1].corruption_errs  0
[/dev/sdd1].generation_errs  0
[/dev/sdb1].write_io_errs    17381866
[/dev/sdb1].read_io_errs     1092081
[/dev/sdb1].flush_io_errs    615464
[/dev/sdb1].corruption_errs  885679
[/dev/sdb1].generation_errs  0
The strange thing here is that sdd1 is an old SSD (6 years?) and old cable, whilst sdb1 is less than a month old, with a new cable. What could cause the new components to have the errors?
bigdaddy-diagnostics-20220628-1457.zip
Edited by randommonth
Revised the request
Device is dropping offline, this is usually a power/connection problem, suggest replacing/swapping both cables, power and SATA.
I've been getting an error message daily of a plugin not being compatible with unraid 6.10, but it's still working just fine, while I wait for the update.
Any way to suppress only this message?
"* docker.folder.plg Not Compatible with Unraid version 6.10.3"
Thanks!
Thanks!
Click ignore.
11 hours ago, wgstarks said:
Click ignore.
Thanks.
I was referring to the emails, but I accessed the fix common problems plugin area and clicked ignore on that warning.
Cheers!
When i run extended tests nothing happens, it says running but i do not get any status/messages, so i don't know if its done or just stopped.
If i start another window and check, it says no tests are running.
regards
// Hans
Edit:
this shows up in the log directly after starting extended test:
 atd[426]: PAM unable to dlopen(/lib64/security/pam_unix.so): /lib64/libc.so.6: version `GLIBC_2.34' not found (required by /lib64/libresolv.so.2)
Jul 12 04:59:08 Plexium atd[426]: PAM adding faulty module: /lib64/security/pam_unix.so
Jul 12 04:59:08 Plexium atd[426]: Module is unknown
Edited by Hansa
Added the log entry after starting extended test:
With the increasing popularity of btrfs and zfs snapshots and snapshot replication, it is becoming difficult to maintain a directory structure that doesn't run afoul of FCPs extended test for duplicate file names.  This is especially true since FCP ignores the disk setting "Enable user share assignment".
I am proposing an enhancement to FCP, to include the capability to enter a list of paths for exclusion from the duplicate file name test.
Just brainstorming:
  A path beginning with /mnt would be drive specific.
  A path beginning with /, but not /mnt would apply to all drives, e.g. "/.snapshots".
  An entry not beginning with /, ignore the folder contents anywhere, e.g. ".snapshots".
Edited by aim60
